Sponsored by: CARiD
Engine lugging in V4 mode
Old Jun 25, 2024 | 01:17 PM
  #41
Andybump's Avatar
Andybump
Originally Posted by Acpantera
That's what I'm talking about, thanks Andy, nice find.
Someone else posted the link either in this or another thread. I just saved it when I saw it. As you can probably tell, I save stuff.
Old Jun 25, 2024 | 04:58 PM
  #42
Joe C5 C2's Avatar
Joe C5 C2
I had my C8 out yesterday and picked a flat road with no traffic to try and duplicate what this topic is about. At 55 mph in auto the car was in 7th gear and just before the trans needed to go to 6th I could hear a deep harmonic rumble from the exhaust. There was no knock or ping, just that very short deep sound from the exhaust. I really think this is what people are actually hearing and it is the nature of the exhaust system. I will also agree with what was said above about getting on it to clean things out. Over on the Ferrari Forum it is known as an Italian tune up. Maybe we should call it a "Merican Tune up".
Old May 7, 2025 | 03:03 PM
  #43
Orion2011's Avatar
Orion2011
Update in OP.
Old May 8, 2025 | 10:55 AM
  #44
undecided1965's Avatar
undecided1965
Default Link for that?
Originally Posted by Orion2011
I have a 2024 C8 and the AFM sometimes gets in a situation where I can hear the engine lugging. If you ever owned an old school manual and tried to accelerate in too high a gear, that noise.
It happens somewhere between 1000 and 1500 RPM at low load. I can get on the gas or get off the gas to stop it. Anyway...
Is there any known solution for this besides running in Manual or Track mode all the time? I don't mind AFM except for this issue. I know it's not healthy for the engine. Pretty sure it's low speed knock. When the warranty is out I will get the ECM unlocked and turn AFM off if there isn't any other options.
Update. I have determined it is not coming from the engine, it's some sort of rattle. Doing some research it seems C7's had a similar issue that was usually related to a weak serpentine belt tensioner.
Because it could definitely be something like that but why would it coincide with V4 mode? I mean it also chirps in V8 mode but much less frequently.
Old May 8, 2025 | 11:08 AM
  #45
Orion2011's Avatar
Orion2011
Originally Posted by undecided1965
Because it could definitely be something like that but why would it coincide with V4 mode? I mean it also chirps in V8 mode and much less frequent.
I think there are more vibrations in V4 mode that tax the belt tenstioner.
Old May 8, 2025 | 11:55 PM
  #46
MarkMeHopeful's Avatar
MarkMeHopeful
2022 C8 of the Year Finalist - Modified
Originally Posted by MarkMeHopeful
I agree with both of the above. The C8 will NOT lug - if it does there is something wrong and you should take it to the dealer. However, if you are not accustomed to the C8 and AFM mode you might be hearing the normal AFM sounds. Lugging is something you can feel as well as hear and the computer in the C8 will not allow it unless something is wrong.
I will quote my post #9 again, since it has been almost a year and the discussion is still going.
Old May 9, 2025 | 07:15 PM
  #47
undecided1965
Default There's 3 reasons for the continuation
1. We still have the issue
2. Something may be wrong but it's not obvious what hence the questioning & discussion
3. Dealers are incapable of helping on something like this
