Sponsored by: CARiD
1LT Live-view camera install with engine lights
Old Nov 7, 2021 | 05:26 AM
Victory06vert's Avatar
Victory06vert
Default 1LT Live-view camera install with engine lights
The only option I wanted in my 1LT C8 was the live view camera because I didn’t realize how much the high wing blocked the view and the overall poor rear visibility in C8’s. I decided I’d add the live view camera.
mirror - ebay
Harness with video cable and engine bay lights
84740000
Cargo Lamps
84238355
84238354
Appliqué with camera in primer
84609010
Mirror harness and video cable - Gen5diy
900305-15 ft camera cable
live view mirror 10 pin connector/power and ground only + 6'
Note: this is a moderate difficulty level and I didn’t include all the basic steps as this is an overview of what I did an not a detailed step by step
Bench test with everything working
Remove the trim
Remove the a pillar trim
Remove cover, visor clip, and visor
Stock mirror twists out. Remove panel. Route power wire and video cable
Ran cable down a pillar and connected to rear fuse block on circuit 12
Hidden screws in the weatherstripping
Remove header panel
Disconnect b pillar harness
Testing the lights work
Remove old harness
Remove all the screws under the weather stripping and two hidden ones on each end
Arch removed easily to run harness
Roughy harness to B pillar connector
New harness routed on the hatch
Routing the harness and making sure to seat the grommet
Screws to hold up lights
Lights installed
Camera installed and mirror working
Popular Reply
Nov 8, 2021, 09:41 PM
Victory06vert
Right about $1k.
mirror $300
wiring harnesses for camera and video cable $100
trim and camera $200
arch wiring harness and lights $100
paint $300
Old Nov 8, 2021 | 07:15 AM
Tim0shel's Avatar
Tim0shel
Wow doesnt look to be the funniest job. Good work and thanks for sharing!
Old Nov 8, 2021 | 09:18 PM
jacksoj2wf's Avatar
jacksoj2wf
Default Cost and time
What was the total cost of parts and how long did it take you? I've added my own spoiler and installed my AWE exhaust myself already
Old Nov 8, 2021 | 09:41 PM
Victory06vert
Right about $1k.
mirror $300
paint $300
Old Nov 14, 2021 | 10:19 AM
kern44's Avatar
kern44
Nice job and write up.
Now....can you do mine?
Old Nov 15, 2021 | 01:56 AM
GTUnit's Avatar
GTUnit
Nice work
Old Nov 15, 2021 | 06:48 PM
92_383LT4's Avatar
92_383LT4
Nice job 😎🤓
Old Dec 22, 2021 | 09:43 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
Looks like $130 to add lights.
now I need to find a C8 2/3LT MIRROR
Old Jan 7, 2022 | 04:18 PM
oooseun's Avatar
oooseun
How did you go about paint matching? @Victory06vert
Old Jan 26, 2022 | 07:59 PM
Victory06vert
I went to a local paint and body shop that sprayed it for me.
Old Feb 22, 2022 | 02:55 PM
Jbltulsa's Avatar
Jbltulsa
2nd Gear
Where did you purchase the "live view mirror 10 pin connector/power and ground only + 6'" cable? I have all the parts except this one and can't find any parts that match this.
Old Feb 23, 2022 | 07:47 PM
Edwardz's Avatar
Edwardz
I am having intermittent problems with my camera. Acts like a loose connector somewhere. Any tips on finding it would be appreciated.
Old Mar 4, 2022 | 03:44 PM
Jbltulsa's Avatar
Jbltulsa
2nd Gear
Just following up. Where did you purchase the "live view mirror 10 pin connector/power and ground only + 6'" cable?
I am looking for the part and cannot find it.
Thanks,
Old Mar 26, 2022 | 04:46 PM
Robertsonal's Avatar
Robertsonal
2nd Gear
Thanks for the awesome write-up. Testing mine now before the install.
Old Mar 26, 2022 | 04:51 PM
Robertsonal
2nd Gear
Thanks,
I couldn’t fine it either, I went with pn 220600 from gen5diy. I removed the part I didn’t need from the harness. See pic for section that was removed
Old Mar 26, 2022 | 09:57 PM
Victory06vert
@Jbltulsa All the missing parts…video extension cable and harness to the mirror I got from Gen5diy.com. They were super helpful.
Last edited by Victory06vert; Mar 26, 2022 at 09:58 PM. Reason: Needed to tag requestor
Old Mar 26, 2022 | 10:05 PM
Victory06vert
this is the invoice from Gen5diy
To 1LT Live-view camera install with engine lights
Old Aug 1, 2022 | 02:43 PM
Monkeybear1!'s Avatar
Monkeybear1!
2nd Gear
Do you by any chance have the GM part list numbers for the Mirro, Camera and Harness?
Old Aug 1, 2022 | 02:47 PM
Monkeybear1!
2nd Gear
Default Part List?
Do you by any chance have the GM part numbers for the Rearview mirror, camera wiring harness and rear camera???
Old Aug 24, 2022 | 11:59 PM
Tuckermaclain's Avatar
Tuckermaclain
You seriously did a lot of work there! Great job! I do very much love that rear-view mirror camera. It makes visibility go from the worst ever to the best.
