first oil change
I'm really tired of all the chicken littles running around.
If it ever goes 7500 mi before a change it will be because I'm dead and or don't own it anymore.
I simply don't believe in going that long and since I can afford it I don't have to. I doubt I will ever go over 5000 mi.
We can debate whether 7500 is too long between changes but one thing is 100% certain, it can't hurt anything doing it sooner.
I changed it last week for the first time at 780 mi and will get the oil analysis report in a few days.
The answer to your question Thayne is Now!
Your cars first oil change is the most important it will ever have. This is not speculation it's science.
Don't take my word for it. Spend 30 min listening to a professional Tribologist prove it with facts and science.
What is a Tribologist you say? Good question.
(A tribologist is a professional who studies how surfaces interact when they move relative to each other. Tribologists use their knowledge of friction, wear, and lubrication to understand how objects behave when they are in motion. They apply their expertise in many fields, including mechanical engineering, chemistry, and physics, to solve real-world problems.)
Start with a quick one on his Qualifications: https://youtu.be/AVipfCRlpzk
Then the science and data of why the first change early is important: https://www.youtube.com/watch?v=_6nWCQ_70J0
One statement he makes that is important to remember, the oil filter does NOT capture all of the break in contaminants that will be circulating for that 7500 miles!
Nope for the C8, as C7 as C6 ONLY the OLM should be used. It gives a % oil life left if you want to look. It's a very sophisticated systems, monitors oil temps after cold starts for example. If the oil does not get hot enough long enough to evaporate much of the water of combustion that passed the cold pistons it will have you change oil earlier than the max time it will allow, 12 months! Yep that water forms with sulfur in oil and fuel and forms sulfuric acid. That eats metal when parked!
At ~10% Life left the OLM will display that # to the right of the dash. Each time you start it will show the lower number. MUST press OK to dismiss message. Can't miss it! Can always change sooner and reset the OLM, up to you!
PS: See my post #17!
Edit: I should add, the contaminants reported on this forum in the early oil changes that are higher during the break in period are mostly chemical contaminants - not things that will be removed by the oil filter, but potentially harmful to the engine if that contamination level was too high, for too long.
I'm thinking that the majority of owners simply follow the recommended schedule and no more, and there is scant evidence that more frequent changes extend the life, performance or efficiency of the engine vs mileage. I do not fault those that want to change the oil more frequently - and do those analyses - I have learned a lot from reading those posts. And, in some of those cases, the result has detected an actual engine issue. I'm just saying there is plenty of evidence that the contamination level is higher during break in.
Thanks for your posts though, they really added a lot to the topic!
I drove my new car home (4000 miles across the USA) then changed the oil, and then at 7500 let GM change it again, so I split the 7500 with 2 changes.
I don't drive my C8 in bad weather, so I only drive 4000 miles a year, and that is a good interval for a change.
If I drove 7500 per year, I would probably change it mid year. I like to know there is clean oil in there when I am hitting the 6500 redline.
An example of a way to show that would be to run two identical engines, change the oil early and frequently in one, and stick to the 10000 mile (in his example) change in the other. Then take the engines apart and analyze the wear.
Another way, not as invasive, is to run one engine to the full 10000 miles before an oil change, then find a way to measure/estimate the total mass of those contaminants that he says are indicative of engine wear (iron, aluminum, nickel, copper, or whatever is relevant to indication actual wear of metal parts). Then do the same with a different car, with early and more frequent oil change, but estimate, at each change, the total mass of shed wear indicators, and add them up for the same 10000 mile period. Then compare to see if the total mass of shed contaminants that indicate engine wear is less with the early and more frequent oil changes.
Yep, the presence of molecules of chrome, nickel, iron, etc does not mean they are causing wear. It reflects what is wearing not what is causing wear. Yep, if you have a fleet of the same type truck, oil analysis can define if one is having a rocker arm wearing excessively for example. May have to do with an alignment issue but is not a cause of wear.
In my former life we had many tractors that pulled trailers of liquid atmospheric gases. Being identical diesel engines oil analysis was useful defining when an overhaul etc was needed.
The video person was a "certified lubrication specialist" and spoke of his racing experience and how they formulated oil for racing. So in that application, they may well get to see rapid degradation of engines in single race event, and get meaningful data regarding the impact of lubrication related wear on race performance. How does that translate to street use?
Oh wait, I guess you didn't or you would know he has forgotten more about oil, lubrication and engines than you or I will ever know!
All myself and the folks that agree with me are saying is for less than $100 and in the first 1000 miles we can be sure a majority of initial wear particles are removed. Why take a chance with an $85k car that may be kept for a long time when you could help it's life with something so inexpensive?
It's not rocket science it's common sense to me. You fellows want to keep the likely contaminated initial fill in there for 7500 miles be my guest. Gm will never complain if we change it early.
So let's just agree to disagree.
Nobody said that the heaviest level of wear isn't during the initial break in. The oil analysis shows that the shedding rate of wear indicators is highest during break in. That is going to happen throughout the break in period whether the oil is change or not and its because the parts themselves are mating, wearing down the asperities , one could say. Whats not shown in the video, and what is typically not proven, is that getting those out of there at 500 miles instead of 7,500 miles makes any significant difference in engine wear, resulting longevity, power, efficiency or what ever measure one is trying to improve.
Lots of folks think it does, and change oil more frequently. The majority of owners do not. I typically observe the recommended oil change schedule, and I typically run my daily drivers well over 100k miles, and have not had engine problems.
Comparison of actual engine wear after 7500 miles with and without the early and more frequent oil changes during the break in would go a long way to making the point. Or comparison of compression ratio, oil consumption, whatever. Anything like that. The video only asserts that the wear indicators contribute to additional wear. Yeah - "common sense" says the accumulation of those wear indicators contributes to additional, but how much additional wear? Can it be measured? Or is it negligible?
Add: I neither agree nor disagree as to how much additional wear results if the oil is changed at 7,500 miles (or when the OLM says so) and whether that difference is signficant, when compared with the wear the results with early and more frequent oil changes, because there is no supporting information either way.
Here we go again. Everybody is an expert except the people who design and build the car. Old schoolers don't believe that technology has improved.
