Sponsored by: CARiD
Lowering Collar Problems
Old Mar 15, 2025 | 12:30 PM
thale's Avatar
thale
Default Lowering Collar Problems
I have a 2020 HTC and we installed the lowering collars on the front and adjusted the height on the rear. everything is installed right but I have a noise when I go over a speed hump....sounds like the shocks are lose and moving,,,,anyone have the same problem?
Old Mar 15, 2025 | 01:48 PM
Chevy Cust Svc's Avatar
Chevy Cust Svc
Thanks for reporting this here on our forum. If you are unable to pinpoint the reason for the noise when passing over a speed bump, it is best to have a certified-GM dealership take a look at it. Should you need assistance connecting with a facility near you, you can email us at socialmedia@gm.com and use your Username/Forum Title in the subject line.
Old Mar 15, 2025 | 02:02 PM
thale's Avatar
thale
Thank you
Old Mar 15, 2025 | 09:57 PM
X25's Avatar
X25
Sr.Random input generator
Well, not sure how it looks like without a pic, but can you increase preload to see if it helps?
Old Mar 15, 2025 | 11:31 PM
MarkMeHopeful's Avatar
MarkMeHopeful
2022 C8 of the Year Finalist - Modified
Originally Posted by thale
Thank you
Don't be fooled by the Bot Chevy Cust Scv comments. If you take your car to a dealer the first thing they will tell you is they can't do anything since the lowering collars are prohibited by GM and void your warranty.
Old Mar 20, 2025 | 01:35 PM
mittens's Avatar
mittens
Not sure what noise you would have from that. you can use a jack and lift one wheel at a time and aticulate the shocks and see if anything moves or is loose?
Old Mar 23, 2025 | 08:52 AM
Andybump's Avatar
Andybump
Thats right! Here is a link to a bulletin about that.
https://static.nhtsa.gov/odi/tsbs/20...15636-0001.pdf
It should not void your entire warranty, but it likely will "prevent" the dealer from performing diagnostics and repairs related to any suspension issues.
Besides the bulletin, the Service Manual includes general (and some specific) instructions about checking for any aftermarket components before starting a diagnosis. In the case of the suspension, many procedures start with verification of correct ride height, and may not proceed if the correct ride height is not found. So, lowering collars are a potential showstopper. Some dealers may be more lenient about having a look - but some won't.
To Lowering Collar Problems
