Sponsored by: CARiD
C8 weight thread
Old Mar 17, 2020 | 10:55 AM
Dane@LGmotorsports's Avatar
Dane@LGmotorsports
Premium Supporting Vendor
Default C8 weight thread
As we take the car apart and weigh different items I'll update this original post with our findings.
Brakes
Parking Brake (Pair) 12.7 lbs
Rear Rotors (Pair) 45.2 lbs
Exhaust
Muffler 76.25 lbs
Catalytic Converters (Pair) 26.45 lbs
Headers/Manifolds (Z51) (Pair) 24.85 lbs
Heat Shielding 15.30 lbs
Interior
Carpet/Insulation Behind Seats 16.15 lbs
Wheels
Front Wheel w/ Tire 52.20 lbs
Rear Wheel w/ Tire 67.95 lbs
Popular Reply
Mar 18, 2020, 10:25 AM
Dane@LGmotorsports
Originally Posted by Z06zilla
Dane, can you please post the corner weights?
Thank you
Old Mar 17, 2020 | 12:38 PM
stevebz06's Avatar
stevebz06
How much do the seats weigh?
Old Mar 17, 2020 | 01:02 PM
Dane@LGmotorsports
Seats will come out at the end of the week when we get our new axles here and get the car off the lift.
Old Mar 17, 2020 | 09:58 PM
mikey's Avatar
mikey
Reducing weight will be where I spend my money whenever the heck I actually get my car! Looking forward to seeing what options are developed.
Old Mar 17, 2020 | 10:05 PM
BrunoTheMellow's Avatar
BrunoTheMellow
Gspeed just posted 3625 lbs with full fluids. Damn near Camaro SS 1LE weight (+60 lbs) with 40 mm less tire and 1" less brake rotor on each front corner. That's gonna be tough on consumables.
Old Mar 17, 2020 | 10:42 PM
Dane@LGmotorsports
Yeah ours was 3,538 on an empty tank
Old Mar 18, 2020 | 10:22 AM
Z06zilla's Avatar
Z06zilla
Thank you
Old Mar 18, 2020 | 10:25 AM
Dane@LGmotorsports
Thank you
Old Mar 18, 2020 | 04:40 PM
stevebz06's Avatar
stevebz06
This is with no driver?
Old Mar 18, 2020 | 04:41 PM
Dane@LGmotorsports
No driver on empty.
Old Mar 18, 2020 | 05:54 PM
PRE-Z06's Avatar
PRE-Z06
Not to high jack the thread, but what did your supercharged C7 weigh or current C7Z06 with a full tank?
Old Mar 18, 2020 | 06:20 PM
Dane@LGmotorsports
I can't remember off hand it's been a while since I've had to put a shop car on the scales.
Old Mar 18, 2020 | 07:23 PM
BrunoTheMellow
C7z weighs about 3550 full tank. So the c8 z51 is 75 lbs heavier. Pooooooorky.
Old Mar 18, 2020 | 07:30 PM
jrhoades's Avatar
jrhoades
What's the car's spec (1, 2, 3LT)? Does it have front lift?
Old Mar 18, 2020 | 08:44 PM
PRE-Z06's Avatar
PRE-Z06
It is heavy for being NA and guess the gain from C7Z51 to C8Z51 is greater than C6Z51 to C7Z51 was, so not trending in the right direction.
Old Mar 19, 2020 | 10:55 AM
Dane@LGmotorsports
2LT Z51 no front end lift
Old Mar 20, 2020 | 07:46 AM
ZishanM's Avatar
ZishanM
Gspeed car has front end lift, that might be another variable for weight difference
To C8 weight thread
Old Mar 31, 2020 | 06:53 PM
Dane@LGmotorsports
Old Mar 31, 2020 | 08:10 PM
BrunoTheMellow
For reference. A nickel plated c7z wheel weighs 63.5 lbs with a 335/25r20 runflat.
Old Apr 1, 2020 | 08:48 AM
Shaka's Avatar
Shaka
Thanks. Can you jack the back up as high as you can while on the scales. Record load transfer. Measure the angle or height difference difference at the axle. You can calculate the exact location of the CG. Give me the numbers and I will do it. All chassis tuning starts at this point.
