Zr1 hp
#61
I don't think a 4500lbs car with 1000hp on tap is going to feel weighty at all. Veyron was 4050 ish. Chiron is 4400 ish. Slugging around 4500 (high estimate) with 1000hp still comes in at 2 less lbs per hp than the ER; and we all know the ER is no slouch.
I see very distinct markets for the ZR1 and Zora; just like there's a lot of hybrid drive haters who won't even look at an ER.
p.s.
I've got a line in for one (zora)...but IDK if it will actually appeal to me or if I'll end up keeping the ER I'm in line for. I figure I'd probably need an extra 100k + trade-in, and then I get to deal with whatever fugly and gross 75th livery GM pukes up--on top of any concerns for maintenance cost on the NA LT2 & a fairly straightforward hybrid drive.
p.s.
#62
Doesn't make sense to have 2 separate variants of a very similar car with 1 being AWD. The ERAY and z06 are similar price range but 2 totally different cars besides just AWD.
For the ZR1 and ZORA to have the SAME powerplant, except the ZORA having AWD? Idk if that makes sense.
It makes more sense to have the ZR1. Then have a ZR1 "ZORA" edition for people who would want AWD and spend 200+.
Or the ZR1 could just be the almighty corvette again of the lineup. With AWD and closer to 1000hp. But if that's the case, then definitely not starting at 150k lol
Hell, there is AWD on a blazer, why cant it be on both ZR1 and Zora? It is just extra parts and some tuning. Im on a few lists for the ZR1, and if its not AWD i wont get it. And it better not have any hybrid stuff on it either, or it is also a pass. I already have a vehicle with over 1400hp, so not interested in anything hybrid or electric, but maybe the lambo revuelto.
#63
Santa Clause came to me in a dream and said ZR1 is TT RWD and there's "another one" with eAWD, but it's not a copy/paste of the eRay bits. Tooth Fairy says ZR1 was supposed to be eAWD at one point and the "another one" would be full active aero, but things shifted some during development. $0.015 take it or leave it.
#64
Air quantity and air velocity are not the same thing. The longer the stroke, the more air velocity you have--which mixes the air/fuel better.
Can you get the same torque/power out of oversquare? Sure. The trade off is requiring higher RPM and the corresponding longevity decrease.
https://www.corvetteforum.com/forums...ke-or-fpc.html
#65
Doesnt have to make sense, its about GM making profit. Its not a big deal to add AWD to the ZR1 and/or the Zora, if there even is one.
I'm just saying from a "corvette enthusiast" point of view. If the ZR1 is 800, TT with RWD. Then a ZORA is the same setup, just with an electric motor in the front to make it AWD and bring it to 950hp or so, is that enough to charge the 50-75k extra which i assume it would be for a corvette of that magnitude?
The Z06 already looks crazy aesthetically. Imagine the ZR1 when revealed and then a ZORA? It'll then look like a transformer at that point.
Just saying if the ZR1 is this monster as we know of it, maybe there won't be a ZORA. There's only so much you can do before people are wondering what is the difference between them and if that extra cost is justified just for 1 added performance advantage, AWD.
Plus i was watching the "ZR1 mules" at the ring and i didn't notice any traction issues. So maybe it is AWD? Who knows anymore.
#67
Just out of curiosity, any idea what the rod ratios are for the LT2 and LT6?
#68
#70
#71
The one where on first corner entry of the ring he spun it a bit? That could be due to cold tires though.
I know these C8 variants all have great traction control but with everything turned on in my C7Z, even when it was stock, i could still fishtail a bit.
The new ZR1 looks very composed for a car that's supposed to have close to 700, or maybe even more ft lbs of torque.
JMB (03-20-2024)
#73
And that goes doubly so for the Corvette migrating away from a F/R layout. M/R would be even more complex to design from scratch to be AWD.
#74
Mechanical AWD linkage in a Corvette, you can pretty much expect GM to never do this. Ever. I wouldn't be surprised if mechanical AWD linkage starts to almost die out in sports cars. If GM had made an AWD Corvette like I'd wanted them to do back in the C4 generation, maybe that would have been a thing. But nearly 35 years later, and it's just now coming into the hands of owners...so no. No mechanical linkage. Ever. I'd almost put money on it.
CDNZR (03-29-2024)
#75
One of the biggest debates so far, is will the LT7 be LT6-based, or will it be based on a more passenger/truck-like as-yet-unreleased Gen6 with a CPC. I think one of the very first things Tadge asked years ago, was "will the LT6 FPC architecture work with boost, with minor changes?" Co-development of both LT6 and LT7 simultaneously saves much in the way of development costs, and the FPC lends itself to efficient turbocharging. If they did find out that they needed a CPC architecture, I suspect it was due to possible piston and rod strength issues that pushed them away from the light rod and good r/s ratio and into a shorter rod / stronger piston with a lower compression height and more weight and a more favorable vibration region; We'll see.
#77
I was looking back over a thread you had posted in years ago about the LT6, and you mentioned something about secondary vibrations being attenuated by longer rod ratios. To that end, I could see where vibration could become problematic if--as you stated--strength of the piston/rod had to be increased, thus necessitating a shorter rod ratio.
#78
I'm not sure if you're joking or just trying to have people react to your irrational speculation. Anyone with the smallest amount of mechanical understanding of the Corvette platform would realize that GM will not create an AWD C8 Corvette without a hybrid system. That would be mechanically, financially impractical if not nearly impossible. To route a driveshaft through the tunnel front of the engine... No way, no how!
#79
Received 4,386 Likes
#80
In contrast, GM may not sell a ton of e-rays, but they will almost certainly exceed the number of ZR1s, and the e-ray's technology provides some lessons as GM marches toward an electric future.
