Sponsored by: CARiD
1LT Live-view camera install with engine lights
Old Sep 17, 2022 | 12:18 PM
Innovated's Avatar
Innovated
Surely there has to be a shop that can offer this ?
Old Sep 18, 2022 | 08:52 AM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
I think there was one posted. I'll see if I can find the name. Not sure about a shop that'll do it but here's a post with some info.
#4 https://www.corvetteforum.com/forums...-solution.html
Old Oct 31, 2022 | 10:33 AM
oreobbq's Avatar
oreobbq
Outstanding mod! I agree that this is the most helpful feature from 2LT and up.
Old Feb 3, 2023 | 03:27 PM
Carguy67's Avatar
Carguy67
Thanks for the great instruction & photos: I will be doing the same in a few days
Old Feb 3, 2023 | 03:33 PM
Innovated's Avatar
Innovated
Have you already sourced all the parts ?
Old Feb 4, 2023 | 09:21 AM
slow goat's Avatar
slow goat
That is outstanding work. I did mods like this on my C6 to bring up the spec- like adding the HUD. Very well done to you sir!
Old Mar 10, 2023 | 07:06 PM
Carguy67's Avatar
Carguy67
I'm a new member: 2023 LT1, bought 3 weeks ago and trying to install the roof camera system. I'm waiting for 1 last part and I'll do the install. A big thanks to VictoryC8Vert for the great photo instructions. While I have all the right harnesses, I'm confused as to which harness goes where. Can anyone post a list or drwg of the harness orientations from the mirror/display to the camera? I'd surely appreciate the help
Old Sep 18, 2023 | 12:13 PM
Rloubriel1973's Avatar
Rloubriel1973
1st Gear
Default how can i get this part
Old Dec 26, 2023 | 11:26 AM
raulcr13@yahoo.com's Avatar
raulcr13@yahoo.com
1st Gear
Default 2020 corvette
Hi I was wondering if anyone has the part number for the live view camera only? The camera I bought doesn’t fit the rear live view panel I bought
Old Dec 5, 2024 | 06:24 PM
reef_guru's Avatar
reef_guru
2nd Gear
sold
Old Oct 20, 2025 | 09:59 AM
LightSaberVette's Avatar
LightSaberVette
2nd Gear
Originally Posted by Victory06vert
The only option I wanted in my 1LT C8 was the live view camera because I didn’t realize how much the high wing blocked the view and the overall poor rear visibility in C8’s. I decided I’d add the live view camera.
mirror - ebay
Harness with video cable and engine bay lights
84740000
Cargo Lamps
84238355
84238354
Appliqué with camera in primer
84609010
Mirror harness and video cable - Gen5diy
900305-15 ft camera cable
live view mirror 10 pin connector/power and ground only + 6'
Note: this is a moderate difficulty level and I didn’t include all the basic steps as this is an overview of what I did an not a detailed step by step
Bench test with everything working
Remove the trim
Remove the a pillar trim
Remove cover, visor clip, and visor
Stock mirror twists out. Remove panel. Route power wire and video cable
Ran cable down a pillar and connected to rear fuse block on circuit 12
Hidden screws in the weatherstripping
Remove header panel
Disconnect b pillar harness
Testing the lights work
Remove old harness
Remove all the screws under the weather stripping and two hidden ones on each end
Arch removed easily to run harness
Roughy harness to B pillar connector
New harness routed on the hatch
Routing the harness and making sure to seat the grommet
Screws to hold up lights
Lights installed
Camera installed and mirror working
Following your lead and I have ordered all the parts. Gen5DIY was super helpful information. One question...the top lid part 84895699-did that come with the camera attached? The description is unclear.
Old Oct 30, 2025 | 09:59 AM
Victory06vert's Avatar
Victory06vert
Yes, the part came with the camera
Old Jan 3, 2026 | 12:40 PM
  #33
LightSaberVette
2nd Gear
Do you mind telling me what you used for a power source to bench test the mirror and the camera prior to the install in the car? I have all the parts and my best friend is testing using a 12 V car battery and unable to get the mirror to power on. Any tips would be much appreciated. Doing the install on my 2021 C8.Cassidy.leefl@gmail.com
QUOTE=Victory06vert;1604276580]The only option I wanted in my 1LT C8 was the live view camera because I didn’t realize how much the high wing blocked the view and the overall poor rear visibility in C8’s. I decided I’d add the live view camera.
mirror - ebay
84740000
Cargo Lamps
84238355
84238354
84609010
Remove the trim
Remove header panel
Remove old harness
Lights installed
Camera installed and mirror working[/QUOTE]
Old Jan 3, 2026 | 03:34 PM
  #34
cmck0916's Avatar
cmck0916
Great tutorial!
I wonder what the feasibility of adding a front camera and PDR is to a 1LT/1LZ?
Old Jan 5, 2026 | 09:54 AM
  #35
3LZR21U's Avatar
3LZR21U
Banned Scam/Spammer
I'd think at this point it might be easier to retrofit with a ZR1 style camera...
I would recommend against doing a stock PDR camera retrofit. If you don't have, you might as well go with an aftermarket solution that has both front AND rear cameras.
