Sponsored by: CARiD
ProCharger is adding variable launch RPM
Old Aug 4, 2023 | 05:59 PM
degfu's Avatar
degfu
Default ProCharger is adding variable launch RPM
Pretty cool feature being added to the ProCharger setup. I'm guessing this will be available for HP tuners as well in the future.
New feature being added to the ProCharger C8 supercharger systems.
- User defined launch RPM!
https://www.facebook.com/562317422/videos/7012696068781022/
Old Aug 5, 2023 | 09:27 AM
degfu's Avatar
degfu
https://www.facebook.com/562317422/v...2696068781022/
He removed the post. He must have jumped the gun on releasing the feature. He did show its functionality and was able to launch at 2500 RPM vs 3500RPM
Old Aug 5, 2023 | 06:39 PM
newchevyman's Avatar
newchevyman
This would be an HP Tuners feature. Not a Procharger's specific feature.
Why would the ECU care what power adder or modifications are done to the engine to change launch RPM?
Old Aug 5, 2023 | 07:10 PM
degfu's Avatar
degfu
Of course this is an ECM feature but ProCharger is not using HP Tuners. This feature was added by ProChargers tuners.
Old Aug 6, 2023 | 02:01 PM
DSteck's Avatar
DSteck
It was added by Trifecta.
Unfortunately, GM doesn’t use the term “launch control” to really define it, but I’d imagine HPT can locate the necessary tables.
Old Aug 6, 2023 | 06:14 PM
OkieVette84's Avatar
OkieVette84
But... is it dynamically adjustable like the Z06? Or need to plug in HpT and have laptop etc
Old Aug 6, 2023 | 10:19 PM
degfu's Avatar
degfu
I was hoping to find out this answer but he pulled the post before I could ask. Hopefully he will repost it soon, so I can ask further details.
Old Aug 7, 2023 | 07:17 AM
OkieVette84
My understanding is this is only via laptop/tuner-port. Which is cool, but not super effective for making adjustments for tire/track fine tuning on the fly like the Z06.
Old Aug 7, 2023 | 02:20 PM
degfu's Avatar
degfu
He just reposted the video.
https://fb.watch/mgXPJf2I7t/?mibextid=cr9u03
Old Aug 7, 2023 | 04:25 PM
degfu's Avatar
degfu
He said it can be controlled and adjusted to any RPM setting via steering wheel controls (I'm guessing the range is set in the ECM or TCM)
Old Aug 7, 2023 | 05:00 PM
Dirtnap_TX's Avatar
Dirtnap_TX
So he says there are normally two launch rpms? 1700 and 3500 rpm? I've only seen the 3500. How do you get the 1700 rpm mode?
Old Aug 7, 2023 | 05:05 PM
123sugey's Avatar
123sugey
Dig
sounds like just simply power taking the car
Old Aug 7, 2023 | 05:42 PM
Fore58's Avatar
Fore58
Just press the brake pedal firmly not hard and will commence the low rpm. I did this at the track by mistake and ended up with a much higher ET.
Old Aug 7, 2023 | 07:17 PM
OkieVette84
That's counter to what I've been told. Keep us posted. ive been told its very buggy and its not adjustable outside of laptop/tuning screens.
would be exceptional if its via steering wheel controls under the performance menu.
To ProCharger is adding variable launch RPM
