Sponsored by: CARiD
The C8 launch control zero to sixty timed
Old Sep 4, 2019 | 09:13 PM
24/Eray's Avatar
24/Eray
Default The C8 launch control zero to sixty timed
i tried my best.. a little lazy at the start and a little quick on the stop and then vice versa lol.. need another set of hands!!
if 56mph is the top of 2nd, then the 2/3 completed shift should be 60 with momentum.. to pull a real sub 3 second in the street will be tough on those tires as i gave it much more than even a 3ft rollout on the low 3 and the 2.95.. but this was only one launch. was just surprised by the amount of wheelspin. was similar to that video of the blue one on the street taking off without the launch control.
Old Sep 5, 2019 | 03:43 AM
ZeeOSix's Avatar
ZeeOSix
There is obviously tire spin (squealing) at the start. My bet is with ideal traction it will be around 3.0 sec +/- 0.1.
Old Sep 5, 2019 | 01:34 PM
NW-99SS's Avatar
NW-99SS
2022 C2 of the Year Finalist - Modified
Make sure you factor in the speed of sound since you are basing the speed of the C8 on the sound of the shifts the DCT is making.
The mic reference in timing needs to be adjusted for the amount of time required for the sound to travel from the C8 to the mic at the time of the 2nd shift.
Old Sep 5, 2019 | 03:43 PM
Bill Dearborn's Avatar
Bill Dearborn
Also other than having a certain speed when the shift occurs momentum doesn't provide any additional acceleration. For the short period of time that engine torque isn't transferred to the rear wheels during the shift the car is coasting and actually dropping in speed.
Bill
Old Sep 5, 2019 | 04:22 PM
CaptainFalcon's Avatar
CaptainFalcon
Bill
If this Chevrolet video is to be believed this may not be entirely true. Unless I'm missing something, it sounds like they are driving power through both clutches at the same time during shifts, at least on "aggressive launches". So second gear isn't stopping power delivery until third gear has already started delivering power which basically makes the shift time moot since there is a seamless delivery of torque during acceleration despite the gear change. Not sure if this also happens on the 1-2 or 3-4, 4-5 etc shifts, but 2-3 is mentioned. Again, this is a Chevy video so take that for what it's worth.
Old Sep 5, 2019 | 04:56 PM
JazzVA's Avatar
JazzVA
Since it a DCT an in two gears simultaneously how does the change in engine sound relate the gear change at all?
Old Sep 5, 2019 | 05:32 PM
NW-99SS's Avatar
NW-99SS
The RPMs drop with every upshift...just like any other transmission with gear ratios.
Old Sep 5, 2019 | 11:18 PM
fatsport's Avatar
fatsport
https://www.youtube.com/watch?v=k0FjkvFQcso
This is brilliant engineering if true. Looks like GM wanted the 2-3 shift before 60 mph to improve the 0-60 time. Putting power through both clutches.
Awesome stuff! (And I’m a manual transmission fan)
Old Sep 25, 2019 | 10:37 AM
Commandercorvette's Avatar
Commandercorvette
I was a manual guy for 20 years , then I was an auto guy . I'm now a DCT guy !! When can I get this for my 7 second drag car ??
Old Sep 25, 2019 | 12:26 PM
The HACK's Avatar
The HACK
That's insane if true, because you can't spin both gears at the same engine speed simultaneously.. If both clutches are engaged for the 1/10th of second that it takes for the mechanism to select between each gear, the clutch for the higher gear will be slipping for that 100 millisecond every time you shift. Maybe that's why the gear ratios are so close, as to keep the difference in engine speed to gear spin ratio as low as possible to minimize slip and wear.
That clutch pack better be the most robust clutch pack, or a wet clutch setup (dry clutch is superior*), or both to last the duration of the warranty.
Old Sep 25, 2019 | 02:51 PM
ZeeOSix's Avatar
ZeeOSix
It is a wet clutch pack design.
Old Sep 29, 2019 | 05:09 PM
Wyldfyer's Avatar
Wyldfyer
https://youtu.be/l27X0NSMk_s
Isnt this just a video they released as they tried launch control a few times? Or is this an official video with claims of under 3 seconds?
Old Sep 30, 2019 | 05:45 AM
usrodeo4's Avatar
usrodeo4
lol...yeah that's why guys run a 4.39 40 on a hand time then a 4.55 on an electronic timer. Being ME and with the low 3.80:1 Z51 rear end and the special attention chevy gave the Z51 DCT gear spacing she will have a very good 0-60 time but w/o a rolling start (MT actually allows a 1 mph rolling start in their "0-60" times), no way she will be under 3 seconds....the Ferrari F8 is 710 BHP and she is a 2.8 or 2.9 sec 0-60 car...my 2 cents anywho.
Old Sep 30, 2019 | 09:18 AM
Wyldfyer's Avatar
Wyldfyer
^^^ That would be false advertising then. You think GM is going to start off with lawsuits?
Honestly, I'm good with 1-60 mph in less than 3 seconds either way lol. That would actually be better to have legal fun.
Old Sep 30, 2019 | 01:11 PM
Fore58's Avatar
Fore58
What about the other cars that you had mentioned did MT did start those on a roll or any other magazine? I do get your point......it should be a fair time
Old Sep 30, 2019 | 05:20 PM
Red Mist Rulz's Avatar
Red Mist Rulz
MT calculates the time from 1 mph on all their test cars, not just the Corvette.
Old Oct 1, 2019 | 12:09 AM
PRE-Z06's Avatar
PRE-Z06
No launch control, still seems quick...
View this post on Instagram
To The C8 launch control zero to sixty timed
Old Oct 3, 2019 | 10:05 PM
24/Eray's Avatar
24/Eray
Just make sure you stay at sea level.... because that was one very slow run to 100 lol. Bring on the FI powerplant... quick.
Old Oct 4, 2019 | 11:24 AM
carlsturm's Avatar
carlsturm
Resetting post to //Sarcasm <Off>
Old Oct 4, 2019 | 10:44 PM
PRE-Z06's Avatar
PRE-Z06
It’s slower than my old run in C5 that made a little over 400rwhp in video below which I figure should be similar to what a C8 runs in optimal conditions, so if the disclaimers are true then it makes sense...
