Sponsored by: CARiD
Track alignment - why remove the washers?
Old Jul 14, 2023 | 02:20 PM
MistressMotorsports's Avatar
MistressMotorsports
Default Track alignment - why remove the washers?
It’s clear in the manual that you are supposed to remove the washers between the body and the shocks when doing a track alignment. What is the reason for that? Does it change something in the camber or toe curve, or is it just to help be able to get to the recommended static setting, or something else? THX
Old Jul 15, 2023 | 02:06 AM
X25's Avatar
X25
Sr.Random input generator
It increases the maximum camber you can attain. With the washers, you likely can't hit the recommended track alignment specs listed in GM's track prep document.
Old Jul 15, 2023 | 08:45 AM
AHP's Avatar
AHP
My alignment guy was able to get me to the track spec without removing the washers. -3 up front, -2.6 in the rear.
Old Jul 15, 2023 | 11:24 AM
X25's Avatar
X25
Is your car at stock height?
Old Jul 15, 2023 | 01:13 PM
AHP's Avatar
AHP
I have the front lift so the front ride height is not adjustable. I'm actually not sure if he changed the rear, though; will ask. My C8 was the first he had done and I do know it took a few hours to get it sorted. He's been doing my alignments, tires, etc.. forever and has worked with various race teams so I trust him implicitly.
Old Jul 15, 2023 | 01:23 PM
X25's Avatar
X25
https://www.corvetteforum.com/forums...post1606789327
My target was a bit more aggressive than yours, but we had to get the washers removed.
Alignment Specs (Camber, Caster, Toe; in degrees):
  • Front: -3.5, 8.1, 0.00
  • Rear: -2.8, 0, 0.05
Heights, weights with 192 lb ballast, full tank (FL, FR, RL, RR)
  • 672, 668, 714, 713 (mm)
  • 756, 725, 1160, 1127 (lb) --> 3768 lb total; 3576 lb curb without driver.
  • LR + RF = 1885 lb; 50.09%.
Old Jul 15, 2023 | 01:42 PM
AHP's Avatar
AHP
We did the GM prescribed specs so maybe we're at the tail end of the adjustment with the washers in place. I do think it would like more camber judging by the shoulder wear so will find out the next time it's on the rack.
Old Jul 15, 2023 | 01:59 PM
c5racr1's Avatar
c5racr1
Removing the washers makes it easier. Probably it.
Old Oct 26, 2023 | 12:41 PM
new_hampster's Avatar
new_hampster
A clarification - the track spec does not -remove- the washers. It -moves- the washer from between control arm/chassis to between head of bolt and control arm.
Old Oct 26, 2023 | 12:46 PM
new_hampster
Same for me with '21 Z51 w/lift. He said he could get up to -3.1 on the front and -2.6 on the rear without moving the washers. I went with -2.5 and -2.1 for first track event. Nice to know I can move it around without dealing with the washers.
Old Oct 28, 2023 | 10:42 AM
jwt1603's Avatar
jwt1603
My guy was able to as well. Took him a bit of time and effort but he got it there. Anything more and you would have to flip the washers.
To Track alignment - why remove the washers?
