Sponsored by: CARiD
LT2 Stroker 390” engine with Camshaft
Old Aug 1, 2023 | 07:53 PM
PRE-Z06's Avatar
PRE-Z06
Originally Posted by undecided1965
When you really want to squeeze that little extra RPM. Or, will the TCU not let you keep it in the lower gear even in M?
I believe the stock rev limiter cuts fuel and you need fuel to make power, are you saying the tables are there in the tune so you can alter them? I know older generation ECU’s had tables up to 8k rpm, but not sure about the C8.
