Sponsored by: CARiD
Cold Air Intake GM Software
Old Sep 5, 2021 | 10:42 PM
Bee attack's Avatar
Bee attack
Default Cold Air Intake GM Software
Has anyone have information if GM came out with a software update for the generic Cold air intakes? The discussion years previous was purchasing a CAI wold not help unless the CPU had an update to recognize the change in air velocity.
Old Sep 5, 2021 | 11:32 PM
Racer X's Avatar
Racer X
The C8 has wideband O2 sensors and runs in closed loop except at startup and limp home. So it automatically adjusts to additional airflow to a target AFR, until it runs out of injector. Prior models used reference tables at wide open throttle , thus the Air Fuel Ratio would change when you added more airflow,
No tune is needed or possible for a CAI. A properly designed intake does not interfere with the Mass Air Flow sensor readings.
