Sponsored by: CARiD
Zero to 60
Old Jul 5, 2021 | 02:04 PM
thomas doyle's Avatar
thomas doyle
Default Zero to 60
Has anyone been able to hit 0-60 in 2.9 seconds as advertised? Best I can do is 3.2 seconds
Old Jul 5, 2021 | 02:54 PM
LANZ06's Avatar
LANZ06
I finally got the timer to work and the best I can seem to do is 3.0. I want sub 3’s!!!
Old Jul 5, 2021 | 03:58 PM
thomas doyle
My tires were breaking loose at start up and that could be the delay. I would love to see 3 seconds, Overall it is a very fast car and passenger will wet there pants LOL
Old Jul 5, 2021 | 11:37 PM
clear33765's Avatar
clear33765
I can do 2.6 - 2.8 all day long, but I live in Florida at sea level. The elevation you are at has a lot to do with the times you are able to achieve. I was just at the Spring Mountain class this last weekend and my best time was 3.4. Elevation as well as temperature play a big role with your times.
Old Jul 6, 2021 | 07:45 AM
Z51CYA's Avatar
Z51CYA
Agreed I hit 2.6 here in Florida regularly have even gotten a 2.5 twice. Higher elevations much harder to attain same.
Old Jul 6, 2021 | 11:58 AM
thrilled's Avatar
thrilled
That’s fantastic. 2.5-2.6
Old Jul 6, 2021 | 07:50 PM
jimman10's Avatar
jimman10
Default Timer
What did you do to get timer to work, dealer is working with GM tech sport and haven’t fixed yet
Old Jul 6, 2021 | 07:53 PM
PRE-Z06's Avatar
PRE-Z06
I haven’t raced at elevation, but have run in the summer which can be an equivalent DA swing of a mile high from winter and that’s approximately a 1/2 second difference in the 1/4. The 0-330’ time varies less than half that, I don’t see how there’s more than a .2-.3 second variance in 0-60mph which is mostly traction and mechanical gearing(which isn’t affected by altitude/DA). Driver weight, passenger weight and fuel load I believe could have just as much affect on the 0-60mph as the DA honestly.
Old Jul 6, 2021 | 09:03 PM
jimman10's Avatar
jimman10
Default Altitude
Loose 3% of hp per 1000’ in altitudes
Old Jul 6, 2021 | 10:49 PM
PRE-Z06's Avatar
PRE-Z06
Right or about 15hp in the case of the C8, which is around a .1 in the 1/4 mile for a low 11 second car. How much hp is needed to gain or loose a tenth in a short 0-60mph burst that only takes 3 seconds?
Old Jul 7, 2021 | 08:46 AM
thomas doyle
It took several TRIES TO GET MINE TO WORK. You need to be at a dead stop to start the timer
Read the owners manual carefully on how to set parameters
Old Jul 7, 2021 | 09:31 AM
thomas doyle
Zero to 60 procedure
Old Jul 9, 2021 | 04:35 PM
PRE-Z06's Avatar
PRE-Z06
https://www.motortrend.com/reviews/c...-inconsistent/
To Zero to 60
