Turn off Big Brother
Sorry, if I could make this font 100 times bigger, I would.
174 pages. And this is a Billion dollar company just pushing paper?? May God help us!
Ok, getting ready to put a dummy load, i.e., a 50 Ohm resistor on the antenna connector on rhe passengee side. DAMMIT, the great farmers that own John Deere tractors are dealing with a similar issue of "EXPLETIVE Big Brother interfering with machines that they purchased" to get repairwd..
I am an electrical engineer: have patents. If I need to be I can put a relay rhat is actuated from the cockpit to selectivey apply the dummmy load resistor to tbe transmitter's output. ([This will insure that the tranwmitter's output device [[a RF semiconductot willnot b3 d3stroy3d, i.3., fri3d]] BUT again like a pr3vious pistee said, the circuit can survive with the coqx [connecti9n] being disconnected. Well, great.
I KNOW WHAT FREEDOM IS: ME AND MY DAD WALKED DOWN FROM THE TOP OF THE WASHINGTION MONUMENT.
EVERYBODY IN MY FAMILY WAS A COMMISSIONED UNITED STATES ARMY OFFICER and I am extremely proud of that.
apo,ogize for mis-spell8ngs, as usual the phone's keys are small for the edges of my fingers.
Amazon and others sell Faraday bags to block your phone signal, laptop….. anything. So you can carry electronic devices without being tracked.
Using foil etc partially blocks the signal but you need something specifically designed to block the signal.
I’m still considering that but in the meantime I called Onstar, followed the instructions from other posts and had Onstar turn off SmartDriver then disconnect my car. They did exactly as I asked. No argument. No bullshit.
And I recorded the conversation in case they somehow change their minds or forget….
1. You're in law enforcement
2. You've had your identity stolen
3. You're in danger from another
2 and 3 require you to submit a police report.
In the other thread, people have said they aren't just turning off OnStar, they never had an active subscription to start. They've had success in getting Chevy to completely disable it so it's not reporting to Chevy either, supposedly. No way to really know for sure without sniffing the traffic leaving the car which is likely encrypted.
Android gives you the same options as far as apps go. But those are only for the app, not the operating system. Android OS is always tracking you. Even if you turn off the GPS receiver, it tracks you based on cell towers and known WiFi hotspot locations. Turning location off in an app doesn't stop Google (or Apple) from knowing where you are via the OS. I know Google does this no matter what you turn off. I don't know if Apple truly respects your choices to not be tracked, but I suspect you have to make sure you turn it off in every place the option exists to avoid it.
https://imgur.com/gallery/n00QKnH
there is a "Step by Step Guide to Disable OnStar on a 2022 Chevy Bolt" in which the disablement method is to remove the antenna connections to the telematics module and terminate the connectors with 50 ohm resistors. In fact the author of that post even sells premade 50 ohm loads with proper connectors for the purpose.
However, at least in the Toyoto Tacoma, the simple disconnecting of the antennas will not suffice to stop data transmission. According to a couple of very lengthy and thoughtful strings (15 pages total so far) on a Toyota Tacoma discussion group, at
https://www.tacomaworld.com/threads/...module.794817/
and
https://www.tacomaworld.com/threads/...tennas.821649/
1) Considerable data is stored in nonvolatile RAM in the module--at least 6Gb--to hold at least a year's worth of data; the module save the data until it can be transmitted. It's not clear whether the data is erased thereafter.
2) Removing the antenna connections does not completely stop data transmission because the module can transmit/receive even if signals are very weak
3) Adding a 50 ohm load to the module output at the disconnected antenna terminals might not be necessary because the module itself may detect shorts or opens on the antenna ports to allow it to shut itself down to prevent damage;
4) Data can be transmitted even if both the module is wrapped in grounded aluminum foil and the antenna ports are terminated with 50 ohms.
5) One certain way to prevent transmission is to remove the SIM card in the module, which lets the module connect to the cellular network. However, that's not an easy project and these days it's likely that an electronic SIM is used, so the SIM data is in part of a nonvolatile RAM.
6) Another certain way to prevent transmission is to remove power from the telematics module, most easily done by removing the relevant fuse. Apparently in the Tacoma the only negative effect of depowering the module is that the Bluetooth microphone is lost (The telematics module takes control of the microphone so a driver can send a verbal SOS in case of accident). Possibly the effect in the Corvette would be the same, but I have seen no reports of the effects of simply removing the fuse in a Corvette on this forum.
7) The Tacoma discussion has a link to a device on Amazon that can be used to switch the fuse in and out of the circuit, so you only have to access the fuse box once if you want to occasionally restore the Bluetooth microphone.
Personally I find the Bluetooth microphone useful for telling my phone's nav system, through Android Auto, where I want to go. Owners of '24 Corvettes who are paying the monthly Google ransom can also use the microphone to control certain other functions.
Maybe readers of this Corvette forum can pitch in with their own research results and actual experiences.
I suggested an eSIM was likely being used, in which case the only real option is to remove power to the power amp (PA) and ground the output or cut the output trace. Since the telematics module is used for more than just sending this data out, removing power to the entire module is also not a best solution.
bummer.
i suppose the question then becomes exactly what else do we lose if one were to really, really completely block the antennas from transmitting?
bummer.
The telematics module can be disabled by pulling the power connection from the box. The box is under the dash on the drivers side - it does not look like it is difficult to access. It is possible that with it powered down, it may set DTCs which prevent other things from working - that is why it would need to be tested.
To test this, you can pull a fuse that powers the telematics box. That same fuse will also disable the HUD. But for purposes of the test you can overlook that. If the test is successful, then you can disconnect the power at the box and put the fuse back in so you have the HUD. So. its fuse 34 behind the glove box. Power down the car first, and leave it set for a few minutes or verify that the Retained Power Accessory feature is inactive. Then pull the fuse. The reason for making sure its powered down is because there is a back up battery in the telematics module. Once it is triggered, it will continue to discharge until it is fully discharged.
