Sponsored by: CARiD
C8 head options
Old May 8, 2022 | 10:43 AM
DAGreekNYC's Avatar
DAGreekNYC
Default C8 head options
Wondering has anyone installed a different set of heads on their car yet ? Any older model heads fit this block ? If not has anyone ported a set of stock heads yet ? Curious to the performance gains . Thanks
Popular Reply
May 8, 2022, 10:40 PM
Snowblind2.0's Avatar
Snowblind2.0
LT1 and LT2 heads are the same so you can port the stockers or go something like a PRC LTX or CID head and not have any issues.
Compression is king in the LT NA world so I think getting them decked is probably going to net bigger gains than just a cnc port, but that's just my opinion. I have my heads ported and saw decent gains but they are coming back off soon to get a big mill cut...fingers crossed the ecu doesn't mind it
Old May 8, 2022 | 11:39 AM
NoMatter's Avatar
NoMatter
What’s Next
Competition Auto has ported the heads. Great gains also. Car has ported intake also. About $6100 for install which includes the heads and pulling the motor.
Old May 8, 2022 | 10:40 PM
Snowblind2.0
Old May 9, 2022 | 06:09 AM
Fore58's Avatar
Fore58
Just curious......what was the gains?
Old May 10, 2022 | 04:36 PM
langhorne_bill's Avatar
langhorne_bill
Active Streak: 90 Days
Default Head removal
Can the heads be removed for porting without removing the entire engine?
Thanks, Bill
Old May 15, 2022 | 05:13 PM
Andy@A&ACorvette's Avatar
Andy@A&ACorvette
Platinum Supporting Vendor
Thanks, Bill
Maybe, but pulling the engine will probably be easier.
I have a set of CNC ported heads that Richard at West Coast Cylinder heads did for me. I have a set of Ceramic coated American Racing headers and a Soler Performance TB as well.
I'm just waiting on the LPE intake manifold before I swap everything out. I'll look at doing it in the car, but I'm sure we'll just drop the motor/ trans assembly.
__________________
PLEASE TAKE A MOMENT TO VISIT OUR WEBSITE AT WWW.AACORVETTE.COM
NOW PARTNERING WITH AFFIRM TO OFFER INTEREST FREE FINANCING!
ANDY GREEN- OWNER/ CEO -A&A CORVETTE / A&A SUPERCHARGERS
477 LAMBERT ST
OXNARD CA 93036
WWW.AACorvette.com
A&A CORVETTE SUPERCHARGER SYSTEMS
HOME OF THE WORLDS FIRST
CENTRIFUGALLY SUPERCHARGED C7
SUPERIOR ENGINEERING- SUPERIOR POWER
SUPERIOR PRICING- SUPERIOR CUSTOMER SUPPORT
Andy@AACorvette.com 805- 278 4107
Old May 16, 2022 | 03:07 PM
Ragtop 99's Avatar
Ragtop 99
How much are you thinking of milling? Do you have a means to adjust ignition or cam timing if you start to get some detonation?
Old May 17, 2022 | 08:48 PM
PRE-Z06's Avatar
PRE-Z06
What’s PTV clearance with VCT?
Old May 18, 2022 | 10:21 AM
Snowblind2.0
Thanks, Bill
Short answer is yes. Their is 1 bolt that goes thru the dry sump tank and into the drivers side head, it is only for support and a tool with a cutting wheel can do the job, their is a gap between the tank and the block to get the tool in there. I know the hammerheads on the forums will cry foul that you need that support bolt, but you don't. Its not the correct way but you can do a head swap with the motor still in it.
I spoke to a couple friends that do head work on the LT1 motors. They say I can mill .060 on the head and do a .028 gasket (.054? is stock) and it has enough ptv clearence but their is a nub by the spark plug that need to be ground off. The issue is octane, which you've asked, and that is the big question for me too. If I go full send in the compression bump I will prob either need to run an octane booster or try something like an e20 mix for a point above 93. I haven't pulled the trigger yet but I'm getting close.
Old May 18, 2022 | 11:48 AM
PRE-Z06's Avatar
PRE-Z06
Iirc the LT2 camshaft is “bigger” than LT1 meaning less PTV? Thinner head gasket and that much milling bumps SCR up how much?
Old May 18, 2022 | 10:03 PM
SocalC5Z's Avatar
SocalC5Z
So the stock tune won't throw codes and make more HP/TQ just with higher compression and ported heads? Kinda seems hard to believe.
Old May 11, 2023 | 07:51 AM
PhoenixM3's Avatar
PhoenixM3
any update to milling the heads?
Old May 22, 2023 | 08:57 PM
c5racr1's Avatar
c5racr1
did the heads on my car, took about a day, and did not drop the engine. I went with ported stock heads and had 1 bolt to cut. It was a garage project so it was done on quick jacks, I didn't have to jack the car all the work was done from up top.
Old May 22, 2023 | 09:19 PM
123sugey's Avatar
123sugey
Dig
And…. How does she run ? Any other details ?
Old May 22, 2023 | 10:08 PM
c5racr1's Avatar
c5racr1
it’s faster. I pull away from my buddies c8 from a roll
Old May 22, 2023 | 10:28 PM
123sugey's Avatar
123sugey
Dig
nice 😎
Old Jul 28, 2023 | 06:30 PM
Snowblind2.0
I ended up doing a .040 mill .040 Cometic and shorter pushrods. Did not adjust timing and got no detonation. Car idles and drives no different than stock. Compression is probably around 12.8:1
To C8 head options
