Sponsored by: CARiD
C8 Tuning
Old Jul 14, 2024 | 06:30 PM
  #41
Fore58's Avatar
Fore58
Originally Posted by combatninja
What are we even arguing about?
I hope we are not arguing......I don't roll like that sir. The numbers that I have given you is also an indication what the C8 is capable of with bolt-ons. That's it.
Old Jul 14, 2024 | 07:00 PM
  #42
Snowblind2.0's Avatar
Snowblind2.0
That's a very interesting timeslip. The fact that you both ran 24 mph on the back half seems really odd. Why would a car with about 150 more HP not realize that power advantage on the top half ? He was reeling you in some, but I thought he would have come in harder.
Old Jul 14, 2024 | 07:20 PM
  #43
BJ67's Avatar
BJ67
Hey fore58, my thoughts on this is that the Z06 launch to control system is not as easy as the stingray to dial in, with a precise dial in and set up on the Z06 to at least achieve a low 1.6s 60 ft time (match a properly set up and with tires stingray) the Z06 should be/will be tuff to beat with a skillfull driver. BTW, you are doing a good job getting close to a properly set up and driven Z06s performance.
Old Jul 14, 2024 | 07:28 PM
  #44
BJ67's Avatar
BJ67
Its not a strong running Z06 for what ever reason is my take, properly set up and driven, those cars should be trapping 130mph.
Old Jul 14, 2024 | 07:47 PM
  #45
Fore58's Avatar
Fore58
Yeah...I was hoping that he got a decent 60ft time on me. He ran 10.72 earlier that day with a 1.6 60ft time. He now has a red mist convertible and that thing pulls hard...... low 10.70's first time out.
And agree with you 100% sir. Thanks
Old Jul 14, 2024 | 08:18 PM
  #46
Fore58's Avatar
Fore58
Yeah Snowblind......my C8 didn't have enough horsepower at the topend.lol. I have another video where you could see the entire holeshot from the sideview. My friend Z06 started to reel me in just after 1/8 mark. But the little convertible was fighting to the end and that's when he passed by me with that topend. I was first at the end probably a fender......so close. Those Z06s in stock form from what I have observed are trapping between 126 and 129 at our track.
Old Jul 26, 2024 | 01:18 PM
  #47
Revmanii's Avatar
Revmanii
I don't have an after market intake or exhaust but would really like to eliminate AFM. From lookig into it, the only place I've found is Paragon and would cost about $3k.
Old Jul 26, 2024 | 01:29 PM
  #48
BJ67's Avatar
BJ67
I agree on the elimination of AFM. But why stop there, the lengthy high rpm cold start can be adjusted, and have it dyno tuned on 93 the same time . You also end up with a MPVI3 HP tuner, scanner and can data log while you drive.
Old Jul 26, 2024 | 01:38 PM
  #49
mmthomas's Avatar
mmthomas
I have asked this question on other threads/forums and no one seems to know:
Does the C8 6.2l ecu have channels to drive additional injectors?
and
Can we raise the rpm limit?
Old Jan 18, 2025 | 03:51 PM
  #50
jjk2509's Avatar
jjk2509
In your opinion, if hfc, tb and intake are added to a C8 Z06, will the car run trouble free without CEL coming on?
Will the car need to be tuned when available to perform properly?
Thanks,,
Old Jan 18, 2025 | 08:19 PM
  #51
itsonlyairandfuel's Avatar
itsonlyairandfuel
You guys can say what you want. Here's something to consider when you think your bolt-on Stingray can hang with a Z06. Take a 50mph roll starting in 3rd gear. You both hammer it and are pretty even. The Stingray (let's assume it is Z51), has to shift to 4th at 83mph. Just when you were feeling good about yourself, you have to shift to an overdrive gear, Uh oh. The Z06 can stay in 3rd, wait for it......all the way to 105mph. This is a problem. You have to shift at 115 to 5th and you know the party's over as the car truly falls on its face. Z06 guy can stay in 4th almost until you are out of 5th. The ability of that car to rev is a huge difference maker. It is simply not possible for a car with less than 500whp and a 6500rpm redline to walk a car with 600whp and an 8600rpm redline. The more powerful, higher-revving car has more aggressive gearing to boot.
I know someone is going to chime in immediately and talk about how from a dig the LT2 has enough torque to reverse the rotation of the Earth. Fine, it might get the jump but the Z06 will catch it halfway through 2nd gear.
Best to start a 50mph roll, at 5300 rpm in 2nd gear, 3rd would be way below the optimum torque. As soon as we get good weather, I will try to get draggy numbers for both cars. A roll will greatly benefit the Z.
Old Jan 20, 2025 | 10:30 AM
  #52
Orion2011's Avatar
Orion2011
Get the ECM unlocked. No doubt it Uses a Neural Network, if so HP Tuners will have a Neural Network trainer you can use.
Old Jan 21, 2025 | 12:58 AM
  #53
OLD_GOAT's Avatar
OLD_GOAT
Yes, but I believe you have to paddle shift when the rpm limit is raised. Peitz raised my rpm limit when he tuned my car.
