C8 Z06/ZR1/Zora Discussion General Z06, ZR1 and Zora Corvette Discussion, Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored By:
Sponsored By: Wheel Designers
Could the Z06 be supercharged?
Old 02-02-2021, 01:50 PM
  #41
DetroitGS
DetroitGS's Avatar
What details do we want to speculate about tomorrow? I think the Z06 will have a center console that will be large enough to hold my 10" x 12" hope journal.
Old 02-02-2021, 02:04 PM
  #42
Z0HS1CK
Z0HS1CK's Avatar
Received 3,346 Likes on 2,246 Posts
Originally Posted by donkeyssuck
I am offering to bet you $100 that the new Z will have more than 650 hp, because I am certain of that. I am not certain of which platform they will use to get there, so betting on that would be foolish. If you are anxious to lose more than $100, I am sure there are a lot of other guys on the Forum that will also take your money. Do we have a bet?
Lmao first you were so sure on TT, now you're changing your tune.
I'm not betting on hp, I'll bet on na or FI though. Fair?
Old 02-02-2021, 02:06 PM
  #43
SharkDiverZ06
SharkDiverZ06's Avatar
Received 3,763 Likes on 1,418 Posts
How about we speculate on the chances that someone with no interest in this thread will actually waste their time by posting what only they think is a witty comment. I'm speculating you just did that.
Savoy2001 (02-02-2021)
Old 02-02-2021, 02:11 PM
  #44
Z0HS1CK
Z0HS1CK's Avatar
it sure as hell won't accommodate a manual though lmaooo
Old 02-02-2021, 02:22 PM
  #45
SharkDiverZ06
Show me where I said I was SURE that it would be TT. I have never said this. What I have said numerous times is that I am certain GM is not stupid enough to bring out a new Z with less hp than it's predecessor and that, because of this, I believe GM will most likely go FI. Is it POSSIBLE GM produces a dependable NA FPC that can make 650+ hp that isn't a warranty nightmare? Yes. Is it likely? Most engineers and engine builders would tell you no.
vettesweetnos (02-02-2021)
  #46
Latterlon
Latterlon's Avatar
LT7
The following 9 users liked this post by Latterlon:
23/C8Z (02-03-2021), ChevyChad (02-02-2021), CPhelps (02-03-2021), JockItch (02-02-2021), TB427Z06 (02-04-2021), vettesweetnos (02-02-2021), WalterSobchak (02-03-2021), Zaro Tundov (02-04-2021), ZRacerLE (02-02-2021) and 4 others liked this post. (Show less...)
Old 02-02-2021, 02:23 PM
  #47
DetroitGS
DetroitGS's Avatar
I do have interest in a future Z06, and I click on these threads hoping it will be actual news I've missed elsewhere, but really knowing it's just you guys speculating and talking in circles. I'm impressed that you guys basically retype yesterday's Z06 speculation thread, but with today's date. Carry on. I should be ignored.
The following 4 users liked this post by DetroitGS:
Bossman429 (02-03-2021), ChevyChad (02-02-2021), NytmereZ (02-09-2021), Sub Driver (02-03-2021)
Old 02-02-2021, 02:38 PM
  #48
Z0HS1CK
Z0HS1CK's Avatar
so all the previous months when I said NA and you said it'll never happen, doesn't count as you being sure it was TT?
Only recently, like yesterday, is when people are throwing out the idea of possibly the LT4/5 going in. As if that's there last hope of hope lol.
I still could be wrong so I'm not claiming victory just yet.
However it's not looking good for you NA haters lmaoo
Old 02-02-2021, 03:25 PM
  #49
SharkDiverZ06
Yeah, it beats talkin' politics.
Old 02-02-2021, 03:39 PM
  #50
Savoy2001
Savoy2001's Avatar
Received 2,477 Likes on 1,108 Posts
Originally Posted by TB427Z06
I believe it's got to be a 750 HP TT DOHC 5.5 Liter Flat plane crank engine after reading countless speculation and here's why: Let’s think about this. If the GT2 RS is 700 HP from a TT 3.8 L 6cyl and weights 3200 lbs. What would the C8 Z06 have to have in order to compete? GM is benchmarking the C8 Z06 against the GT2 RS as seen by them testing the mules along with a GT2 RS. If the C8 Z06 weighs 3600 lbs they need at least 750 HP to even be close to competing with the GTRS. No way a 600-675 HP NA 5.5 liter car weighing 3600 lbs will do that. So in order to do that in addition to the 5.5 liter DOHC flat plane engine it needs to be Turbo Charged to the tune of 750 HP! I think the 600-675 HP NA leaks are intentionally blowing smoke so they can blow everyone away at the reveal. The C8R puts out 500 HP, the Ford GT 350 puts out 525 from a 5.2 L DOHC Flat plane crank. So a guess as to the street version of the GM 5.5 L flat plane crank is around 550-600 HP. Add twin turbo's to that and you get an additional 150-200 HP or 750 HP. The ZR1 would have the same setup except bigger turbo's, bring the HP to 850. Makes sense to me. And also this: Rick @ Conti teased a little that he might know something about the Z06 but he would not say. The only clue he gave was something along the lines of "and you all thought it was going to be..." Yea And we all thought is was going to be a 600-675 HP NA DOHC flat plane crank!!!!!!
This is my thinking exactly. You are on the same line of thought I have been since the beginning really. The car can’t have only 100 hp more than the base car. The car can’t only have 100 hp more and still weight the 3600 ish lbs it does. We know they can’t afford to drill enough weight to make that competitive. You need to be down around 3200 lbs for that to work. So what makes more sense tt 700-750 hp 3600/3700 lbs car competing with its competition or the 600 hp car slightly faster than the base car and losing all of its down low trq. Oh and let’s charge 25/30 grand more for this slight performance boost over base? Ya sign me up. If that were The case I might just order a z.51 stingray and save a ton of money.
The following 5 users liked this post by Savoy2001:
ChevyChad (02-02-2021), mrvegasrx7 (02-02-2021), SharkDiverZ06 (02-02-2021), TB427Z06 (02-04-2021), vettesweetnos (02-02-2021)
Old 02-02-2021, 03:42 PM
  #51
Savoy2001
Savoy2001's Avatar
Originally Posted by CanadianVetster
Will GM want their new flagship C8 Z06 have less HP than the new Cadillac just announced?
Hence I also believe/hope the Z will be TT and produce near enough to 700HP.
This is another important clue. Gm didn’t allow the v3 to have 650/650 because their flagship performance car has to be the top dog. No other reason for the v3 to be slightly detuned. The bs Cadillac gave regarding the slightly different exhaust was crap we all knew it.
Old 02-02-2021, 03:45 PM
  #52
DetroitGS
DetroitGS's Avatar
I have to agree with you on that.
Old 02-02-2021, 03:47 PM
  #53
VetteVinnie
Support Corvetteforum!
VetteVinnie's Avatar
Received 1,787 Likes on 1,133 Posts
Your username says it every day.
Old 02-02-2021, 03:48 PM
  #54
SharkDiverZ06
You're still sounding like a 10 year old. Victory? For siding with the car rags on a 50/50 proposition. You sure set the bar low. We ALL want the new Z to be successful and not be hamstrung by an under powered and unreliable power plant...We're all on the same side there.
And who are you referring to as an NA hater? My current Vette is a highly modified NA LS2...I LOVE NA power plants...Just not with less than 650 hp in an unreliable FPC configuration at $85+k. If GM pulls a rabbit out of it's hat and is the first manufacturer in the world to mass market a RELIABLE 675 hp NA FPC power plant with more than 500 lb-ft, I'm all in, as I think most guys looking at a new Z would be. I just think there are a lot of us that are skeptical that GM can actually pull that off, regardless of what the auto rags are feeding us.
Old 02-02-2021, 03:58 PM
  #55
SharkDiverZ06
Shhhhh...That's supposed to be subliminal.
Old 02-02-2021, 04:02 PM
  #56
VetteVinnie
I think I caught that show in Mexico one time....
Old 02-02-2021, 04:05 PM
  #57
SharkDiverZ06
Just don't let them pull you up on stage to be part of the show.
To Could the Z06 be supercharged?
Old 02-02-2021, 04:10 PM
  #58
Z0HS1CK
Z0HS1CK's Avatar
Still crossing fingers on that NA GOODDDDNEESSS!!!!
Old 02-02-2021, 04:22 PM
  #59
thill444
thill444's Avatar
Received 4,101 Likes on 2,004 Posts
And if it is an NA FPC engine, then even the thought of adding aftermarket turbo, supercharger, tune, etc means you are a high roller. Because if the engine turns out to be unreliable that is an expensive mistake with no warranty. $15-25K mistake maybe with labor?
Old 02-02-2021, 04:31 PM
  #60
Z0HS1CK
Z0HS1CK's Avatar
Nah. Itll be a quick track car if NA. The zr1 with the tt will be the street powerhouse.
Quick Reply: Could the Z06 be supercharged?
