Sponsored by: CARiD
ARH headers arrived today!
Old Jul 24, 2023 | 07:46 PM
PhoenixM3's Avatar
PhoenixM3
Default ARH headers arrived today!
Unfortunately, I wasn’t savvy enough to have them shipped to Jet-Hot. I will likely go with the polished finish, but am not sure how much (if any) heat reduction this will afford. Will not likely go FI, but rather bolt-ons and maybe a tune.
Old Jul 26, 2023 | 01:59 PM
PhoenixM3's Avatar
PhoenixM3
......and shipped off to Jet-Hot for polished ceramic coating......
Old Jul 27, 2023 | 12:05 AM
newchevyman's Avatar
newchevyman
Do you have other mods? Install yourself or having a shop do it?
Old Jul 27, 2023 | 11:20 AM
PhoenixM3's Avatar
PhoenixM3
I'm scheduled to pickup the car mid-August. I have an AFE intake coming, and a Soler TB on my shelf. I'll do the work myself.
Old Jul 27, 2023 | 11:37 AM
Driv200's Avatar
Driv200
Congrats on the mods. Exhaust and headers my favorite mod on the C8. I jet hot coated mine for heat protection in the already hot engine bay. High flow cats and exhaust heat wrapped in ceramic blankets.
Soler TB or ECU tune for me. Pondering.
Old Jul 27, 2023 | 11:51 AM
PhoenixM3's Avatar
PhoenixM3
I've been chatting with @Kracka for his thoughts on test pipes. I'll see how I feel after I get the headers installed, before I consider ditching the cats. Probably wont do an exhaust because they're still stupidly expensive.
Old Jul 27, 2023 | 01:07 PM
Driv200's Avatar
Driv200
Agree with that. Over $10k in my exhaust set up. I can save you the learning curve and tell you headers won’t change your sound much. They are better than stock, but the high flow cats will make a bigger difference. But they aren’t cheap either.
Old Jul 27, 2023 | 01:31 PM
Kracka's Avatar
Kracka
Yup, exhausts are definitely expensive on these cars!
aFe + Corsa + Borla here. I also have the aFe intake + Soler TB + SoCal Porting IM.
Old Jul 28, 2023 | 06:08 AM
PhoenixM3's Avatar
PhoenixM3
Still pondering porting the stock IM, or going aftermarket….
Old Jul 28, 2023 | 03:42 PM
combatninja's Avatar
combatninja
Skip all these tacky-tacky BS bolt-ons and do it right. Now that tuning is unlocked, do a cam, tune and head build for real power. Twice the power at similar money to a bunch of bolt-ons.
Old Jul 28, 2023 | 05:20 PM
Fore58's Avatar
Fore58
I would like to see tune with bolt-ons.
Old Jul 28, 2023 | 08:33 PM
Kracka's Avatar
Kracka
300 bucks and literally takes only minutes to install. It's not a huge gain since the LT2 already had a nicely improved intake manifold vs. the LT1, but porting them shows about 3whp on the dyno. Gains aren't easy to come by on these cars so I'll take what I can get where I can find it.
Old Jul 30, 2023 | 10:15 AM
combatninja
Paragon posted a video last week. Gains were....unimpressive. Inconclusive testing methodology muddied by 91 vs 93 octane, no baseline, etc. It looks like the tune was good for about 14whp over the bolt-ons on the 91. They never got a baseline stock tune with the bolt-ons on 93 unfortunately but I'd expect about the same result. These cars are so finicky about IATs and heat soak that I approach every dyno with a healthy dose of skepticism. Just the nature of the beast. Once these tuned NA cars start showing up in numbers and start logging those 60-130 times, we'll know what it actually does.
Old Jul 30, 2023 | 11:02 AM
Fore58's Avatar
Fore58
From what I had experienced with previous tunes 14 rwhp is pretty much in the ballpark. However paying over $3000 for 14 rwhp is painful.
Old Jul 30, 2023 | 12:13 PM
PhoenixM3's Avatar
PhoenixM3
Headers, throttle body and intake and easy bolt-on mods with proven performance. The big upside is I won’t void a warranty, but tuning will. Let me get the car, do the basic mods, then I will probably consider a tune and a cam.
Old Jul 30, 2023 | 02:50 PM
combatninja
Nobody is really paying that much for that little. They get the tune because the have an upgrade path planned out and once unlocked, they can tune it over and over as they add modifications. I don't think we are going to see the real value of tuning until the cam and head cars start getting built. A mild cam that can let this engine breathe right up to a 6500rpm power peak with a fuel cut at 7000 would be awesome on this platform. If we can't change the damn gears, maybe we can at least raise the redline.
Old Jul 30, 2023 | 03:02 PM
floorman279's Avatar
floorman279
jethot isnt a thermal coating.......if you want thermal you need swaintech white lightning
To ARH headers arrived today!
Old Jul 30, 2023 | 03:11 PM
Kracka's Avatar
Kracka
That stuff sucks... It's ugly, discolors, then flakes off. I honestly thought people stopped using it 2+ decades ago, but apparently not.
Old Jul 30, 2023 | 03:18 PM
combatninja
Jet-Hot is absolutely a thermal coating. It drastically reduces underhood temperatures when applied to exhaust manifolds/headers, etc. You can take a normal drive and sometimes touch a header coated with it whereas a plain mild steel header would absolutely burn you. I'm not saying you'd want to keep your hand there for a ten count but it's not hot to the point that your reflexes kick in and you jerk your hand away. Swain Tech White Ligtning is good stuff as well and probably does outperform Jet-Hot but at a price point much higher. Once intent is met and the header is coated sufficiently to keep it from ruining anything around it, you've reached that point of diminishing returns as far as coating performance.
Old Jul 30, 2023 | 03:28 PM
floorman279
lol im pretty sure more jethot has flaked off than swain tech......but yea i guess looks in a coating is more important
