C8 Z06 Discussion General Z06 Corvette Discussion, Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored By:
Sponsored By: Wheel Designers
Cicio Performance Lowering Collars = PERFECT!
Old Dec 19, 2023 | 09:48 PM
  #81
phalse's Avatar
phalse
the correct spacers to use on the rear for the z06 are the FIFTEEN mm spacers, paragon makes some. by now many have seen pics of 20mm spacers on a Z and its awful, gonna destroy the fender.
you have to grind down the studs for the 15mm spacers but hardly any, and not even enough to encroach on any of the thread length. takes like 2 mins per wheel, cover stuff with a towel/tape/this/that and get 'er done =D
Old Dec 19, 2023 | 11:09 PM
  #82
Synergy-'s Avatar
Synergy-
Originally Posted by JockItch
On a separate, but related note… guy on FB says he’s been working with Cicio regarding the possible development of spacers for the carbon fiber wheels. He should hopefully know shortly if they are a possibility. I know Paragon said they will not be developing spacers for that wheel.
I sure hope you are correct! I can't stand the spacing on my CF wheels!
Old Dec 19, 2023 | 11:16 PM
  #83
RD-1's Avatar
RD-1
You forgot to add imo, and they are rear quarter panels not fenders.
Old Dec 19, 2023 | 11:37 PM
  #84
phalse's Avatar
phalse
well, no, because thats how math works. if the outer edges of your tires are pushed outward/outboard enough to where theyll contact the fender lip during suspension travel, then thats wrong.
whys it wrong? arranging things in such a way that they no longer properly serve their mechanical function is basically fuckboi status. thats like those harley guys that choose those dinky little helmets strictly based on how they look.
dont hate me, hate math.
Old Dec 20, 2023 | 12:00 AM
  #85
RD-1's Avatar
RD-1
Plenty of people have used the 20mm spacers on the back with fully lowered cars and are no where near to rubbing the quarter panels. If you read the other thread on wheel spacers you will see that I've done the math and know first hand what fits.
Old Dec 20, 2023 | 01:01 AM
  #86
John510's Avatar
John510
Bruh 😆 you have no idea what you are talking about. I have 20mm spacers and they are still nowhere near my quarter panels even with my car dumped to the floor and multiple track days. Stop spreading “phalse” info.
Old Dec 20, 2023 | 11:42 AM
  #87
Synergy-'s Avatar
Synergy-
^^ THAT looks fantastic and a PERFECT STANCE setup IMO. Appreciate the facts that you can roll 20mm spacers and lower it without rubbing!
Old Dec 20, 2023 | 04:24 PM
  #88
95vettski's Avatar
95vettski
Does lowering and spacing the wheels require realignment?
I'm guessing it should be checked and adjusted for optimal tire wear.
Old Dec 20, 2023 | 04:39 PM
  #89
John510's Avatar
John510
Yes you will need an alignment.
Old Dec 20, 2023 | 07:25 PM
  #90
MuscleCarDave's Avatar
MuscleCarDave
I was a certified alignment tech in the mid '80s. Yes lowering requires re-alignment as it will likely affect both caster and camber, which then affects toe. Spacing the wheels should not affect alignment, but may transfer wear to the wheel bearings differently and over time may cause slightly advanced bearing wear...although I don't know what type of front bearings the vette has. I had to replace a lot of tapered bearings on old trucks when these guys would use 2" spacers on their lifted trucks.
Old Dec 21, 2023 | 06:16 PM
  #91
Gang Green's Avatar
Gang Green
To avoid the potential issues with the collars, does it make sense to just go with the lowering springs? Paragon offers them and achieves the 1" lowering. Seems pretty straight forward to me - I think the ride becomes 30% stiffer which I could live with opposed to a leaking break line.
Did anyone go this route? Pics to share?
Old Dec 21, 2023 | 06:20 PM
  #92
RD-1's Avatar
RD-1
You won't have any leaks if you use new crush washers and apply the recommended torque spec to the bolt.
Old Dec 21, 2023 | 07:03 PM
  #93
Gang Green's Avatar
Gang Green
I get it but it just seems like a cleaner less headache job going the spring route no?
Old Dec 21, 2023 | 07:11 PM
  #94
RD-1's Avatar
RD-1
I guess it depends how you look at it. To do the springs you have to remove all 4 shocks and mess with 4 mag ride connectors, which can be a PIA. The car will also be lower than some people want. With the collars you have the choice of the drop from 3/8, 3/4 or 1 inch, and you can adjust the rear coil overs up to 3/4 inch drop. Cost can also be a consideration, but either option can be the cause of a warranty denial issue if a shock or front lift actuator fails.
Old Dec 21, 2023 | 08:20 PM
  #95
Gang Green's Avatar
Gang Green
You make a lot of sense. Im sorry if I missed it but did you lower your car? If so, Im assuming you took the collar route?
Old Dec 21, 2023 | 08:21 PM
  #96
phalse's Avatar
phalse
hehe arent you adorable. but yeah, nice car.
the correct way to check these things is to put it on the rack with wheel off, take the spring out and with a wheel sitting on the ground face down, measure from the floor (since that'll be the effective outside edge of your tire) to the wheel hub backface. then you take a magnetic articulated holder and position it so its at that same height and stick it on the hub. this way the tip of the mag block arm is where your tire sidewall would be. push the wheel assembly towards the sky and pray, easy with the spring out. if the tip of the mag holder passes safely behind the panel lip along its full suspension travel then we have joy especially since with camber you'll get just a liiiiiiiiiittle more clearance on top of that. everyone should have one of these mag block arms anyway (buy a Noga) for checking rotor runout and such.
but if you think your z06 with its track spring rate and the mag ride set to track is getting anywhere near fully squatting down in the rear you're smoking something good. =D
nice try though.
Old Dec 21, 2023 | 09:28 PM
  #97
RD-1's Avatar
RD-1
Cicio collars, I also forgot to mention that whatever route you take, you would still need to disconnect the hydraulic hose.
To Cicio Performance Lowering Collars = PERFECT!
Old Dec 21, 2023 | 11:59 PM
  #98
John510's Avatar
John510
nice try though.
your not a bright one are you 😆. You were proven wrong and got butthurt. Most egocentric people tend to get angry when proven wrong.
Old Dec 22, 2023 | 01:01 PM
  #99
Gang Green's Avatar
Gang Green
Beautiful! Nicely done - And Im assuming you lowered the rear on the stock bolts?
No issues with leaks etc using the collars - Did you do the work yourself - speed shop?
Old Dec 22, 2023 | 01:08 PM
  #100
RD-1's Avatar
RD-1
There are no bolts, that was on the C7 generation. This car has factory adjustable coil overs, the rears can be lowered to a max of 3/4 inch. I did all the work myself in the garage, I just got this car at the end of October and it's been in hibernation due to winter. I haven't driven it yet with the collars, I used new crush washers and bled the system so I don't anticipate any issues. If there was a leak it would be leaking just sitting in the garage.
