Sponsored by: CARiD
Launch control
Old Jun 2, 2020 | 06:04 PM
rrigia's Avatar
rrigia
Default Launch control
I am one of the lucky ones to have my C8 and love it.
1. Does my car have to have Magnetic Ride Control in order to use Launch Control?
If not here is what I have read:
1. Put car into Track Mode
2. Double tap the Traction Control button
3. This brings up the Performance Traction Management menu on the driver's display.
4. Select Wet,Dry, Sport, Sport 2 or Race.
5. Engage the Brake
6. Floor the gas pedal
7. When 3500 rpm is reached let go of the brake.
8. Does the computer stop the rpm's at 3500?
I would appreciate an answer(s) on this.
I
Popular Reply
Jun 8, 2020, 12:18 PM
E.T.D. Corvettes's Avatar
E.T.D. Corvettes
C7 & C8 Events Correspondent
2020 C8 of the Year Finalist - Unmodified
2020 Corvette of the Year (track prepared)
C7 of Year Winner (appearance mods) 2019
2017 C7 of Year Finalist
2015 C7 of the Year
St. Jude Donor '14-'15-'16-'17-'18-'19
I talk about the process in my video on this topic...
Old Jun 2, 2020 | 06:06 PM
Dane@LGmotorsports's Avatar
Dane@LGmotorsports
Premium Supporting Vendor
That looks correct. I've only done it selecting race, haven't tried any others. Computer will stop it at 3,500. Make sure you press hard on the brake pedal or it won't work.
Old Jun 2, 2020 | 06:10 PM
rrigia's Avatar
rrigia
Thank you very much. This helps me greatly.
Old Jun 3, 2020 | 09:46 PM
skvette's Avatar
skvette
Cruise-In VIII Veteran
If you do not have Magnetic Ride like my car you will see Competitive Driving Mode after the double tap of the Traction Control button. This will allow for launch control. I just used it today 3.2 seconds to 60 with a passenger. Best time so far is 2.7 with driver only. You really need to mash the brake it to kick in.
Enjoy.
Old Jun 8, 2020 | 12:18 PM
E.T.D. Corvettes
2015 C7 of the Year
Old Jun 8, 2020 | 01:34 PM
rrigia's Avatar
rrigia
Default Launch control video
This was an outstanding and informative video!
Thank you
Old Jun 8, 2020 | 01:44 PM
E.T.D. Corvettes
2015 C7 of the Year
Thank you
Glad it was helpful...thanks!
Old Jun 8, 2020 | 01:52 PM
RapidC84B's Avatar
RapidC84B
https://youtu.be/JyJE1ykfgvQ
That was informative... let me make sure i have it right.
1. In sport mode you hit TCS button 2X in close succession and it will enter a generic track mode w/o PTM and launch control works?
2. In track mode you have to enter PTM to enable launch control?
Old Jun 8, 2020 | 02:19 PM
E.T.D. Corvettes
2015 C7 of the Year
Thanks...yes, you are correct on both.
Old Jun 10, 2020 | 08:10 AM
rrigia's Avatar
rrigia
For some reason I can't hit 3500 RPM ! it stops at around 2000RPM.! Track mode and 2 X TCS button.
Last night i tried it again and had my brake depressed as much as possible and had the gas pedal floored.
Now I do not have the Z51 so does this matter?
Also, when I tried the same sequence in sport mode the car fishtailed unlike when I have it in Track mode.
Old Jun 10, 2020 | 10:33 AM
E.T.D. Corvettes
2015 C7 of the Year
I assume you have more than 500 miles on the car?
Mine wasn't going to 3500 at first because I wasn't pressing the brake down hard enough. But if you're not in the correct mode for launch control, it won't rev very high either. Check the following to see if there's anything you're missing...
From the owners manual...
Launch Control (Sport and Track Mode Only) A Launch Control feature is available, within Competitive Driving Mode or PTM, on all vehicles to allow the driver to achieve high levels of vehicle acceleration in a straight line. Launch Control is a form of TCS that manages tire spin, and transmissions clutch, while launching the vehicle. This feature is intended for use during closed course race events where consistent zero to 60 and quarter mile times are desirable. Launch Control is only available when the following criteria are met: . Competitive Driving Mode or any of the PTM Modes are selected (if equipped). . The vehicle is not moving. . The wheels and steering wheel are pointing straight. Launching the Vehicle . Ensure the vehicle is in Competitive Driving Mode or any of the PTM modes. . The brake pedal must be firmly pressed to the floor, equivalent to a panic brake event. . While maintaining the brake pedal, the accelerator pedal is rapidly applied to wide open throttle. (If the vehicle rolls due to wide open throttle, release the throttle, press the brake pedal more firmly, and re-apply the accelerator to wide open throttle.) The Launch Control feature will initially limit engine speed as the driver rapidly applies the accelerator pedal to wide open throttle. Allow the engine rpm’s to stabilize. A smooth, quick release of the brake pedal, while maintaining the fully pressed accelerator pedal, will manage tire slip and transmissions clutch. After the vehicle is launched, the system continues in Competitive Driving Mode or PTM. Competitive Driving Mode, PTM, and Launch Control are systems designed for a closed course race track and not intended for use on public roads. The systems are not intended to compensate for lack of driver experience or familiarity with the race track. Caution The new vehicle break-in period should be completed before using the launch control feature, otherwise performance will be limited and damage may occur to the powertrain/engine. See New Vehicle Break-In 0 162.
Old Jun 10, 2020 | 01:04 PM
rrigia's Avatar
rrigia
Thank you
Yes, I do have 1700 + miles.
Old Jun 18, 2020 | 08:37 PM
Shinobi'sZ's Avatar
Shinobi'sZ
Cool vid. Thanks
Old Jun 21, 2020 | 11:10 PM
skvette's Avatar
skvette
New low 0-60 using launch control .....
Old Jun 23, 2020 | 10:12 PM
DAKING's Avatar
DAKING
Really hard on the break
Old Jun 23, 2020 | 10:48 PM
E.T.D. Corvettes
2015 C7 of the Year
Great! Almost no fuel in the tank sure helps it seems.
Old Jul 4, 2020 | 10:56 AM
StickerDick's Avatar
StickerDick
I do not have a Z51 package, I do have 2LT, so does the "standard" C8 still have the ability to do Launch Control?
To Launch control
Old Jul 4, 2020 | 05:24 PM
rrigia's Avatar
rrigia
Thank you and have a great 4th!
Old Jul 6, 2020 | 11:42 AM
E.T.D. Corvettes
2015 C7 of the Year
Yes, you can do it in Sport or Track.
Old Jul 7, 2020 | 10:51 AM
Toilets's Avatar
Toilets
If your car is at all modified please be careful using launch control. My wife was driving the car and tried launch control and we snapped an axle on the street. Because it was modified with Headers, GM denied the warranty claim on it and we had to front the bill.
