Sponsored by: CARiD
Not sure
Old Dec 23, 2024 | 11:44 PM
Can't get right's Avatar
Can't get right
1st Gear
Default Not sure
So basically this is what I'm running at idle probably 35° outside and I had some oil leaking from somewhere but everything's fine oil's full transmission seems fine someone please help it's coming out seems like at the back of the car near the muffler but that just could because you know the wind pushing it back
Old Dec 24, 2024 | 02:34 PM
Andybump's Avatar
Andybump
You will need to provide more info than that. Have you identified what kind of "oil" it is? Have you looked under the car? Was the engine oil/filer recently changed? Did you have other recent service lately? Has a dealer looked at it? Engine and transmission are both "in back" so that is where engine oil, transmission fluid, coolant leaks will be found usually. Brake fluid can leak too. Maybe a photo of the issue? Etc.
Generally, leak requires a trip to the dealer. No matter what it is (unless its just spilled liquid from a recent service), a leak is best addressed by the dealer while under warranty, even if you know where it originates, and how to fix it.
Old Dec 25, 2024 | 10:51 AM
Olddudesrule1's Avatar
Olddudesrule1
2024 C8 of the Year Finalist - Modified
If you're just idling, shouldn't be much wind pushing whatever is leaking out the back. Could it be sooty colored condensation coming out of the exhaust? You should be able to tell what it is by the color and/or smell.
To Not sure
