DCT-Problems/Solutions
Those '22 model year failures I read about were within several hundred miles. These failures, along with having to wait many weeks in some cases for replacements to be installed, also is disheartening. I try to remember this is a "first world problem" in the grand scheme of things though.
I appreciate all the responses in this thread just like the OP.
Ray
No one is claiming that the issue pervades every single c8. No one is claiming that this is the worst problem ever either. But you know what you are not seeing voiced to this magnitude as a problem? Timing issues, exhaust issues, power steering failure issues, cylinder 1-3-5-7 failure. That is because those issues do not frequently appear to the level that the transmission has.
Get every owner victimized by a lemon DCT to join you in a class action lawsuit against Chevrolet, Tremec, and GM. It will be summarily dismissed since when you bought the car and signed the sales documents ― which neither you nor anyone else ever reads ― compels you to settle disputes by binding arbitration. And guess who gets to pick the arbitrator? You guessed it; GM. And guess how the arbitration will conclude? That's right, GM will repair or replace at their discretion any defective parts with new or refurbished parts. End of story. Case dismissed.
You will get on TV for 10 minutes. Maybe even cable. And you will embarrass GM. And you may cost them a sale or two. But even after everyone is made aware, what do you expect to happen?
If you endeavor to do this and have credible evidence to support your claim, I will donate to your legal fund. Hell, maybe Chevy sold a bum DCT to an attorney and he or she will take the case pro bono!
I love the post from the guy who gets his information from Facebook. According to reliable sources ― insert facetious grin here ― on Facebook, the C8 DCT "loses gears". No further exposition on what exactly "losing gears" means ― do they fall out, lose their teeth, refuse to mesh? ― but hey, he's on the list for a 2023 (really?) and he's concerned.
Ray
Only time will tell….
More common issues appear to fall into a couple different categories, that might be interrelated or confused because we don't know the ultimate truth in these cases, only anecdotal evidence:
1) Contamination issue with solenoids, valve bodies, etc.
2) Clutch failure (might be related to #1)
3) mLSD/eLSD whine / shimming problems
4) Porosity issues
5) TCM / electrical / sensor problems
6) Pan cover / gasket leaks, cracked casing around PAN and DCT filter covers (due to overtorque of pan cover bolts). This problem may be related to #4 above, but techs failed to determine the correct source of leak, then over torqued the cover bolts (they are low low torque).
7) Snapped half-shafts (not really a DCT issue, but a drive train issue and also shows how stout the DCT really is)
Ray
Tell me though, without those voicing the issues that you of course do not think exist, how would I find these class members? I would not pay for mail sir and I sure as hell would not do anything for free...you see I already did my pro bono in law school.
You may be on to something though, I give you that.
https://www.corvetteforum.com/forums...post1602044863
It would be nice to see a detailed video of the internals of the TD9080, but I haven't seen one yet. I did capture some facebook videos that a corvette tech at a dealer posted as he was tearing one down. He showed some issues with solenoids, a wiring harness issue, and an o-ring issue with the pipe/tube that connects to the top of the external DCT filter, also talked about the really low torque specs and that some people may be over torqueing bolts on covers. I was surprised to see in that video a lot of ZIP TIES being used for cable management. Given the potential for heat, slippery DCTF fluid etc, I would be a lot more comfortable with a safety wire approach vs plastic ties.
Here is this nice video of the TR9070 used in the Mustang:
Much different transmission, but a DCT nonetheless and it appears there are some similar design elements in play, especially the synchronizers and shift forks.
Solenoids and valve bodies are moved around because they needed to flatten the TR9080 to get center of mass lower, and the TR9080 has two output shafts and diff's integral to the design.
I know GM has a nice cutaway model on display, but I would like to see one actually fully disassembled and every part scrutinized.
It would be awesome too to see videos of the manufacturing process for all the parts, including castings, gears, etc. Do they shot peen all the gears in the TR9080, etc.
several years ago I bought a first year sporty Acura. The transmissions started failing on some cars and I always heard a noise in mine but considered myself lucky- eventually all the transmissions failed-I made it to 70k miles and bought another trans and it went out again at the same amount of miles. My friend and a relative liked my Acura so much they bought the same car and their trans failed at varying mileages.
I guess I am asking if someone can summarize why they are actually replacing the transmission and what is mechanically defective? Is it just leaks? Have any issue surfaced on the 22’s ?
I decided to look at this car the same way I look at anything - if it's mechanical it can fail.
Ray
Just like the originator of the thread, I am here to learn and I appreciate when other people provide the detailed information they do. As others have mentioned, there is a larger sample size on the FB groups, so that's why I review them.
