Sponsored by: CARiD
2024 C8 Window Indexing
Old Aug 11, 2024 | 05:14 PM
Sweptclean's Avatar
Sweptclean
Default 2024 C8 Window Indexing
I have read and re-read the instruction manual, and tried to re-index my windows: Close window, continue to hold up button for several seconds, open window, continue to hold down tab for several seconds, all to no avail.
Is there something I am missing, something else I need to do ?
Help !
Old Aug 12, 2024 | 12:06 AM
MarkMeHopeful's Avatar
MarkMeHopeful
2022 C8 of the Year Finalist - Modified
Yes, that's the way it's done. Why do you think it's not working? What are you experiencing?
Old Aug 12, 2024 | 03:32 PM
Sweptclean's Avatar
Sweptclean
I am having difficulty in closing the driver side door. I have to really pull on it to close it, or slam it hard from outside when closing. Looking at the glass when the door is open shows it is all the way up, which will make it bind against the rubber trim. I have tried to re-index with engine off, engine running, and no avail. Thought there may be something in the settings that would be preventing me from indexing properly.
Old Aug 12, 2024 | 08:18 PM
MarkMeHopeful
Have you looked through this thread?
https://www.corvetteforum.com/forums...-to-close.html
Old Aug 15, 2024 | 01:04 PM
Sweptclean's Avatar
Sweptclean
Certainly have. Still, no fix.
Old Aug 15, 2024 | 02:43 PM
Arizona Jim's Avatar
Arizona Jim
I recently indexed my windows after installing a new battery as follows (per manual)
lower window part way
raise window and hold the button up for several seconds
lower window all the way down (I did not keep holding the button down)
Old Aug 15, 2024 | 02:55 PM
mikegr's Avatar
mikegr
I would also suggest a battery disconnect if not tried already, it forces you to walk through re indexing when connecting the battery back.
Old Aug 15, 2024 | 11:58 PM
MarkMeHopeful
Well, since it is a 2024 you might consider the last resort solution - take it to the dealer and use your warranty!
To 2024 C8 Window Indexing
