Advice please - floor jack for C8
https://zl1addons.com/products/jack-...75a232f1&_ss=r
I have 3 low profile, light weight floor jacks in the garage (they actually can be stored on on top of the other if you choose - taking very little space).
I'd typically lift one end from both sides (e.g. front-left and front-right) with 2 jacks using pucks, to keep the car level side to side. Then I'd put the above safety stops, keeping the jacks under hydraulic tension just as high as needed to fit the safety stop. I would also have the third jack as an extra safety just touching a strong (center) component (but a block would work as well).
So, for the thing to come down the hydraulic of 2 jacks, plus the metal safety stop would have to fail. I'd say that is good enough.
At track side, I'd borrow 2 jacks from friends and use the metal safety stop, just would be extra careful with body parts under the car while changing pads (typical work at track side).
Hope this helps. It has worked well for me, and it is reasonably safe for vehicles where you can't easily put a jack stand under.
P.S. Incidentally on my 3-ton Jeep, I also use a hydraulic/jack stand combo (since I have the clearance for it). On the Vette I guess you could drive it on a ramp that use the same - but never tried. I don't like ramps
Bill
I would like to have one that I could use on both a C8 as well as our Honda Pilot. I have not purchased anything yet, but with the fact that the lifting points on the C8 are not parallel, front to back, that would mean that to hit the lifting points the two side pieces would be wider at the front of the car than the back. Would that matter with the lift?
Also, one of the first projects would be to install my 5VM Aftermarket C7 Carbon side skirts and front splitter. The side skirts obviously attach to the rockers..... Would the QuickJack lift be in the way of the rockers???
Does anyone know the distance between the lifting points front to back. The lift point spread for this 7000 model is 60" max. The minimum is 31.5".
https://www.midenginecorvetteforum.c...l-work-with-c8
Make sure to read through it as the info changes as people validated.
The standard length 7000 should be fine, as it's the same as the 5000 SLX...... 70" long.
I too would like to get the heavy duty 7000 EXT for my future C8 ZO6. Like many here, I have numerous vehicles. I have a C2, C3 C5, C6 and a Dodge SUV. My Son also has a Big Silverado. If I get the 7000 and it will fit under all the cars, WHY NOT spend the extra cash and have a better more robust lift with more flexibility. Seems like people are afraid or do not want to answerer that question.
I have askes Quick Jack numerous times this question but they will NOT answer it!!
QUESTION~ What is the maximum angle that a floor or drive way surface can be to safely use a Quick Jack?
I'm sure that there Lawyers passed out when they saw that question!!
Bill C
1. If you lower there is less clearance
2. If you use pucks there is less clearance.
I am still debating quickjack vs 4 post 2 point. The 4 post 2 point costs about the same as quick jack and isnt portable.
But quickjack likely won't work on a 4 post... maybe?
If I knew I could use my quick jack on a lower to the ground 4 post... it would be an easy decision.
My normal MO, when going to a dealer or tire shop for service is to put 4 jack pads in a clear plastic bag on the passenger seat and instruct the service writer to be sure they are used. However also understand that "message" may not get to the Tech AND Techs don't want to take the extra time or DON'T believe they are needed. So my current thought is to either: 1) bolt in my 4 Reverse Logic Jack Pads or 2) if the 9/16 inch high, Red Permanent Aluminum pads clear the C7 Carbon Side Skirts I have on order, to buy those for ~$40.
The permanent jack pads are cheap insurance the Tech will have a higher probability of getting jack arms on a two or center post lift in the correct location. Like the red color as when bending down to place the lift arms, easier to see! That assumes they will bend down, have watched techs at the local Chevy Dealer kick lift arms to locate with the feet! Works for the trucks and most cars they work on- why not this Corvette?
For my garage use, two jack pads, two jacks and if the back and front (or one side) needs to be lifted I'll use my wheel stanchions under two wheels. If just changing brake pads (as I plan to install low dust ones as soon as I get the C8 home) I'll jack one wheel at a time and for security install a jack stand under that lower 'A" arm.
But I know alot of people who don't.
