Sponsored by: CARiD
LT2 Stroker 390” engine with Camshaft
Old Jul 30, 2023 | 11:09 PM
degfu's Avatar
degfu
Default LT2 Stroker 390” engine with Camshaft
LME Built a 390 cu. in. LT2 618 HP @7100RPM capable of 1500HP with boosted applications. This platform is finally getting fun.
No pricing listed.
Old Jul 31, 2023 | 10:27 AM
LowcountryVette's Avatar
LowcountryVette
Wonder what the issue is that keeps them from going to the typical 416ci like the LS3/LT1
Old Jul 31, 2023 | 11:23 AM
degfu's Avatar
degfu
That I'm not sure. Maybe it can but they are building this for boost. I did read the engine is more shallow, but I don't know if that's the overall dimensions or the block itself.
Old Jul 31, 2023 | 11:51 AM
c5racr1's Avatar
c5racr1
I have heard the oil pan won't accept a long-stroke crankshaft.
Old Jul 31, 2023 | 02:27 PM
PRE-Z06's Avatar
PRE-Z06
Thought the C8 is limited to 6600rpm?
Old Jul 31, 2023 | 04:21 PM
combatninja's Avatar
combatninja
That's half the point of building a GM small block up. You can get rid of the truck redline. LT2 has a relatively short stroke, the piston speeds should support some pretty high revs. I think we'll see 7500rpm builds become common and the drag racers and track rats will probably go beyond that.
Old Jul 31, 2023 | 05:34 PM
PRE-Z06's Avatar
PRE-Z06
I agree on the rev limit, suppose I should have worded it differently…can the shift points be raised as I thought they couldn’t?
Old Jul 31, 2023 | 05:54 PM
123sugey's Avatar
123sugey
Dig
as of now I’ve been told no
Old Jul 31, 2023 | 06:10 PM
INTRUDR's Avatar
INTRUDR
It's my understanding that HP Tuners has not yet addressed the DCT, and Dodson has not produced additional gear sets for the C8. Both would be nice! However, boost by gear, rpm, vehicle speed, etc. is available via a Cortex controller (can also control methanol/nitrous injection).
Old Jul 31, 2023 | 07:23 PM
combatninja
TCU decryption has to be close. Somebody please tell me it's close.
Old Jul 31, 2023 | 08:00 PM
allblackeverything's Avatar
allblackeverything
I was told by the end of August it will be commercially available
Old Jul 31, 2023 | 10:42 PM
OkieVette84's Avatar
OkieVette84
Sweet Mother of God. I hope this winds up being accurate.
Just moving the Max RPM to 7050 with existing trash gears would be a major improvement to mid-range-go-fast.
7500 would be earth shattering in terms of improvement and that is w/o a new gear set...
do both and we'd be seeing a lot of crazy 1/4mi times
Old Jul 31, 2023 | 11:11 PM
allblackeverything
I know right! Updated gear set would be amazing for us track guys too. The car just stops pulling in 4th
Old Jul 31, 2023 | 11:23 PM
123sugey's Avatar
123sugey
Dig
With the C7 it was 5th gear for me. Once I upped the boost (more power…. Procharged car) it was all good.
Praying the trans tune will have similar results on the C8
Old Aug 1, 2023 | 12:02 AM
PRE-Z06's Avatar
PRE-Z06
I don’t understand how it stops pulling as it only drops 1700rpm and drops very close to peak torque? I’ve only driven a C8 on road course that’s vmax was top of 4th though it’s not like the LT2 is a peaky engine and believe the aero drag is greater in this car because of it’s exceptional cooling that comes with increased drag.
Old Aug 1, 2023 | 06:42 AM
Rkreigh's Avatar
Rkreigh
car doesn't need all the OD gears. I wonder if anyone has taken a fancy hewland box from c8r to put in in the street car
gear ratios are so much better. No fix for the tremec in sight 2 not 4 OD gears would be plenty!!
Old Aug 1, 2023 | 10:40 AM
d16dcoe45's Avatar
d16dcoe45
Yes, obviously! You wouldn't install a big inch build with a big camshaft and expect the stock ECM to "compensate". Now that you can use HP Tuners you can raise shift points, change torque tables, alter knock sensitivity and change timing to suit your exact build.
To LT2 Stroker 390” engine with Camshaft
Old Aug 1, 2023 | 10:50 AM
PRE-Z06's Avatar
PRE-Z06
Right, but you can’t control the TCM yet to raise shift points is my understanding no?
Old Aug 1, 2023 | 03:16 PM
undecided1965's Avatar
undecided1965
Default Just drive in M, no?
When you really want to squeeze that little extra RPM. Or, will the TCU not let you keep it in the lower gear even in M?
Old Aug 1, 2023 | 05:21 PM
combatninja
Not sure anyone knows the answer to that. Anyone seen all the tables? Is there one for shift points? I doubt it and figure it is controlled by the TCU.
