No, the bulletin says that a single valve spring is to be replaced on engines other than the LT2 Corvette engine, the LT2 would get ALL springs replaced
Valve springs keep popping up as a recurring GM V8 problem. A friend’s 2017 Denali had one fail and dealer tech told him they were handling replacements on multiple trucks/SUV every day. I don’t understand why GM tolerates suppliers who produce faulty products. They are ruining their reputation.
The old saying spend peanuts you get peanuts. Lowest cost so they use them. Going the cheapest usually means it will end up costing you more in the long run. GM yet to figure this out yet.
When I rebuild my first Mopar motor for performance, there was no way I was going to use OEM springs. I had installed a high duration Crane cam, so I paid extra to get quality high performance springs. Apparently, GM felt that the stock OEM springs they used in trucks were good enough for their flagship Corvette. There is a reason exotic vehicles cost more. They install high quality components in their vehicles. There are areas to cut corners, but the engine shouldn't be one of them.
A guy in our club was building a C2 resto mod, and showed me the LS3 truck motor he was installing. He said it was far cheaper and just as good as the Corvette version. I still remain skeptical of that. I doubt you are going to exceed triple digit speeds or do 3 second launches in a C2, but still.
maybe a minor point, but Corvettes LT2 engines would require ALL Spring be replace (per the Advisory) which my read says if a spring goes, then ALL of them need to be replace. ?
i believe the point on the 5000 affected made by NextOne is tied to that many cars being built over the time frame in question.
Frustrating because GM and reputable suppliers know how to build springs that work. Look at the millions of Chevy V8 engines produced and the thousands of miles covered by each and valve spring failures have always been rare until recent history.
Yep GM could use high end spring suppliers like the Manley Performance info I posted in #57 above.
But I condensed their comments; their 1st intro paragraph said: "With seemingly square-lobe camshafts being produced today that provide tappet acceleration rates previously unheard of and valvetrain motion so aggressive it can turn the stoutest of pushrods into a spaghetti noodle, the need for superior valve spring technology combined with unsurpassed durability is greater than ever before."
Yep the small block I had in my '56 Chevy with the same bore spacing (albeit smaller diameter pistons and less stoke) as the LT2 never saw anything like today's valve spring strength performance requirements. Heck NHRA ProStock cars are probably replacing their 10,500 max rpm valve springs every race (they were turning ~13,000 before NHRA put on a limit.) Yep producing their ~1500 NA hp power requires huge valves on 500 cid engine and not doubt close to "Square" cam lobs as Manley said "tongue-in-cheek!" 495 NA from a small block also requires lots of lift, fast!
Please. The springs are not even the real issue. Mfrs do not build them to last. Look how much plastic and rubber is on the inside? It's amazing to me any of these engines last as long as they do. It doesn't benefit chevy or Ford or any mfr to make the engines out of materials that will last a lifetime even if they charged 20k more for the car.
I read in a magazine that porsche testing is extensive and no car is sent out with a flaw. Picture must be a fake as magazine said no flaws.
OK, so the auto press who you know for a fact lies about everything then lied once again about the 992S? 0-60 is not 2.9? Is it really 3.9? 4.9? Why don't you tell the rest of us here the whole truth and nothing but the truth. What are the real #s since you seem to be so sure about the absolute lack of integrity on the part of the auto press.
Once again, can't wait to hear our conspiracy theorists take on reality. Fire at will!
I remember my C5 z06 and always being asked if it was an oil burner. On to the C6 z06 and always being asked if the heads were done yet or if it had dropped a valve. And now this.
If only GM had used a good reputable brand and spent a little extra on springs then this would not be happening.
High-end aftermarket valve spring suppliers have run into issues with "bad batches" too. And not just with springs. Pretty much everything from time to time.
Any rational person who follows the automotive world is able to understand this as that scenario has been seen many times before, bad gears from China, killer air bags from Japan, and on. Don't waste your time with this clown, he has a death grip on his C8 hate. Really weird indeed.
It does tend to show pretty quick, the most miles I've seen so far is 428 at failure. Obviously I haven't been privy to all the failures, that's just the most I've heard of.
Great i'm at 460 getting ready to finally use the throttle properly and I'l possibly be the next to raise the limit?
I remember when companies like Boeing did everything in house to control quality vs make the most Dinero. The trade off is $$$ vs no (less) problems.
Great i'm at 460 getting ready to finally use the throttle properly and I'll possibly be the next to raise the limit?
Hit 500 miles today just before I got on the 3/4 mile long road by my house with no homes/people- only farm fields. Did two 0 to 60 runs!
First surprise was there was no drama! No wheel spin (I could detect.) Faster than my street rod that has more power/torque, 53% of it's weight on the rear 420 section width Mickey Thompson tires! It has lots of drama on the start of a banzai run! Have to check my PDR! Shifted at 6000 rpm and all valve springs still fine!
Have you got some paragraphs saved that you just copy and paste in every thread.
