Sponsored by: CARiD
Does anyone know???
Old Nov 4, 2020 | 07:45 PM
CP's Avatar
CP
Default Does anyone know???
In the various DCT vids they always say to not creep the car, like when stuck in traffic. Does anyone know the slowest car speed for full clutch engagement in first gear?
Old Nov 5, 2020 | 09:35 PM
Avanti's Avatar
Avanti
"...not creep the car." Good grief, who cares... really? DRIVE the thing just as you would anything else.
Old Nov 6, 2020 | 12:05 PM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
When I first got the car drove mainly in Manual Mode. Did not like that clutch slipping feeling as I came to a stop so pulled both paddles and disconnected both clutches while it was in 2nd or 3rd as I approached a red light. Then would keep the right paddle pulled until close to a green light.
BUT now I have found a great was to set Z MODE that makes it a different car. I have Steering, Brakes, Ride set to my normal Sport BUT Power set to Track. In Track: 1) as in Manual Mode it never goes into V4, 2) shifts at a higher rpm when accelerating even modestly, 3) seldom goes past 5 gear up to ~65+ mph and 4) Down shifts starting at a higher rpm when braking. So I can be in Drive mode and have it perform as I drove my two C7s and when using Manual Mode.
I now "live with the modest clutch slipping" when going slow in 1st. Tadge said it will not cause excessive wear. It is the outer, larger of the two clutches. But as I pull into my tight garage it's a bit jerky as the clutch slips and grabs. Not a big deal.
Old Nov 8, 2020 | 12:28 PM
CP's Avatar
CP
Obviously you've never driven in commuter rush hour traffic or tried to leave a concert venue parking lot.
Old Nov 8, 2020 | 02:33 PM
Red Mist Rulz's Avatar
Red Mist Rulz
When the car was introduced, GM said the transmission is designed to creep a little bit, so it feels like a normal automatic It has multi-plate wet clutches that you're not likely to ever wear out. Just drive it.
Old Nov 8, 2020 | 04:47 PM
JerryU's Avatar
JerryU
I don't agree! If in bumper-to-bumper traffic (something for the last 35 years I very seldom have to do when at home) and expect it to operate like a "slushbox" you'll be upset as some have posted!
My suggestion is what I did with my standard shifts in that situation (I have only had standard shifts for DD's in 60 years until the C8, many times in areas where there was that foolish traffic!) You don't move to stay on the car it fronts bumper at a creep. Wait a car length or two then move (except when in NYC where some AH will try to move in so you leave a maximum of 3/4 of a car! ) BUT don't just apply moderate brake pressure as you would in a car with a torque converter and "creep" the car forward! Yep the C8 DCT is slipping the 1st gear clutch slightly and it's not the smooth (inefficient) power transmission of a "Slushbox!" So leave a car length or so then release the brake don't ride it! At least that is what I would do and NOT be frustrated as some have posted. It's not a specific mph, it's a feel for that slipping clutch engaging and disengaging as you move forward!
Old Nov 8, 2020 | 08:16 PM
CP's Avatar
CP
All I see from Chevy is "trust me". Yeah, riiight. What have you done to earn my trust?
Old Nov 9, 2020 | 12:28 PM
Racer X's Avatar
Racer X
Whatever 600-700 rpm equates to in first gear with the options you have.
Old Nov 9, 2020 | 12:40 PM
JerryU's Avatar
JerryU
Good way to look at it as far as a mph number. Extrapolating from data I have for 10 mph in 1st for 650 rpm that would be ~3.5 mph in my Z51. Below ~3.5 mph the 1st gear clutch (also for 3rd, 5th, & 7th) will slip. If slower it will feel somewhat jerky going from slipping to engaging!
Funny, I'm participating in a Covid Test Program for SC (I don't have any issues.) Was in line this morning waiting to be tested. I waited until the car in front was ~1 1/2 car lengths ahead, then took it out of Park, engaged Drive then back to Park when I was close to the bumper of the car in front! Was not going to modulate the brake pressure and have that "poor clutch" slipping!
Old Nov 9, 2020 | 01:05 PM
Shaka's Avatar
Shaka
If your foot is off the brake, the clutch will slip just above idle while creeping. If you are stationary with the brake on or below idle, the clutch is dis engaged otherwise it is not. No DCT is comfortable in very slow traffic, hence the very low gearing in the C8. Keeping clutches engaged partially, like any clutch system, will cause premature wear. Think manual clutch and drive a DCT accordingly. That's why there is a clutch temp gauge for this abuse. Slush box clutches don't slip, the torque converter is the clutch. Drive it as though it was a manual xmission. If you don't have the brake on, pull both paddles to prevent slipping. So creep with the gas pedal, and immediately pull the levers to coast or hit the brake. Left foot on the brake is easier.
Old Nov 9, 2020 | 02:06 PM
JerryU's Avatar
JerryU
Yep, drive like I did in bumper to bumper traffic with every DD I had for 60 years that all had a 3rd pedal (before my C8.) Let the car in front get 1 1/2 to 2 cars ahead then move forward and wait for another 1 to 2 car gap. That works except in NYC or Miami etc where can't leave more than 3/4 of a car length if there are cars in a lane next to you! Someone will surely cut in to gain one car length!
Glad I've lived in Eastern SC for 35 years where we don't have that silly traffic. Lots of farm fields and back roads for my 20 mile trip to town!
Old Nov 10, 2020 | 01:20 PM
iKonPerformance's Avatar
iKonPerformance
I creep my car all the time without any issues. That what ends up happening in traffic so I wouldn't worry too much about it.
Old Nov 12, 2020 | 10:55 AM
Shaka's Avatar
Shaka
You can only do that if you don't know how it works or you don't respect machinery. If the clutch reaches a certain temperature, the car will be disabled 'till it recovers. There will be an indication on the dash.
To Does anyone know???
