Sponsored by: CARiD
Improving 0-60
Old Dec 16, 2021 | 05:48 PM
Tennisplyr's Avatar
Tennisplyr
Default Improving 0-60
I looked at an earlier thread on 0-60 times, but didn't actually see how people are accomplishing their times. I have a 2022 Z51. I have only tried to launch it once, but my time for 0 - 60 was 3.5. I simply put it in "track" mode and used launch control, then kept my foot to the floor. How have you folks gotten such a fast time (2.6)? Were you shifting manually? What can I do differently?
Old Dec 17, 2021 | 12:39 AM
Krazy98Z28's Avatar
Krazy98Z28
Try sport mode, sometimes lowering tire pressure helps. Leave it in Auto, also helps if you have 2 extra quarts of trans fluid.
Old Dec 17, 2021 | 11:41 AM
diehrd's Avatar
diehrd
Did you disable traction control ? When you don't you will not get the full 3500 rpm launch. And your times will be like yours.
Old Dec 19, 2021 | 03:33 PM
Mike's LS3's Avatar
Mike's LS3
Do a few back to back runs which will heat up the tires. On a 72* F day, I did a couple back to back runs. On my first run a 3.2 with some wheel spin. On my second run with little wheel spin a 2.9. 2021 Z51 Coupe MSRC.
Old Jan 10, 2022 | 03:13 PM
oooseun's Avatar
oooseun
TBH 2.7 & 3.5 don't feel THAT much different. It's still a violent start, albeit a little wheelspin. Stop chasing numbers and just enjoy the car.
But i've gotten both 3.5 and 2.7 (launched ~2 times ever). 3.5 was at about 2k miles, it was a HOT day, i had a bunch of stuff in the trunk/frunk. Felt very quick.
2.7 was a 60F day, tires were 'normal temp', and pretty light. In both cases, i launched on asphalt, 2.7 didn't feel any faster than 3.5
To Improving 0-60
