Sponsored by: CARiD
C8 Brake Upgrade Option
Old Mar 13, 2021 | 04:34 PM
RacingBrake's Avatar
0RacingBrake
Former Vendor
Default C8 Brake Upgrade Option
Carbon Ceramic Brakes
Caliper (Upgrade) Rebuild
The most comprehensive brake store for your Corvette
Link for C6
Link for C7
Old Mar 15, 2021 | 05:17 PM
0RacingBrake
Former Vendor
Old Mar 15, 2021 | 05:37 PM
0RacingBrake
Former Vendor
FRONT:
REAR:
Old Mar 15, 2021 | 05:41 PM
BTT's Avatar
BTT
What is the lifetime of the carbon ceramic rotor replacement when used with your pads?
Old Mar 16, 2021 | 10:17 AM
0RacingBrake
Former Vendor
We started shipping them since 2013 some 7+ years ago, no customers had an issue on them that requires replacement. Nowadays not only the design, material, and production process are greatly improved but also the development of brake pads that helped carbon ceramic brake application more durable and enjoyable (less worries) than before.
Our experience on CCB spans from using OE C6 ZR1 chopped carbon fiber discs for Nissan GTR to Surface Transforms' long carbon fiber straight vanes to our long carbon fiber with direction vane discs. Not only they are stronger but can run cooler than OE Brembo's conventional rotors that most people know (fragile and very expensive to replace).
Carbon Ceramic Brake:
https://racingbrake.com/carbon-ceramic-brake/
Disc material and construction
https://racingbrake.com/products-tech-info/
Old Mar 16, 2021 | 02:32 PM
Ragtop 99's Avatar
Ragtop 99
How well dothe CCB's work on the street in cool and cold weather?
51 rotating lbs saved is a lot.
Old Mar 16, 2021 | 06:42 PM
0RacingBrake
Former Vendor
ST600 is our most recent release exclusively developed for CCB for street & spirited driving. No cold temperature deficiency like you might have learned in the past, good friction right out of your garage even in the cold winter, after a few stops the friction level quickly build up so you hardly will notice any change of friction but consistent and excellent performance.
Recent review by a Nissan GTR driver.
Racing Brake ST600 CCB Pad Review
Old Mar 17, 2021 | 01:09 PM
0RacingBrake
Former Vendor
Rear CCB BBK (390x28)
Old Mar 23, 2021 | 10:34 AM
0RacingBrake
Former Vendor
Big brake kits fit 20" wheels:
https://racingbrake.com/c8-irp-02
  • Front: RB 6 pot caliper w/400x34mm rotor
  • Rear: RB 4 pot caliper w/390x28mm rotor
CCB combo kit:
https://racingbrake.com/rccb-c8-02
Old Mar 23, 2021 | 01:26 PM
0RacingBrake
Former Vendor
Big Brake Kit specifically designed and built for Corvette C8 for extreme track duty, fit stock 19/20" wheels:
  • Front: RB 6 pot caliper w/380x34mm rotor
If you want more weight saving, here is the link to carbon ceramic brake options - Just swap the rotor and pad to instantly convert to a full RB-CCB brake kit.We build a better brake component and system for Corvette (C6 to C8) by design and experience - Improving the performance, durability, and look from street to tracks.
Old Mar 25, 2021 | 06:34 AM
0RacingBrake
Former Vendor
Does Your Track Car Need Carbon Ceramic Brakes?
Old Apr 2, 2021 | 10:16 AM
0RacingBrake
Former Vendor
High performance brake pad for your C8 - No squeaking very low dust street pads in XT910A compound (Copper free).
For Z51:For Non Z51:Better design in size and compound:
Old Apr 2, 2021 | 11:54 AM
Bill Dearborn's Avatar
Bill Dearborn
C7 Corvette Brembo CCM brake rotors need to be replaced due to pockmarking of the rotor face after 13 to 15 track days. Even though they are still above minimum weight the pockmarks decrease brake pad life from 6 track days to 1 track day, thus forcing rotor replacement. How long will your rotors last in this environment? At $1500 to $1800 per rotor replacement cost, this makes the system noncompetitive with aftermarket iron rotor brake systems even though rotor life may be comparable.
Bill
Old Apr 2, 2021 | 06:44 PM
RedLS6's Avatar
RedLS6
Bill
I've experienced all of the above. The Brembo CC rotors are great for the street or for competition with high replacement cost factored in, but for track days most of us have gone back to iron rotors. I'd be interested to know if these carbon-ceramics experience the same rate of surface decay.
Old Apr 6, 2021 | 05:44 PM
0RacingBrake
Former Vendor
Affordable track duty BBK for your C8:
  1. Designed and built for extreme track duty.
  2. Calipers are built with internal dust seals, no boots to burn out (=Ferrari F430 Scruderia)
  3. Center mount two piece rotors dissipate heat for more efficient than conventional surface mount.
  4. Front kit (384x34mm) is the same as our offer for Nissan GTR CBA stock replacement.
  5. Rear kit (390x28mm) retains OE parking brake and provides a more balanced brake system.
  6. Brake pads are standard FMSI# - Easy to source at low cost from your favorite brands.
  7. Guarantee outperforming any aftermarket brake kits.
  8. Fits under stock wheels
On sale at Introductory price, ready to build and ship.
https://racingbrake.com/c8-irp-01
Old Apr 6, 2021 | 06:13 PM
0RacingBrake
Former Vendor
We have developed some un-conventional brake products over the years especially on CCM brakes; rotor, pad, and entire system - Just need more people to experience themselves to believe:
Z28 - By a Russ T. Camaro Z28 track racer (NASA)
Z28 swap for Racing Brake Forged Calipers with Sintered Brake Pads and Carbon Ceramic
Porsche 911 - By David D a Professional Porsche racer
How to restore your damaged CCM rotors at no cost
Mustang GT350R - By John J. Mustang GT track racer
Carbon Ceramic Brakes - They're on!
Old Apr 7, 2021 | 01:36 AM
0RacingBrake
Former Vendor
Buy stock replacement rotors and pads in bundle kits and save:
For Standard C8 (non Z51):
https://racingbrake.com/c8-irk-02
For C8 Z51:
https://racingbrake.com/c8-irk-01
Kits include rotors and performance brake pads (no squeak, low dust) for a 100% bolt on installation.
To C8 Brake Upgrade Option
Old Apr 7, 2021 | 09:17 AM
RedLS6's Avatar
RedLS6
Thanks for the post - very interesting info on the sintered pad's impact on the CC rotor surface. From what I've gathered, the sintered pads work well with the Brembo CC rotor but possibly not other CC brands/constructions, and the comments indicate there may be some extension of rotor life. I think you also commented that the sintered pad / CC combination could be cost-effective when compared to an iron rotor setup. Do you have any quantitative data based on a rotor lifetime test that would give an indication of pad/CC rotor life under trackday conditions?
Old Apr 13, 2021 | 10:09 AM
0RacingBrake
Former Vendor
Sorry we don't have marketing data.
RB 6 pot caliper built for ultimate tracking performance (Same pads as for C7/C8 ZR1 front.)
For this 400/390 brake kit.
Brake pad:
Old Apr 26, 2021 | 12:45 PM
0RacingBrake
Former Vendor
A track duty brake kit with 380x34/390x28mm rotors designed and built for Corvette C8 fits OE 19"/20" wheels
  • Heady duty 6 pot/4 pot calipers with stainless steel pistons and internal dust seals
  • Oversize rotors for extra thermal capacity for a fade free and confidence inspiring tracking
  • Standard FMSI brake pads: Front=Mustang GT500 (D1666), Rear=GTR (D968)
  • Center mount design two piece light weight for more efficient cooling
