Sponsored by: Wheel Design
LED Engine Lights
Old Apr 7, 2022 | 04:57 PM
DeeHutch's Avatar
DeeHutch
Default LED Engine Lights
What's everyone doing aftermarket for the LED engine bay lighting? It seems I recall someone getting good results from some Amazon Puck lights but I can't find that post....
Old Apr 7, 2022 | 05:05 PM
Zymurgy's Avatar
Zymurgy
Moderator
Here's a couple of DIY threads with different approaches:
DIY OEM Engine Appearance Lights
DIY Engine Compartment Lights with wiring instructions
These links can be found in the Manuals, Reference Material, FAQs, DIY Threads sticky thread.
Old Apr 7, 2022 | 05:36 PM
BLUEPSTU's Avatar
BLUEPSTU
I posted this in another thread. I used the small puck lights from amazon. Here is a pic installed as well as a pic on where I placed the lights. I also painted them black so they are not easily seen.
Old Apr 7, 2022 | 05:42 PM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
Yep there are wired DIY's BUT if you just want to use them occasionally as I do when someone askes "To see the engine" at night these work fine.
Can buy two for <$15 on Amazon. Mine are smaller thn some and waterproof. Can float in a pool. They use 3 AAA batteries 9which have lasted over a year.) Others a bit larger use AA and a smaller uses a small KEY FOB type battery. This is a How To PDF: http://netwelding.com/Engine_Lights.pdf
Old Apr 8, 2022 | 07:34 PM
bluman's Avatar
bluman
Old Apr 8, 2022 | 07:58 PM
Maxie2U's Avatar
Maxie2U
A direct link to the product on Amazon would be really helpful.
Old Apr 8, 2022 | 08:28 PM
syoungbe's Avatar
syoungbe
Pucks, batteries, remote controlled
Old Apr 8, 2022 | 09:43 PM
CP's Avatar
CP
Put these in right after I got the car and haven't used them EVAR. Car just isn't out at night at any shows. Plus, it's my DD and the engine bay is filthy.
Old Apr 9, 2022 | 06:01 AM
JerryU's Avatar
JerryU
It was well over a year ago but found them:
Amazon Amazon
Since Forum Vendors would not be selling these I included.
Always find it funny with Amazon as the same product is offered and source has in 1 and 3 quantiles and had to find this link which gave an option for 2! Guess being from China not surprising!
Worth clicking on the PDF as there is info on the double sided tape: http://netwelding.com/Engine_Lights.pdf
Old Apr 9, 2022 | 07:19 AM
SoCal C8's Avatar
SoCal C8
Livin the Life
2024 C8 of the Year Winner - Modified
I did the PowerLabs cable that uses the OEM engine appearance package lights. Seamless, no batteries, no remote needed….just push the rear defroster button. I added some orange Laminx film for the color over the lights.
Old Apr 9, 2022 | 07:29 AM
Corvette03051's Avatar
Corvette03051
Default Lights
Already purchased and they all worked well. I painted them black and am ready to install next week when my car comes. They work well using the remote in my garage. I don’t see why they won’t work in the car as long as you are close enough.
Old Apr 27, 2022 | 01:05 AM
RK43's Avatar
RK43
I just put these little pucks in and used that heavy duty scotch double sided tape. They’re really small about 1” diameter and 2 of them do the job pretty well. I like that they fit in the slots for the stock kit, they’re barely noticeable.
https://www.amazon.com/gp/aw/d/B07WHM1CFH?psc=1&ref=ppx_pop_mob_b_asin_image https://www.amazon.com/gp/aw/d/B07WHM1CFH?psc=1&ref=ppx_pop_mob_b_asin_image
Old Apr 27, 2022 | 06:38 AM
Corvette03051
Default Engine lights
Lots of us I chose mini lights from Amazon 10 lights including batteries with 2 remotes. Only used 2. Fir over the screw holes. Painted them black. Only about 1” in diameter.
Ok
Old Apr 27, 2022 | 07:06 AM
boblitzf's Avatar
boblitzf
just got a set, I liked the idea of painting them black, I will do the same. Do they come with with 2 sides tape?
Old Apr 27, 2022 | 08:42 AM
Corvette03051
Default Lights
No sir no tape. I suggest you get black tape because you may see the tape under the light. I ended up painting the tape edges.
Old Apr 27, 2022 | 09:21 AM
Triple Black 88's Avatar
Triple Black 88
I use battery operated strip lights and painted the housing black. They are attached with double sided tape. You can also change colors like the other LED's on the market.
Old Apr 27, 2022 | 09:25 AM
CorvetteOJ's Avatar
CorvetteOJ
I have posted this in a previous thread, but since the question came up again, here is my effort to light the engine compartment with LEDs. This is actually a strand of 8 individual lights designed for a pick up truck bed. I found them at O'Reillys Auto Parts. I simply wired them into the courtesy lights in the trunk. Attached with 3M double stick. They have been installed for almost 2 years, and continue to do their job.
To LED Engine Lights
Old Apr 27, 2022 | 10:47 AM
Strake's Avatar
Strake
2020 C8 of the Year Finalist - Unmodified
I did 4 strip LED lights mounted in the engine bay for evening car shows, etc..... They can change to about a dozen different colors and also change to the music if you choose, although I only leave them on solid RED..... Amazon... they were $9.99 when I bought them last summer.
https://smile.amazon.com/gp/product/...1?ie=UTF8&th=1
Attached one to each side rail near the engine, and 2 are on the back side facing forward towards the engine. All are powered off of a separate 12V small battery in the trunk so not even tied to the car's electrical system.
Old Apr 27, 2022 | 11:29 AM
Sullyvette's Avatar
Sullyvette
Used the same pucks, Put small round stickers on the LED lights. Courtesy of my grandkids. Then painted flat black and then removed the stickers that left a clean look. I then velcro'd them to the rear window. Hides their appearance a little more. FWIW
Old Apr 29, 2022 | 07:52 AM
Corvette03051
Default Lights
Velcro was a good idea however I used double sided with no problem either. Who knows maybe we r overthinking the sticky part of the equation! 😜 😂
