Sponsored by: CARiD
Soler Throttle Controller install question - Stingray
Old Nov 15, 2024 | 09:08 AM
24c8's Avatar
24c8
Default Soler Throttle Controller install question - Stingray
Most of the installs I have seen the wires and controller sit between the carpet and the gas pedal. can it be hidden under the carpet? If so, any pics and or tips on getting it back there?
Old Nov 15, 2024 | 10:18 AM
Olddudesrule1's Avatar
Olddudesrule1
2024 C8 of the Year Finalist - Modified
Sorry, I'm not home to get you a pic, but it's very simple and straight forward. I did the install on Sunday. Once you remove the pedal from the floor (one 10mm bolt and pull the pedal backward) and disconnect the connector, you'll clearly see the 3" slit in the carpet behind the pedal where the connector wiring runs. After I connected the Soler harness, I just pushed it all behind the carpet via that slit, and ran the small cable for the display up and around the side of the tunnel, hiding the wire between the dash panels as I ran it up below the audio/nav display. Super easy, done in 10 minutes.
There are multiple videos on YouTube on the subject. Download the Soler app to your phone, and you don't even need the display if you don't want it.
Good luck, just go for it!
Old Nov 15, 2024 | 07:51 PM
Red Mist Rulz's Avatar
Red Mist Rulz
Yes, I pushed everything through the slot in the carpet. Nothing visible at all.
Old Nov 15, 2024 | 11:46 PM
MarkMeHopeful's Avatar
MarkMeHopeful
2022 C8 of the Year Finalist - Modified
Ditto
Old Nov 16, 2024 | 08:10 AM
All the above point you in the right direction. You’ll love the throttle controller.
Old Nov 16, 2024 | 04:47 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
I purchased the "Pedal Commander" It is a similar device as the Solar ---- However it has far more adjustability I believe the Commander has 32 different settings
In my case I went str8 to #32 !! The car was un drivable in 1st gear !!! Just way to violent and jerky especially when the engine is cold--- I settled on about 24 and it is Awesome throttle response
According to Pedal Commander the STOCK throttle ratio on a C8 is very lame so the throttle response sucks
They told me the stock Throttle ratio is 1-3 !! Backwards
With the Commander or Solar you can go from 1-3 all the way up to like 3.5-1 !!!
WOW although it adds NO HP the response is amazingly quick
Old Nov 16, 2024 | 11:44 PM
MarkMeHopeful
?What does that have to do with the ability to hide the wires behind the carpet?
Old Nov 17, 2024 | 05:23 PM
FLC6GS's Avatar
FLC6GS
Method I used for the connections behind the carpet and running the USB to the Center Console
Skip to 4:00 Minutes for begin of installation
Old Nov 17, 2024 | 05:54 PM
SteveL2's Avatar
SteveL2
Does this help?
https://www.corvetteforum.com/forums...tall-tips.html
To Soler Throttle Controller install question - Stingray
