Sponsored by: CARiD
Performance
Old Aug 19, 2019 | 10:44 AM
morepwr's Avatar
morepwr
It will depend on the aftermarket bringing parts to market but see username!
I never leave anything alone!
Old Aug 19, 2019 | 12:50 PM
bad mooofooo's Avatar
bad mooofooo
Modified C8 of the Year 2021 Finalist
Originally Posted by Callaway Chris
We plan on modifying ours.
Old Aug 19, 2019 | 02:09 PM
NineVettes's Avatar
NineVettes
Yes and given the new GM "Sanctum Santorium" by combining Global B with the ZR1 ECU plus the DCT, I would expect that you and perhaps Katech will be among the very few "blessed" by GM.
Old Aug 19, 2019 | 08:04 PM
MikeyTX's Avatar
MikeyTX
Veteran: Marine Corps
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Originally Posted by Joefab
High flow extra large catalytic converters should liberate another 20hp and sports car sound in a simple bolt-on
As long as they don't throw codes ..............
Old Aug 22, 2019 | 02:41 PM
ProfessorDeath's Avatar
ProfessorDeath
St. Jude Donor '13-'14
If the ECM is as difficult to access and well-encrypted as GM wants us to believe, Modding may be pointless if we can't get a decent tune out of it.
Old Aug 25, 2019 | 10:35 PM
JerriVette's Avatar
JerriVette
Acceleration of c8 is so strong the only modification needed is driver training ..
jmo
Old Aug 26, 2019 | 10:21 AM
Tripjammer's Avatar
Tripjammer
They will crack it but its going to be expensive to tune the C8 at first.
Old Aug 26, 2019 | 10:22 AM
Tripjammer's Avatar
Tripjammer
The only way to increase power is to reduce exhaust back pressure and pumping losses of the intake and exhaust. High quality 200 cell sports race catalytic converters should liberate another 20hp with no check engine lights and more gutsy sports car sound. A lightweight highflow x pipe with valves should add more power and save a lot of weight off the rear of the c8. After that an Ecu tune is a possibility.
That is what I am thinking do the "BASIC" stuff before you break into the turning and the Twin Turbos...
Old Sep 3, 2019 | 11:27 PM
alnoe's Avatar
alnoe
CNC ported heads and camshaft package. Unless the factory cylinder head is really, really good.
Old Sep 4, 2019 | 11:48 AM
thrilled's Avatar
thrilled
Mine is waiting for the Z06 or ZR1.
Old Sep 4, 2019 | 12:10 PM
Halltech's Avatar
Halltech
Supporting Vendor
St. Jude Donor '09
Originally Posted by Shaka
The only way you get less restriction is with less filtration. Can't beat OEM filters. Also, applying oil to the K&N filter, voids the warranty.
That is simply untrue. If putting a K&N filter on your car voided the warranty, GM would be in violation of the Magnuson-Moss Federal Law. They can only do that if they insist on you using their filter and make it free of charge at regular intervals. In 21 years of business, we have NEVER had a claim or incident of the type you refer to.
In addition, Commission staff has recently issued a number of guidance documents to better educate consumers and businesses concerning their rights and obligations under the MMWA. For example, in order to cure perceived misconceptions in the marketplace, staff issued and recently updated a consumer alert stating that the MMWA prohibits warrantors from voiding an automotive warranty merely because a consumer uses an aftermarket or recycled part or third-party services to repair one’s 1 76 FR 52596 (Aug. 23, 2011).
__________________
"World Class Performance for your Corvette"
Intake Design and Engineering since 1999
Halltech Systems, LLC
423-915-6056
For service email:
orders@halltechsystems.com
www.halltechsystems.com
Old Sep 4, 2019 | 01:31 PM
shiftdown's Avatar
shiftdown
To start, something like kooks long tubes, an intake, and maybe a 150 wet shot. Then sit quietly and wait for HP tuners to crack it loose for forced induction.
Old Sep 4, 2019 | 04:25 PM
  #33
lgodom's Avatar
lgodom
I talked to Josh at the NCM last weekend, and he said it's a 12 volt system that has 22 or 24 modules. Each of these modules is encrypted with code hopping, similar to your garage door opener. He said it's not going to be accessible with existing software. He did say that GM hasn't finalized anything, but is reviewing possible ways to work with the aftermarket in allowing tuning that wouldn't void the entire warranty if aftermarket programming is done. Hope this happens, but he didn't have any more information.
Old Sep 4, 2019 | 08:56 PM
  #34
quick04Z06's Avatar
quick04Z06
Originally Posted by Race Prepared
The C8 Corvette will have “Global B” 48 volt based electrical system.
Tadge said at NCM it is still 12 volt. Does have new architecture.
Old Sep 4, 2019 | 10:16 PM
  #35
24/Eray's Avatar
24/Eray
Translation: "Buy the C8.. we will allow you to tune it eventually... just buy it... don't worry you can mod it one day... we promise... we pinky swear"
Old Sep 4, 2019 | 11:51 PM
  #36
shiftdown's Avatar
shiftdown
I'm fine with voiding the warranty as long as it's tuneable. If I'm slapping turbo's on there, I wouldn't expect them to honor any powertrain or drivetrain. Maybe if the interior falls apart in a year, I may complain.
Old Sep 5, 2019 | 09:05 AM
  #37
jvp's Avatar
jvp
"Ask Tadge" Producer
If everyone were as honest as you, GM wouldn't need to work so hard at making the modules uncrackable. They could slap a big "Tune at your own risk!" sticker on the modules and be done with it. But unscrupulous folks (and there are a ton of them right here on CF) will try to reverse the tune if something breaks and then attempt a warranty claim.
