C8 Z06/ZR1/Zora Discussion General Z06, ZR1 and Zora Corvette Discussion, Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored By:
Sponsored By: Wheel Designers
C8 Z06 pdr VIR full track video first impressions
Old 02-26-2023, 12:30 AM
AustinVetter
AustinVetter's Avatar
Received 2,670 Likes on 1,034 Posts
Originally Posted by Zjoe6
Looked like that C7 Z06 was getting squirrely in the turns trying to stay ahead of you (assuming it was a Z06). Seemed like you were faster in the turns but it pulled away in the straights. Very cool showing you running with the C7. Nice perspective.
I noticed that too on the Zl1 perspective video. The C7 (ZR1) was dancing around a bit at various times and didn't seem nearly as planted as the C8 Z06. The Z06 seemed amazingly stable and easy to drive by comparison.
Old 02-26-2023, 09:46 AM
z28lt1
Support Corvetteforum!
z28lt1's Avatar
Received 2,046 Likes on 1,069 Posts
As many of us here are patiently (or not so patiently) waiting for our numbers to be called for our Z06's, I almost hate to say it, but with the platform this good, hard to think the C8 ZR1 is going to be anything other than amazing. Suspect we'll see some records fall if they can keep it at a reasonable weight. So far, so good with the C8s.
AustinVetter (02-26-2023)
Old 02-26-2023, 12:12 PM
ZoratZ06
ZoratZ06's Avatar
Yes...it’s about time GM went mid-engine. Now it seems most people are ‘seeing the light.’ Better late than never I guess.
I’m sure the ZR1 will be epic...but I gotta think it’ll be heavier than the Z06. Could be pushing 3900lbs+. What records will fall? It won’t be quicker than an SF90 or 765, don’t forget the new GT2RS with Senna level aero and likely 800hp...and we’re still likely 2 years away from a ZR1. A lot can happen in 2 years...GM needs a halo car.
Old 02-26-2023, 02:23 PM
AVETTE
AVETTE's Avatar
Cruise-In II Veteran
Cruise-In III Veteran
Great driving on the standard tires! Iron Brakes! no aero... wow
NXTFAZE (02-26-2023)
Old 02-26-2023, 05:23 PM
sainthoo
sainthoo's Avatar
Originally Posted by steelankles
Steelankles C8 Z06 video
Enjoy the sound it’s amazing!
please subscribe if you would like too
thanks,
Jay
SRA, Bad Brains, BMWCCA?
Old 02-26-2023, 06:21 PM
thebishman
thebishman's Avatar
The Z07 is going to be even (slightly) more epic!!
Old 03-30-2023, 03:14 PM
Lil Zombie
2nd Gear
Lil Zombie's Avatar
I'm really interested in how you incorporated the rear camera view into the PDR. Could we get instructions on how to do that? Thanks.
Old 03-31-2023, 07:59 AM
steelankles
steelankles's Avatar
go pro mounted on back and use a mac with imovie
Old 03-31-2023, 09:31 AM
-ZEEOHSIX-
-ZEEOHSIX-'s Avatar
It may just be my perspective but, it looks like the car is dancing a bit under initial heavy braking. Do you feel that or notice that as you're braking hard? Was this on the standard alignment or did it have a track alignment?
Old 04-01-2023, 10:49 AM
C8gofast
C8gofast's Avatar
I have a ZO6 that will be a track car only, which I picked up two weeks ago. So far, it only has 480 miles on it.
I’ll be at Barber’s in two weeks, RA and NOLA in May. I went with -2.5 degrees negative camber rather than the GM recommended-2.0 because I found the recommended camber for the C8 was not enough for R7s based on tire temperatures and wear patterns.
My questions , which I will answer over time but there may be an opinion out there already are: are the stock ZO6 iron brakes and pads good enough . What pads are people running with the stock calipers ? Or I’ll be going to the AP big brakes that came off my C8.
Same on the suspension: stock or MCS two ways that came off the C8.
I did have the new Z06 on Barber’s track two weeks ago just cruising around and a huge improvement I noticed was the smoothness of the transmission shifts as compared to my 2021 C8. GM certainly has improved the software controlling the shifts.
Old 04-03-2023, 12:21 AM
Scream And Fly
Scream And Fly's Avatar
Really awesome video. Just wondering, is that MPH number correct? It could just be the video but it almost appears as if that might be KM per hour, judging by the speeds at turns, etc.
Old 04-03-2023, 10:57 AM
RapidC84B
RapidC84B's Avatar
Received 13,258 Likes on 6,041 Posts
LOL... no his video is correct. It's in MPH.
NXTFAZE (04-03-2023)
Old 04-03-2023, 07:54 PM
  #33
NXTFAZE
NXTFAZE's Avatar
I'm going to run stock until things need to get replaced. Once that happens going with KNS for brakes. Carbotech has pads available F/R and Girodisc will have rotors available in a month.
MPH is correct
Yep! I think 167 mph back stretch and 159 front straight were the Vmax best that day
C8gofast (04-04-2023)
Old 04-04-2023, 01:44 AM
  #34
NXTFAZE
NXTFAZE's Avatar
C8 Z06 has the GM spec track alignment (-2 F/R). Car may have some dancing under hard braking but it wasn't anything that made me uneasy. I brake very agressively and know how to handle the rear end dance. My Gen 5 Viper and GT350 R moved a lot more - so this wasn't even on my radar.
The following 2 users liked this post by NXTFAZE:
-ZEEOHSIX- (04-04-2023), RapidC84B (04-04-2023)
Old 04-04-2023, 02:37 PM
  #35
TLS_Addict
TLS_Addict's Avatar
Wow. That thing is cooking. Nice driving.
​​​​​​The Z is a beast of a car, no doubt about it.
NXTFAZE (04-05-2023)
Quick Reply: C8 Z06 pdr VIR full track video first impressions
