Sponsored by: CARiD
Porting throttle body or intake manifold?
Old Jan 13, 2021 | 01:39 PM
jimbob8915's Avatar
jimbob8915
Default Porting throttle body or intake manifold?
Anyone tried to port these yet?
Popular Reply
Sep 17, 2021, 09:59 PM
Kracka's Avatar
Kracka
Full disclosure: I'm a terrible photographer!
Once again Ruben @ SoCal Porting has absolutely knocked it out of the park; this thing is beautiful and easily the nicest LT1 or LT2 ported intake manifold I've ever laid my hands on (I tried 3 different ones on my C7 alone). I would say in addition to the inlet of course, the 8 runners were all 95% touched with manufacturing flaws removed and seams & joints smoothed. If anyone would like additional or specific pictures, please let me know I'm quite excited to get this and my Soler ported throttle body bolted on, to say the least! If anyone needs some IM/TB cores let me know.
@MillerTimeISU @Atlantan
Old Jan 13, 2021 | 09:06 PM
Kracka's Avatar
Kracka
Soler sells a ported TB for the LT2 and Wilson has a ported LT2 IM. Both are on my "wishlist" once my C8 arrives.
Both mods performed well on my C7!
Old Jan 13, 2021 | 09:09 PM
Billy20's Avatar
Billy20
The both have been done you can get an 87mm ported TB or a 92 mm non ported TB to not throw a cell
Old Jan 14, 2021 | 08:55 AM
Snowblind2.0's Avatar
Snowblind2.0
Yes I have ported both. The gains are about what other LT powered cars have shown so you're looking at about 10-15 hp, it may not sound like much for the money spent but if you look at it from the perspective that tuning will not become available anytime soon, then you don't have many options.
The 1 7/8 AR Headers have been the biggest bang for the buck in returns on improved power, they showed 17 peak hp but up to 34 under the curve. Those 3 mods alone will put a gap against a stock c8, assuming traction isn't an issue.
Old Jan 14, 2021 | 09:53 AM
Katech_Mike's Avatar
Katech_Mike
Premium Supporting Vendor
The LT2 throttle body is the same part number as LT1 and LT4. They are interchangeable.
https://store.katechengines.com/lt1l...body-p487.aspx
Old Jan 14, 2021 | 09:55 AM
Mike@SolerEngr's Avatar
Mike@SolerEngr
Supporting Vendor
We have had the modified and ported C8 TB out for a while now! Check out our store. Same performance/features as our LT1/LT4 TB. We have to update the pictures on our site since we have done a few updates since then but lots of C8's already using it (looks more like the LT4 TB).
We have a 91mm (from $275, no tune required) and a 100mm (from $335, requires tune, adapter included). Add a controller ($95) in any case for a complete throttle control solution.
If you have ported your manifold we'll match either the TB or the Adapter (if required) to meet your porting on the manifold, this is also complementary, please coordinate with us before ordering.
No other modification will change your car so much for so little, so easily, and warranty safe.
Cheers!
__________________
Soler Performance LLC
support@solerengineering.com
www.solerengineering.com
(251) 468-9786
Old Jan 14, 2021 | 01:34 PM
TJay74's Avatar
TJay74
Cheers!
Since the C8 ECM hasnt been cracked or is able to be tuned I would think that means any of yours or any other companies TB that requires a tune would not work on the C8 then currently.
Old Jan 14, 2021 | 01:54 PM
Mike@SolerEngr
Supporting Vendor
That's correct. The 91mm does not require a tune. The 100mm runs without a tune but it is less than optimum and might throw codes.
Old Jan 14, 2021 | 02:11 PM
Z0Sick6's Avatar
Z0Sick6
From: North/Central NJ - a.k.a. Gotti in the CFNE section
St. Jude Donor '05
I added a ported TB on my c7 z06 A8 and it helped driveability a good amount do to the lag on the pedal and also because I think due to it being S/C.
Can you explain the benefit and what you noticed on a N/A C8 with the DCT trans (which is far superior to the A8).
Thanks,
Mike
Old Jan 14, 2021 | 02:19 PM
Mike@SolerEngr
Supporting Vendor
Thanks,
Mike
Not sure if you had one of ours on your C7. But basically, the same effect on the C8 regardless of the transmission, this effect is magnified if you also add the controller. WOT power TBD, as we do not have a dyno on a C8 yet.
All our C8/DCT customers love it.
Thanks,
Old Jan 14, 2021 | 03:24 PM
Billy20's Avatar
Billy20
Is this a ported 91mm or just standard 91mm
Old Jan 14, 2021 | 03:30 PM
Mike@SolerEngr
Supporting Vendor
It is actually the same 87mm that comes with the LT2, ported to have the WOT flow area of a 91mm, plus other features at partial throttle.
Old Jan 14, 2021 | 03:46 PM
Snowblind2.0
@Soler is that a throttle commander that modifies the gas pedal signal ?
Old Jan 14, 2021 | 05:15 PM
ArizonaZ06's Avatar
ArizonaZ06
Active Streak: 90 Days
From: Early 2020 Z51 Coupe, Original Owner, Ahwatukee Foothills, AZ
Went with the 95mm Throttle Body Matching by Gwatney Performance, another excellent company. No codes and no tuning required.
As stated, easy 15 HP at not a lot of cost. Great Mod for the C8.
Old Jan 14, 2021 | 05:51 PM
Billy20's Avatar
Billy20
Looking at their site i cant find that ... is that that katech 95mm throttle body that Gwatney has? Or did you buy the whole kit with ported intake manifold with a 95mm TB?
Old Jan 14, 2021 | 06:18 PM
ArizonaZ06's Avatar
ArizonaZ06
Yes went with the whole package manifold with the 95mm TB. 2.5 hr install. Gwatney quality, shipping and communication was outstanding.
Old Jan 14, 2021 | 07:31 PM
Billy20's Avatar
Billy20
There website has 2 prices $425 and $683 what did you pay?
To Porting throttle body or intake manifold?
Old Jan 14, 2021 | 07:41 PM
Mike@SolerEngr
Supporting Vendor
Correct. This is the way it modifies it:
Old Jan 18, 2021 | 08:07 PM
HeadTurner's Avatar
HeadTurner
any issues with your set up.. did you happen to Dyno this set up to confirm results?
Old Jan 19, 2021 | 01:09 AM
ArizonaZ06's Avatar
ArizonaZ06
Check out post #4 on HP info. No issues at all, no codes and install at 2.5 shop labor.
