Sponsored by: Wheel Design
engine compartment
Old May 5, 2021 | 07:54 PM
Red Mist Rulz's Avatar
Red Mist Rulz
Originally Posted by sanman55
I was told that as of today I am 8 away from the dealer giving my order to gm...He says he gets an allocation of 4-5 cars a month. I have the 1100 order number..??????
Thanks for your input...
So IF GM gives your dealer the "normal" number of allocations in May and June, you can figure you'll be in the June batch of allocations. But that's a big if. Many think there will be no, or very few, allocations for May and none for June.
If you dealer gets 8 allocations for May and June, your order would likely get accepted by GM in June. My calculations (which are mine, not GM's) say GM will be building April allocations into August, so June allocations could push into September or later.
If your dealer doesn't get at least 8 allocations for May and June, your order will go nowhere for the 2021 model year. Your dealer will have to reenter your order as a 2022. GM has told dealers they can start entering 2022 orders sometime in July. Hopefully your dealer would keep your place in line.
Either way, I don't think you'll see a car until Fall at the earliest.
Old May 5, 2021 | 09:39 PM
sanman55's Avatar
sanman55
Thanks....disappointed....I contacted chevyDaves blog and he is suppose to call me tomorrow..If he does it will be interesting..Will let all know. He had a blog that said if you ordered in august 2020 it would be 18 months to get it???
The conseirge for chevy told me that even after the build it could take up to 8 weeks for quality control....to let the car go and then shipping too complicated.............man this is just getting worse..
Old May 6, 2021 | 07:44 PM
Zymurgy's Avatar
Zymurgy
Moderator
Don't believe everything the Concierge tells you. That "up to 8 weeks" is a worst case scenario. Most cars are shipping within a week after being built.
I suggest you read the following threads:
Ordering a Corvette - Allocations and Constraints Explained
C8 Corvette Orders - Event Codes and What They Mean
These can both be found in the C8 Order Info-Allocations/Constraints, Prices, Order Guide, Order Tracking/codes, etc sticky thread.
Old May 8, 2021 | 07:39 PM
sanman55's Avatar
sanman55
Thanks to all. I had a call from chevy Dave and he helped explain things to me.I can not believe he actually called me...If I can get gm to take my order by june I should have it in about 3 months..So if I get it in late Sept. I will be happy.
My neighbor ordered his in december..I am 2 months after that,.from the same dealer as me...So when his gets started to build I am next...
I AM EXCITED AGAIN....thanks to you guys for all your help and knowledge...There is a lot of that hear..
