C8 Z06 Discussion General Z06 Corvette Discussion, Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored By:
Sponsored By: Wheel Designers
Customer C8 Z06 engine issue
Old Dec 29, 2022 | 09:44 AM
  #101
yz250fPilot's Avatar
yz250fPilot
I'm not so sure there is something wrong with the engine itself, please hear me out...
When the engine starts at 10:10 - the engine's exhaust does not display an audible miss or a misfire - in other words, all cylinders are firing normally.
The 'smoke' is not blue as someone stated earlier, it is white which more than likely is condensation in the exhaust burning-off - in other words, it's not oil being burned.
As for the noise, it could be the valvetrain, but because the engine is idling normally per the exhaust note, it may not be the valvetrain.
Therefore, I'm speculating the noise could be a bearing going bad - for example, like on the alternator, or air conditioning compressor, or something else similar that rotates while the engine is running.
To reiterate, the big clue for me is the exhaust note does not sound like the engine is missing on a cylinder.
Now that I typed that and thinking it thru, since the engine has 2-intake and 2-exhaust valves per cylinder, perhaps 1 valve/lifter failed meaning the 2nd valve/lifter is still working normally allowing the engine to run without an audible miss from the exhaust - so there's that possibility too.
Just speculating of course, but it is plausible.
Old Dec 29, 2022 | 12:49 PM
  #102
tausc82's Avatar
tausc82
Originally Posted by JockItch
If Mike Ward built the engine this would have never happened
We will have to keep an eye on engines built by Andrew Goins if similar issues start to appear.
Old Dec 29, 2022 | 10:22 PM
  #103
mfain's Avatar
mfain
Flashing CEL? Wonder what the code was?
"engine misfire
A flashing light signifies that the problem is very serious and if not taken care of expeditiously may result in major and significant damage to the vehicle. This blinking light usually reveals a severe engine misfire allowing unburned fuel to be dumped into the exhaust system."
Old Dec 30, 2022 | 11:25 AM
  #104
z06inVB's Avatar
z06inVB
Originally Posted by Blackwater0323
Never buy the first year car. The guys down on the list will get theirs in years 3 or 4 and the problems will be worked out by then!
What ?? That’s crazy talk !! Why I bought a first year 2001 z06 with the LS6. And well…
Ok never mind. Maybe you’re right 😂
Old Dec 30, 2022 | 12:18 PM
  #105
555ctsv's Avatar
555ctsv
I try not to think about the 1st year thing but I do recall when I was looking for a C7Z I avoided the early cars with the different supercharger lids. Actually that also happened in the 2nd generation ctsv's
Fingers crossed this car doesn't follow the trend but wouldn't be surprised at all
Old Dec 30, 2022 | 12:52 PM
  #106
Dominic Sorresso's Avatar
Dominic Sorresso
After getting an 84 Xfire w a 4+3, never again 1st yr. Rather have a well sorted used one.
Old Dec 30, 2022 | 03:07 PM
  #107
Propspinner's Avatar
Propspinner
Okay I’ll start the conspiracy theory. We have not seen or heard anything (at least I have not), since his video. I’ll bet that GM immediately got in contact with this guy and made arrangements to get the car back to Milford or Warren tech center. They will get him an allocation for a new car upon a non-disclosure agreement. They will tear the engine down, find out what happened, and then try as hard they can to prevent this in the future.
Old Dec 30, 2022 | 03:31 PM
  #108
cal45's Avatar
cal45
What gets me is that the Dealer received probably a $50,000 ADM (pure profit) and they don't have a manager who can go open up and receive the car that night from the tow truck? They make no xtra effort - geez.
Old Dec 30, 2022 | 03:40 PM
  #109
smithers's Avatar
smithers
I don't think the first, second, third, etc year thing really matters all that much. The theory makes sense....
...but how many years were LS7's blowing up before GM admitted there was a problem? Wasn't it something like 5 years after production started? haha If it wasn't for the recession/bankruptcy keeping the C6 alive for so long those cars would have been a total wildcard for their entire production run.
Old Dec 30, 2022 | 05:13 PM
  #110
Dominic Sorresso
Similar situation when the first C4 ZR-1 were delivered and camshaft lobes were getting wiped.
motors were not repaired but replaced w original going back to GM. Turned out some driver at the plant was starting cars with WOT in cold weather.
Old Dec 30, 2022 | 07:22 PM
  #111
PRE-Z06's Avatar
PRE-Z06
He posted another and it looks like this will be the second used C8Z06 for sale or he’s just milking the YouTube views, curious to find out how serious of an issue it really is.
https://www.caranddriver.com/news/a4...gine-52-miles/
Old Dec 30, 2022 | 07:25 PM
  #112
JABCAT's Avatar
JABCAT
They were, and still are a wildcard regardless of year as the problem was never fixed.
Old Dec 30, 2022 | 07:38 PM
  #113
smithers's Avatar
smithers
Oh wow, didn't realize it was never sorted out. WHen I looked into it the only C6 Z06 I could afford was an early one and people made it sound like around 2011 they were good to go.
So I guess when it comes to GM it's not "never buy the first year"... its "always buy an extended warranty" lol
Old Dec 30, 2022 | 08:29 PM
  #114
Propspinner
I don’t think he cares about clicks he doesn’t make his living via YouTube. That last one was on the 24th? Hopefully he follows up with updates.
Old Dec 30, 2022 | 10:37 PM
  #115
xBoostx's Avatar
xBoostx
Originally Posted by Egoncool
First episode about 4000 miles. Was something catastrophic. When I came out of a corner and went full throttle I heard a large bang and parts and oil everywhere. I have a sheared wrist pin. Never found out the cause. Second time had about 14k miles. Cause was a fractured #1 piston which destroyed the cylinder. That time it was an almost non event. Came off the track into the paddock and the engine just stalled.
What octane gasoline and what gas stations do you normally use?
Old Dec 30, 2022 | 10:50 PM
  #116
RD-1's Avatar
RD-1
According to the video the dealer offered him 3 options:
1) Get a full refund
2) Order a new car to his spec (6 month wait)
3) Repair the existing car (new engine required) + 100,000 mile warranty (2 month wait)
He chose option 3. Looks like it was no fault of the owner as per the conspiracy theories around here, either way good on GM for taking care of the customer.
Old Dec 30, 2022 | 11:03 PM
  #117
JVi's Avatar
JVi
Originally Posted by LPEC8
How mad would you be if you were that guy, paid 100K in ADM to get a car early and then had to wait 6 months for a new engine? Even worse it looks like it had the **** scratched outta the wheels the way they strapped it down on the tow truck. And it's black so after it spends god knows how long sitting outside BFE Chevy, being leaned into, worked on, bird bombed and walked past his paint should be just about hammered ****. Then once it's fixed every lot rat gets to take a turn behind the wheel for 'drivability testing'. That guy is living my greatest nightmare.
Marco took the news much better than the worry wart Karens Brigade here.
The warranty took care of everything.
To Customer C8 Z06 engine issue
Old Dec 30, 2022 | 11:10 PM
  #118
smithers's Avatar
smithers
Fair options all around. He said #3 also came with a discount from the dealer, so it probably ended up being cheaper than option #2.
Hopefully the service dept gets the job done right and he doesn't have any more headaches.
Old Dec 30, 2022 | 11:31 PM
  #119
RD-1's Avatar
RD-1
The only real problem I foresee is the Black paint is going to get thrashed, unless it has PPF which I doubt with only 52 miles.
Old Dec 31, 2022 | 09:02 AM
  #120
PRE-Z06's Avatar
PRE-Z06
His first one sure did get a lot of views, though now both are private for some reason and he’s got an update in post 119. I couldn’t help and wonder why so long, thought maybe it’s like starting a go fund me with a viral video.
