Sponsored by: Wheel Design
Rear view camera view
Old Apr 24, 2022 | 06:26 AM
Corvette03051's Avatar
Corvette03051
Default Rear view camera view
Please help!
When I look thru my rear view mirror camera I have double everything. Double roads as well as double cars behind me. I’ve tried all kinds of angles. It’s useless to me. I don’t know if it’s my eyes, camera or just the way it is. I suspect a defective camera. Help please!!!! BTW this is not a problem in my rear view camera it’s crystal clear
Old Apr 24, 2022 | 06:52 AM
LIE2ME's Avatar
LIE2ME
Veteran: Marine Corps
This is not normal. I believe a trip to your dealer is in order....
Old Apr 24, 2022 | 07:32 AM
Melvinne's Avatar
Melvinne
There are at least two other threads where members discuss the same or similar effects of seeing both the normal and camera via in the mirror:
https://www.corvetteforum.com/forums...-question.html
https://www.corvetteforum.com/forums...ew-camera.html
You might read through them and try some of the suggestions.
Old Apr 24, 2022 | 10:16 AM
StanNH's Avatar
StanNH
If you close one eye does the image appear correct? If so, there’s nothing wrong with the camera or mirror. If you still see double with one eye closed, it's a defect. Otherwise, your eyes will adapt within a short period of time.
Old Apr 24, 2022 | 10:37 AM
Corvette03051
Default Rear view mirror
ok so one eye works well should I drive with a patch over one eye all the time? 😂
Old Apr 24, 2022 | 10:38 AM
Corvette03051
Hi Lie
so it works well with one eye closed and I’ve been told in this thread then I’ll get used to it. Will I?
Old Apr 24, 2022 | 10:41 AM
Corvette03051
thx will do
Old Apr 24, 2022 | 11:09 AM
RKCRLR's Avatar
RKCRLR
With the lever pushed forward, adjust the mirror so you are looking at yourself; then pull the lever back. That is probably the best you are going to get.
If you like to occasionally use the real mirror, adjust the mirror so you can see out the back with the lever pushed forward and then pull the lever back. See if the view in the camera is acceptable.
Old Apr 24, 2022 | 11:19 AM
StanNH's Avatar
StanNH
Try a patch over both eyes.
Old Apr 24, 2022 | 11:21 AM
Foosh's Avatar
Foosh
After a lot of experimentation, I only use the camera mirror on multi-lane major highways for a better view of everything going on behind me. On small country roads, which surround our home, I stick with the mirror mirror.
Old Apr 24, 2022 | 11:30 AM
Corvette03051
Default Mirror
believe it or not driving much better with double patch 😂
Old Apr 24, 2022 | 11:32 AM
Corvette03051
Default Mirror
will do so why have this anyway it isn’t very good imo
Old Apr 24, 2022 | 11:38 AM
RKCRLR's Avatar
RKCRLR
It depends on one's vision and how they adjust the mirror. People with good near vision generally don't have a problem adjusting the mirror so they can see out the back and then pull the lever forward for the mirror view. I need to use reading glasses and the camera view is a little blurry for me without glasses. So I momentarily flip the lever forward when I want a clearer view.
Some people have no problem with the camera mirror.
Old Apr 24, 2022 | 11:51 AM
Foosh's Avatar
Foosh
It really is dependent upon an individual's eyesight. The best position for me is to adjust it to the best viewing position for the mirror only, and turn the camera on when I want to use it without changing the mirror position at all.
The observation about some folk's brains wired to adjust over time is accurate. For example, the Lasik procedure for fixing poor close-up vision is to correct one eye for that and leave the other alone for normal distance vision. The test for whether one is a good candidate for that procedure is to wear a contact lens in one eye for a day to see if your vision adjusts. Some people can't, and I was one of those. I couldn't see in focus either near or far with the contact in, and I have 20/20 distance vision.
Old Apr 24, 2022 | 12:48 PM
ignatz's Avatar
ignatz
I see you are retired. Suggest you visit a neural opthamologist. I'm 78 and can't quickly focus between the road and the mirror/camera. Have a slight case of double vision brought on by weak muscles in my eye. Prescription fix was simple, plain glass lenses with a slight prism angular offset. I mostly don't need them for driving but they do work. What also works for me without the glasses is a quick glance at the visor which is a little closer than the mirror. My theory is that helps with the refocus.
Old Apr 24, 2022 | 01:16 PM
Corvette03051
Default Mirror
at least I know I’m not broken will turn the mirror toward me for my first try
Old Apr 24, 2022 | 01:23 PM
Corvette03051
Default Mirror
To Rear view camera view
Old Apr 24, 2022 | 01:43 PM
Zormecteon's Avatar
Zormecteon
I've been wearing glasses since I was 22 months old. That's over 65 years and bifocals for over 60 years. It's as natural as walking to tilt my head to make things focus. That said, the camera (mirror) is nearly always out of focus...BUT
It doesn't matter. All one really needs is to get the impression of where the vehicles behind are located and the speed of their approach or recession. I don't need to read their license plate, I just need to know how close they are. ..
The double vision thing of OP would however be extremely distracting... I like the double eye patch solution, but to each their own..
Old Apr 24, 2022 | 03:23 PM
Corvette03051
Default Camera
Too bad we paid all that $$$ for a poor rear view I’m gonna try the double patch with a bag over my head for being taken on the necessity of a broken camera.
Old Apr 24, 2022 | 06:46 PM
Harry2's Avatar
Harry2
BTW, you have a coupe per your picture, with the HTC, the camera does not work when the top is down, which is the way I drive the vast majority of the time.
