Sponsored by: CARiD
O2 Spacers vs Mini Cats
Old Jun 27, 2023 | 10:01 AM
J'sun Z's Avatar
J'sun Z
Default O2 Spacers vs Mini Cats
Currently I have the Paragon track cat back exhaust and love it but miss that loud bite associated with full straight pipe.
So picked up some 2M cat delete pipes. They came with the O2 spacers and I also ordered the mini cat spacers as well.
The question is, should I go straight for the mini cats or try the spacers first. I know most people had luck with the just the spacers and no CEL but for me logic would say do the mini cats. In my mind the idea of the mini cat would be more robust and would convert the gasses for the secondary O2 sensory however I could have sworn I read on the forums somewhere that some people did not advise mini cats as it can’t change secondary measuring in an unfavorable way!
So should I do spacers or mini cats? Do mini cats truly change secondary measuring in a unfavorable way?
Old May 25, 2024 | 12:25 PM
yusufkurun's Avatar
yusufkurun
Originally Posted by J'sun Z;[url=tel:1606779493
1606779493[/url]]Currently I have the Paragon track cat back exhaust and love it but miss that loud bite associated with full straight pipe.
What’d you end up doing? Any CEL? Same predicament- thanks.
Old Jul 11, 2024 | 09:24 PM
nyc8's Avatar
nyc8
1st Gear
Default Update?
would love to know which route you ended up going with i’m in the same predicament and don’t know what to do, im also thinking maybe afm valve simulator modules might work as well.
Old Jul 12, 2024 | 08:47 AM
Kracka's Avatar
Kracka
Mini-cats are the way to go when fully catless. I recommend Big Daddies Garage for o2 sensor spacers and mini-cats as they're about as quality as it gets when it comes to that.
Valve simulators are in no way related to the o2 sensors.
To O2 Spacers vs Mini Cats
