Sponsored by: CARiD
Rotate Michelin PS4?
Old Oct 14, 2020 | 10:55 AM
CZS's Avatar
CZS
Default Rotate Michelin PS4?
It doesn't appear to me (or a quick Google search) that these tires are directional. Can anyone confirm that? Anyone swap the left and right tires occasionally to 'rotate' them?
Old Oct 14, 2020 | 02:20 PM
Sunwarrior's Avatar
Sunwarrior
If no arrows on outside of tire that shows rotation only direction, you are able and safe to rotate.
Old Oct 14, 2020 | 05:00 PM
RussM05's Avatar
RussM05
Not directional but can rotate right to left side only. Front and rear tires are different sizes.
Old Oct 14, 2020 | 05:09 PM
CZS's Avatar
CZS
Yep, that's exactly what I was planning. Just surprised that no one seems to discuss/mention it. I'd have to think it would yield a little improvement in tire life...
Old Oct 15, 2020 | 02:06 PM
MitchAlsup's Avatar
MitchAlsup
Even unidirectional tires can be rotated as long as there is no rain.
I used to run 1/2 day at MSR Cresson and then flip the tires side to side to even out the wear. I did not bother to flip the tires back until after I got home (180 miles).
Old Oct 17, 2020 | 04:16 PM
Arrowsigns's Avatar
Arrowsigns
Without rotating I got 14K miles out of my last set PS4S. Yes different car but tire is great and lasts comparing to the previous gen SS.
Old Oct 22, 2020 | 08:59 PM
c5racr1's Avatar
c5racr1
Tire says outside on it
Old Oct 24, 2020 | 11:17 AM
CPhelps's Avatar
CPhelps
If you rotate side to side the outside will still be on the outside, but it will rotate the opposite direction. So if the tread is not directional, then no issue.
Old Oct 25, 2020 | 07:03 PM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
Yep as with the C7 that said OUTSIDE they can be swapped side to side. That means they are asymmetrical with the outside and inside tread different (usually width and can be tread compound and side wall reinforcement.
There are tires that are asymmetrical and directional. They usually also have an arrow AND some say Left or Right and Outside as they can only be used on that side of the car. Have had those and they cannot be swapped side to side.
Page 260 of the Owner's Manual states:
Tire Rotation The tires should be rotated every 12 000 km (7,500 mi).
To Rotate Michelin PS4?
