Sponsored by: CARiD
GO go Gadget Cammed C8
Old Aug 12, 2023 | 10:12 PM
OkieVette84's Avatar
OkieVette84
Default GO go Gadget Cammed C8
Not sure if this link works. Boost District Cammed C8!
Facebook Post
Old Aug 12, 2023 | 10:29 PM
Kracka's Avatar
Kracka
That sounds horrible! I just had my wife listen to it too and she said it sounds like a beater pickup or tractor. Hard pass.
Old Aug 12, 2023 | 11:03 PM
Kirito's Avatar
Kirito
Yikes, that sounds godawful...
Old Aug 12, 2023 | 11:10 PM
123sugey's Avatar
123sugey
Dig
I’m thinking and pretty sure it has headers and cat deletes with stock NPP
a little rev above idle and a full rev would be nice
Old Aug 12, 2023 | 11:13 PM
Kirito's Avatar
Kirito
Just let the wife listen to it and her first words were that it sounded like an old tractor, lol.
Old Aug 13, 2023 | 08:22 AM
combatninja's Avatar
combatninja
Really hope they release some power numbers for this. You know any other specs of the build? Headwork to go with it or just a cam?
Old Aug 13, 2023 | 09:14 AM
OkieVette84
I think the plan is to start tuning/testing it and releasing Dyno vids/sounds/power levels mid week or by next weekend.
I don't know what all has been done to the car, I believe it already had some head/valve-springs work before the cam, along with some exhaust. I will ask them to post all the mods when they post their Dyno stuff.
Old Aug 13, 2023 | 09:15 AM
OkieVette84
Lol! this is what my friends with 911s say about my car and it has no cam... haha long live the small block truck mow-der!!!
For more exciting "truck sounds" here is a youtube video with a 1200HP tractor mow-der by Peitz
Old Aug 15, 2023 | 12:09 PM
d16dcoe45's Avatar
d16dcoe45
Sounds a little better than stock, The stock LT2 with an open exhaust sounds like an idling fishing boat in shallow waters. Sounds lame. At least that cam sounds SLIGHTLY better than stock.
Stock cam has minimal overlap, high LSA and not much lift. If GM could put a larger cam in it stock and not trip the misfire monitors they would in a second. It makes ok power because of compression, displacement, head flow and direct injection. Put a real cam in an LT2 and it will scream.
When I had my LS3 with an open exhaust, I used to be embarrassed to be advertising the fishing boat stock baby cam idle. When I stepped up to a GPI NFC 4, it sounded aggressive and mean. NOT like a trawler!!
Old Aug 15, 2023 | 12:35 PM
DomLS3's Avatar
DomLS3
That sounds awful. Almost like it's untuned. If that's what they're using to advertise their cam package... oof.
Old Aug 15, 2023 | 02:37 PM
OkieVette84
First starts tend to be un-tuned by default...
Looking forward to hearing it at WOT and on dyno.
Old Aug 15, 2023 | 04:00 PM
combatninja
That lope sounds as though they are taking it right out to the edge. It sounds like with another couple of degrees of duration that it would stall. Curious to see the dyno graph. How much high end does it gain and how much low end does it sacrifice?
Old Aug 22, 2023 | 01:14 PM
OkieVette84
https://www.facebook.com/reel/990168...ibextid=3uyXbM
Just saw this on BD Facebook. Looks like 88rwhp gain
Old Aug 23, 2023 | 08:10 AM
RedTRex's Avatar
RedTRex
That sounds better. See $10.5K for price (to start) in the link
Old Aug 23, 2023 | 03:18 PM
INTRUDR's Avatar
INTRUDR
Tractor w 1200HP
I think this is the exhaust
Love the Peitz Twin Turbos + Lopey Cam Sounds. Hot Rod on Steroids !!!! Performance is fantastic too...
Old Aug 23, 2023 | 03:48 PM
INTRUDR's Avatar
INTRUDR
Another Peitz Cam + Turbos example:
View this post on Instagram
HP Tuners has opened up a Whole New World. Very exciting to see how quickly the tuning community is taking advantage of access to an Open ECU.
Old Aug 23, 2023 | 09:07 PM
OkieVette84
The fact GM locked down the ECU like they did doesn't make a ton of sense to me. Seems like a lot of wasted effort and R&D on their part.
To GO go Gadget Cammed C8
Old Aug 24, 2023 | 11:32 AM
Racer X's Avatar
Racer X
Cars have internet connections that can change programming, They have automatic braking systems, they have electric steering and brake boost and can automatically steer. There have been years of people tuning their cars, breaking them, and setting the tune back to stock to get them fixed under warranty.
Yeah, locking down the ECU doesn't make sense unless you want to avoid massive warranty claims, and potentially billions of dollars of lawsuits when people realize they can kill someone by hacking their car remotely, or causing chaos in cities by shutting cars down on major roads.
Do you leave your home and work computers unprotected?
Old Aug 25, 2023 | 09:24 AM
OkieVette84
really good points. I bet there are potentially unexplored ways to mitigate some of the legitimate existential threats without locking down the entire system.
For example: put safety related fly-by-wire type systems on a dedicated board with all the hardware lockouts and leave the performance stuff up for grabs to do tuning. I'd also bet there is a way to trigger some kind of "has this ever been tampered with" to alleviate the 'reflash and take back to dealer' issue you mentioned. With the amount of engineering that went into locking down the whole thing... I would make a $1.00 bet with the kind of mindset I mentioned above, it could be done and accomplish both their strategic/risk-management goals and also satisfy the tuning/aftermarket world.
Old Aug 25, 2023 | 10:16 AM
Racer X's Avatar
Racer X
But what is the financial incentive for GM to go to extra cost to do to partially undo their security efforts? You are thinking like an enthusiast, not a GM lawyer or CFO. Remember the benefit to GM has to be greater than the risk.
