Sponsored by: CARiD
Drag Pack Disappointment
Old Jan 19, 2023 | 08:01 AM
NonZ51Mark's Avatar
NonZ51Mark
Default Drag Pack Disappointment
Went to Showtime last night with half my drag pack installed (still waiting on front tires). I didn't install TPMS sensors in the rear wheels and the car would not go into launch mode. Slowest ET and almost the slowest mph I've seen on my car do date. Does anyone know if I don't run any TPMS's if launch control will work? Will 0 TPMS sensors work the same as 4? I expected a higher trap speed with the rear wheels weighing 13lbs less each even without launch control. I lost 2 mph in trap speed from the last time I ran. I am running a 26 inch rear tire now thinking it would improve acceleration. Was it just a fluke or should I have gone with the stock tire height or bigger?
Old Jan 19, 2023 | 12:11 PM
bhvrdr's Avatar
bhvrdr
You can run zero sensors or all sensors but nothing in between.
Old Jan 19, 2023 | 12:24 PM
NonZ51Mark's Avatar
NonZ51Mark
So launch control will work without any sensors? Is there anything else you need to do, disable the air pressure monitor system? Will the air pressure warning symbol still be lit?
Old Jan 19, 2023 | 01:40 PM
bhvrdr's Avatar
bhvrdr
Yes you are fine with doing everything with no sensors. The issue is if it reads one sensor or up to three sensors then it assumes there is a failure.
Old Jan 21, 2023 | 07:26 PM
c5racr1's Avatar
c5racr1
0 of all.(period)
Old Jan 23, 2023 | 09:24 AM
Cicio Performance's Avatar
Cicio Performance
Supporting Vendor
Hey Brother,
Just a heads up we have seen C8's not go into launch control with all TPMS active when the tire diameter ratio between front and rear is too far off as well just a heads up so the 26 in tall tire may still give you issues unless a shorter front tire is also used.
Andrew
__________________
Cicio Performance Website
Old Jan 23, 2023 | 09:37 AM
NonZ51Mark's Avatar
NonZ51Mark
Originally Posted by Cicio Performance
Hey Brother,
Andrew
The front tires I ordered are also 26 inch so I hope they work. Stock sizes appear to be 27.25 rear and about 25.75 in the front.
Old Feb 4, 2023 | 08:03 PM
BJ67's Avatar
BJ67
Your correct NonZ51Mark, but the OE rear tire is 27.2 and the front like you say is about 25.75, the car is programed for the 1.5 inch tire height or circumference difference between front and rear tires. The 26 tall rear tire maybe your issue, I have read the electronics have about 3% to work with, a 26.5 inch rear tire for instance may have been no issues.
To Drag Pack Disappointment
