I think they have their hands full… watching the various videos with the engineers they do mention they want to increase output. But a few questions remain, like the overall process required to build, fit custom shims, re check the motor, make needed adjustments then dyno. Did they dyno the C7 Z06 motors? I couldn’t find any information on that. This motor is more sophisticated based on their process so it will be interesting to see how many they can produce.
The bigger issue is supplies/parts. The current issues with the supply chain will be around for the foreseeable future, this will continue to impact production.
Good point about the dynos. No, GM did not dyno the C7 Z06 engines. It was stated that for the first time ever, GM will be dyno'ing every C8 Z06 engine before final assembly. So that takes time and resources as well.
Some are stating as fact that all the things they are doing have been done before... this is clearly not true.
Also, some are stating as fact that the engine will not be a delay. That's a sure way to lose instant credibility. They do NOT KNOW this. GM doesn't know this. They can ASSUME but that is all it is, an assumption. No one expected chips to cause delays either.
GM will do whatever they can to get the Z06's out but all this perfect case, never any issues, record breaking Z06 production...posturing is getting old. It is what it is. (or it will be what it will be... )
Yes they did. They just didn't run them for 20 minutes like they're planning to do with the LT6.
You might want to be careful of who you're calling out. To say that "GM doesn't know this" is a fairly ignorant statement.
I believe they are building the Z06 engines now or at least very soon for 2 reasons, first to stock pile a few engines as a buffer as they ramp up especially in case they run into a parts storage later on. Second they need to start training the actual engine builders to get them up to a level where they can build X amount per day.
This is my take as well. Build a few for the backlog and train more folks to get to 30+% percent of Vette allocation.
having a bespoke engine and wide body is unique to the C8 so maybe the percentages of the past of base vs Z may not apply and who knows maybe we get to 50/50 Z vs base
GM announced that the hand build Z06 engines will be done by 10-12 engine builders. Now lets say each builder can build one or two per day. At one a day a tad less than 3000 per model year, and two per day equals a tad less than 6000 per year. Now how many deposits do you think the total is for every dealer in the US. Furthermore, how many more folks plan on a Z06 who have not given a deposit yet. The reality of the situation is that almost everyone wanting a Z06 will be waiting for many years if they get one, and most will not get one. Therefor, what makes sense to me is this: if you are the average Joe or Joline who does not own a C8 and wants a Z06 BUT HAS NO PLANS TO TRACK THE CAR, get a fully equipped C8 Z51. If you own a C8 and still want a Z06 (like I do), be patient. Be VERY patient!
I love when some people get righteous and place their intentions for the Z06 above the intentions of others.
Get in line. Put down your deposit. Wait your turn, and then do whatever YOU want to do with your Z06.
I don't believe for a second they will be able to make the Z06 30-35% of total C8 production in the first year or two, but I'll gladly come back and eat my words if I'm wrong.
If BG is stock piling Z06 engines right now, or may be for the last few weeks, I would not want to be the one getting an engine that has sat for months with no long term storage oils to prevent rust from forming on bare steel parts. rust particles plugging oil feed hoes in a 8600rpm engine might cause a few problems. Yep lots of aluminum, but cranks, lifters and cams are still steel.
Every engine is dyno so obviously it had oil and thus coating all the components. Also I'm sure they are stored inside so I don't see how this would be any different than the crated engines GM sells that must be sitting on a shelf for several months.
Your engines/day estimates are probably off (on the low side), but more importantly and as I've stated numerous times in this section:
THE ENGINES WILL NOT BE THE LIMITING FACTOR!
Sorry for the emboldened text, but this is the fourth of fifth time I've had to say it. Other Z06-specific components may be a limiting factor, but the LT6 won't be. And note the emphasis on "may".
When JVP answers the question asked, why do people keep coming up with different answers! HE KNOWS!
Exactly. I have not been to BG-PBC but when Chevy hand-built the ZL1 and L88s in the late 60, they were in a clean room with people wearing lab coats and hair nets, etc. It was just short of Has-Mat gear. The temp and humidity was well controlled then, I can't imagine it would be any less so at BG.
My wife's hairdresser's cousin has a son @ G.M. that is working on the Z06. He says to tell all the Chicken Littles on the Corvette Forum that the sky is not falling and that patience is a virtue. Remember, all comes to those that wait!
The OP is right…it IS “simple math”. The desired equation is one of subtraction, by trying to reduce the number of buyers ahead of him to get his car faster.
Well, there's a good bit of owners that store their vehicles over winter for months at a time. I doubt all those engines are worse off because of it.
This post made me LOL. GM projects XXX amount of Z06 sales. They then make plans with their vendors/suppliers to be able to supply enough components in a specific cadence of orders throughout the year....this is called capability and capacity planning.
I work for an OEM supplier in automotive...they have Supplier Quality meetings and visits in which GM tells us how many components they need for the year and at what batch size and frequency they want them. We as the supplier need to show and prove capacity and capability to supply said part. If GM wants sales profit they will find a way to get enough suppliers lined up to make it happen.
Things that delay us are also a reason for delay of other suppliers which can be out of our hands sometimes...raw material supply/cost and or logistic/shipping issues. Case in point...chip shortage...my company has nothing to do with chips directly but when OEMs shut down production because OTHER components can't be built it also reduces our orders for the parts we supply. If OEM's aren't building cars then suppliers stop supplying components for said cars.
There is SO much more then OP's "simple math" on "what he heard/read" about engine builder suppliers an their theoretical daily output.
