Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
Detailing Engine HELP!!!!
Old Mar 14, 2007 | 10:16 PM
VictoriaVette's Avatar
VictoriaVette
Default Detailing Engine HELP!!!!
I want to detail my engine painting it while still in the car. The water pump was replaced several years back and was not painted and some of the paint on the engine needs to be repainted. Can you all give me any tips? And how about the best paint to use? Should I spray or use a brush. Let me hear what you have done.
Old Mar 14, 2007 | 10:33 PM
SIXFOOTER's Avatar
SIXFOOTER
Use simple green and a pressure washer to clean everything. throw a plastic bag over the carb and distributor. If a bit of water gets in the carb no biggie. Rattle can engine paint is a good choice. After cleaning the engine, run it a bit to warm up and dry it off, then tape and cover parts and paint.
Old Mar 14, 2007 | 10:48 PM
Big2Bird's Avatar
Big2Bird
Aluminum foil is your friend for detailing. Get a roll. Wrap things like brake boosters like a ham. Quick/easy.
Old Mar 14, 2007 | 10:53 PM
VictoriaVette
Default Aluminum foil
That is the BEST idea i have heard I would have never though of it but thats way I'm HERE!!!! How about the rust on the water pump from it never being painted? What should I do there? Should I use primer every where to be painted?
Thanks for all the info you all are GEAT!!!!!!!!!!!!!!!
Old Mar 14, 2007 | 10:57 PM
Big2Bird's Avatar
Big2Bird
That's hard to say without seeing it. The more you can take off, the better/easier it is. I.E., Taking off the belts and pulleys, you can paint the pump complete, while glass bead blasting the pulleys and fan semi-gloss black. I use primer, but if the pump is rusty, it will last just so long.
Old Mar 14, 2007 | 11:05 PM
VictoriaVette
Default Rust Converter
How about using a rust converter and then painting over that. Do the rust converters work?
Old Mar 14, 2007 | 11:06 PM
Big2Bird's Avatar
Big2Bird
Or you can pull the engine.
Old Mar 14, 2007 | 11:12 PM
VictoriaVette
Default Pull The Engine!!!
Just send me that one it would look real fine in my 77!! Tell me about it what has been done to it? How much HP etc. I love the way it looks. Just let me know what the shipping will be. LOL!!!
Old Mar 14, 2007 | 11:18 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
use blue painters tape and that press and seal Saran wrap to seal things off
Old Mar 14, 2007 | 11:21 PM
Big2Bird's Avatar
Big2Bird
Try the foil sometime Bob. It works great on goofy shapes.
Old Mar 14, 2007 | 11:41 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
I used that when I por 15'ed my frame. Worked great on rotors, calipers and weird shaped things.
Old Mar 14, 2007 | 11:43 PM
63mako's Avatar
63mako
I pulled the intake and exhaust manifolds and the fan and pulleys. Made life simple and only took a couple hours. Wire brush the water pump good.
Old Mar 15, 2007 | 12:09 AM
lucky76's Avatar
lucky76
Disconnect a battery cable first !!!!!!!!!!
Old Mar 15, 2007 | 12:16 AM
Big2Bird's Avatar
Big2Bird
Excellant advice. You would think a sparky would include that tidbit.
Old Mar 15, 2007 | 12:22 AM
noonie's Avatar
noonie
Bent a rod that way once.
Now I bump it over very gently with the coil disabled to make sure there is no wet lock in it.
Old Mar 15, 2007 | 12:24 AM
Big2Bird's Avatar
Big2Bird
How didi I miss this one. Go to Eastwood.com Lot's of goodies/answers.
PM me with any specifics.
Old Mar 15, 2007 | 12:49 AM
kwplot34's Avatar
kwplot34
very nice motor, i used the wrinkle finish on my valve covers also,but did not mask off top of fins,any sugestions on how to get the aluminium to show again. very proffesional job on that motor.
Old Mar 15, 2007 | 09:39 AM
Big2Bird's Avatar
Big2Bird
If you have an 81, they are magnesium. Just take a sanding block and 220, and sand off the tips. Do it by hand. I masked mine off.
To Detailing Engine HELP!!!!
