Sponsored by: CARiD
Transmission Filter Change
Old Nov 6, 2023 | 09:28 AM
Woodstoc's Avatar
Woodstoc
Default Transmission Filter Change
I know the first transmission filter change is on GM, but I had to have a replacement transmission and they won't cover the filter on this one. One per car apparently as opposed to transmission. At any rate the amount of money the dealerships want is obscene for this fairly straightforward service that you should do every 7500 miles. I will be doing this myself going forward. The only pain with this is the multitude of bolts you have to remove to get the two panels removed to get to the filter. In addition, there are several different sizes you have to get back right.
My question is has anyone, when they had the aluminum panel down, decided to cut out an access to the transmission filter? The oil filter has one and I'm considering doing this to make future filter changes a breeze like the oil filter.
Old Nov 6, 2023 | 09:34 AM
Bburr's Avatar
Bburr
You did not mention the computer generated flush procedure for the DCT.
Old Nov 6, 2023 | 09:41 AM
Mike's LS3's Avatar
Mike's LS3
I not 100% sure, but they need access to the side fill plug to put back the few ounces of DCT fluid loss when replacing the filter. I believe the panel needs to be removed for access of that plug.
Old Nov 6, 2023 | 09:51 AM
RKCRLR's Avatar
RKCRLR
The mileage requirement to change the DCT filter is at 7500 miles, 22,500 miles, and then every 22,500 miles thereafter so it really isn't that often. The fluid needs to be topped off and checked so just a hole for the filter isn't enough. But the big problem is a hydraulic system flush needs to be performed prior to filter removal (at least if you're changing the filter to comply with the maintenance requirements) and, so far, only the GM MDI tool can do this.
GM should cover the first DCT filter change on the new DCT. It isn't your fault it failed. Contact Chevrolet Customer Care and have them open a case if your dealer won't do it.
Old Nov 6, 2023 | 09:55 AM
Kracka's Avatar
Kracka
There was a document circulated that the 7,500 mile filter change on a replacement transmission is the customer's responsibility, if they already used the one complimentary service.
Old Nov 6, 2023 | 10:04 AM
RKCRLR's Avatar
RKCRLR
That doesn't seem right but I guess it could be. Adding insult to injury. Our part failed under warranty so it is going to cost you extra to maintain your warranty. I'd still contact customer care to see if they could do anything.
Old Feb 1, 2024 | 05:37 PM
HRDTOPC54FUN's Avatar
HRDTOPC54FUN
If you miss/exceed the 7500 +/- 500 filter/flush procedure the normal corrective action is:
1. Remove and discard the existing filter
2. Install new filter and perform the GM solenoid flush procedure. This will contaminate the new installed filter.
3. Remove and discard the contaminated filter, install new fresh filter. Top off fluid level. Good to go.
You mention your C8 is a 2020. Depending on when your car was built you are at the time when a complete fluid change is required (36 months form build date). So, I would expect step 3 above would now include a complete 12 qt DCT fluid change.
From what you describe, it's doubtful the DCT filter/fluid issue is causing your shifting problem.
Good news is you are still under warranty.
Good luck. Hope this helps a little.
Old Feb 5, 2024 | 11:05 PM
Michael A's Avatar
Michael A
This is absolute BS that you have to go to the dealer to flush your transmission, when the entire process is done in software. Put the flush procedure in the infotainment system under the Vehicle section.
Old Feb 6, 2024 | 12:12 AM
MarkMeHopeful's Avatar
MarkMeHopeful
2022 C8 of the Year Finalist - Modified
I've seen you say that in two different threads now. Why would GM put that procedure in a system accessible to any yahoo who can press a button? I hear what you're saying but GM has no incentive to do it and it would probably do more harm than good if they did.
Old Feb 6, 2024 | 10:21 AM
Andybump's Avatar
Andybump
I won't share a view on whether or not it should be in the vehicle menu. But I will point this out. As far as I can tell the Hydraulic System Flush procedure in the Service Manual is never a standalone procedure. In fact, in the HSF, it always says, do not perform this procedure unless directed here from another procedures. It is called out from the routine DCT filter change procedure (as most know) and also called out in the context of various diagnostic procedures or service bullteins. It is typically preceded by and/or followed by other steps - such as changing the DCT filter.
It suggests that it could be harmful when not performed in the context of another procedure.
Old Feb 6, 2024 | 10:31 AM
RKCRLR's Avatar
RKCRLR
Yep, when I brought my car in for the "free" engine oil and DCT filter change the dealer reset my DCT fluid life monitor...
Old Feb 10, 2024 | 01:14 PM
bluekey28's Avatar
bluekey28
Default First Free Service
Same here.
Old Feb 10, 2024 | 01:24 PM
Andybump's Avatar
Andybump
Originally Posted by bluekey28
Same here.
Thats a bummer. Did not happen to me, but would not matter since my fluid change will be at 3 years and the FLM doesn't factor that in anyway.
I was just checking my warranty tracker data and noticed something important. Apparently the delivery date and start date for the warranty was entered by the dealer and recorded some 10 days before the car was delivered. It appears to match a date on the dealer invoice (I have a copy of that). But its not the date when I paid for the car and drove it home. I suspect that means the start of the 3 years for the fluid change is also 10 days earlier. I have other service records where the dealer put the correct delivery date on the service invoice so something is screwy. Anyway I'll just make sure its changed before that recorded date in the record. Hopefully though, as with the first filter change (prior to the later clarification) there is some unwritten tolerance on performance of the require maintenance.
Old Feb 10, 2024 | 02:15 PM
RKCRLR's Avatar
RKCRLR
Yea, it didn't matter for me either because of the 3 year requirement. I didn't even mention it to the dealer.
I'm sure there is some leeway of the 3 years. I brought my C8 in for a last repairs just before the expiration of the 3 year B2B warranty which also coincided with my required oil change. I told the dealer I was going to do oil and fluid changes myself. The dealer was waiting for a response from GM on one of the issues and it took GM a couple of weeks to respond. So both were past the due date when they returned my car but they told me not to worry about it, GM gives a lot of leeway on it.
Old Feb 10, 2024 | 07:18 PM
Michael A's Avatar
Michael A
How is that going to harm anything? All it does is flush debris into the filter, which is where you want it anyway. Then replace the filter. This is not rocket science. If anyone does any harm, it is usually the dealer, anyway.
People should not have to drive sometimes hundreds of miles, wait around for hours in a waiting room, and pay $800 just for a "transmission flush". Their incentive is to have happy customers. There may be some laws either pending or on the books where manufacturers must allow third parties to perform service and repairs. That may be an incentive forced on them.
Old Feb 17, 2024 | 12:21 PM
Red Mist Rulz's Avatar
Red Mist Rulz
Given that GM wants the filter changed immediately after the flush, and sometimes before the flush and then again after, I can easily image idiots "flushing" the DCT so often the filter gets clogged and the bypass valve opens, leaving unfiltered fluid circulating for perhaps thousands of miles.
Third parties can purchase a license for the GM software required to do the flush, so GM already meets that requirement. Independent shops that do a lot of GM business probably already have that license.
Old Feb 17, 2024 | 06:24 PM
22c8z51's Avatar
22c8z51
Apparently unfiltered fluid circulates anyway, since you need to flush it out of [wherever it has accumulated] and into the filter. Seemingly preposterous design.
To Transmission Filter Change
Old Feb 17, 2024 | 07:41 PM
Andybump's Avatar
Andybump
Interesting perspective. Since we describe the HSF's purpose to move debris from the lines and valves to the filter (which traps them?) prior to replacing the filter. If they went through the filter then wouldn't they go through it again? So, maybe there really is another source of debris then? Maybe we do not have a full understanding of the what the HSF does? Or, maybe there is an unfiltered path? Or maybe there is a source of debris downstream of the filter. Or maybe the HSF is not really needed after the first time, but it is in there anyway. Or.....?
Old Feb 17, 2024 | 11:48 PM
Mitchell_B's Avatar
Mitchell_B
As has been stated many times before, the DCT filter is severely undersized. Because of this, on every cold start when the fluid is cold, the filter bypasses until it warms up. This is why the trans fluid must be above 140 degrees to run the HSF procedure. GM won't tell you this and a few other things about their DCT. What owners should be thinking about is the cost of a replacement transmission when the car is out of warranty and how long will it take to get a replacement unit?
Old Feb 18, 2024 | 08:06 AM
Mitchell_B's Avatar
Mitchell_B
Debris collects in the valve body solenoids where it stays until it is flushed out. Even if the filter were to never again go into bypass, the debris collects and stays in the valve body until flushed. And the problem with this is a solenoid malfunction might result in two gears being engaged at the same time. When this happens, the transmission immediately destroys itself. This is why the DCT sometimes drops either odd or even gears when it detects an internal pressure fault. This is the control system's way of protecting the DCT. Sometimes it saves the unit, sometimes it does not. Most of the time, GM wants the valve body changed because the cost for this is much lower than changing the unit. If the unit suffered no internal damage, a new valve body might fix it.
The best way to circumvent DCT problems is to regularly change the filter. Best possible course of preventive maintenance action would be to periodically run the flush procedure on a new filter and then replace that filter with a new one.
