Sponsored by: CARiD
Engine service
Old Mar 23, 2020 | 06:54 AM
EnglishRebel's Avatar
EnglishRebel
Default Engine service
I wonder if a major service will require the engine to be removed like on the Ferrari 355. I know my Ferrari 360 had the removable cover behind the seats so the front of the engine could be serviced. I've not seen any photographs or drawings of what the access to the front of the engine is like. Anyone know? Techs maybe?
Alan
Old Mar 23, 2020 | 07:47 PM
ChiTownVetteTech's Avatar
ChiTownVetteTech
There is no regular maintenance that’ll require engine removal. GM doesn’t really have a major service like the Ferrari. No timing belts on the small block. Now if you need an engine repair then the engine will come out. Belts,hoses,ac and alternator, plugs wires and coils all are accessible.
Old Mar 23, 2020 | 08:12 PM
mikey's Avatar
mikey
Why do you wonder this? Are you doing the work?
either way, I’d rather work be done out of the car and not leaning over the fenders risking body damage. And ensuring all bolts are properly torqued not half assembled due to difficult working positions.
Old Mar 27, 2020 | 12:28 PM
EnglishRebel
No, just interested that's all.
Alan
Old Apr 3, 2020 | 09:27 AM
C7&7's Avatar
C7&7
For just about every performance upgrade it will have to come out... well most defiantly heads and cam. Which I suppose isn't that much different from the C7. Alot of shops just removed the motor to work on it easier.
Old Apr 6, 2020 | 02:41 PM
Bill Dearborn's Avatar
Bill Dearborn
Nothing on the front of a GM V8 that needs servicing other than if it breaks. There is no timing belt but there is a timing chain. Most timing chains last well past 100K miles. My 03 Tahoe with 125 K miles hasn't had any major service done on it. Change oil when OLM says to, change coolant and plugs per GM OM directions. It is my tow vehicle and has seen at least 50K miles towing a trailer with a Corvette. Have been driving for 62 years and have noticed that most domestic cars require very little service. The nature of the US Customer who doesn't like taking a car in for service for any reason.
Bill
Old Apr 8, 2020 | 04:36 PM
c2vette64's Avatar
c2vette64
According to latest SAE Automotive Engineering, the engine/transaxle needs to be dropped to replace the FEAD belt(s). Likely not until 100,000 miles though and maybe not that difficult to drop the engine/transaxle. Still not a 15 minute job though. Are they incorrect?
Old Apr 8, 2020 | 04:44 PM
ChiTownVetteTech
According to GM published procedure, yes they’re wrong.
Old Apr 8, 2020 | 06:20 PM
c2vette64's Avatar
c2vette64
Wow, surprising, they must have figured it out after the article went to print. According to author John Sherman, it had "thus far stymied engineers" (changing belts without dropping engine/transaxle).
To Engine service
