Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
Help needed
Old Sep 22, 2008 | 03:34 PM
yellowvert's Avatar
yellowvert
Default Help needed
Hoping some of you smart guys can help.
Car: black Jetta hood. Not factory finish is at was replaced in June due to an accident. Last time I polished this car, I think I went Nano on gray pad to Micro on gray pad but again, this is not the same surface since it was painted by a local shop, not the factory clear coat.
My daughter had my son's car last night and someone st a drink cup on the hood, which was mildly dirty and "slid" it while picking it up, leaving these marks. They are not deep but are very noticable.
http://i220.photobucket.com/albums/d...ttahood002.jpg
I know its not easy to see. I did a quick wipe with QD and its scratched. I've got a PC, Menz Micro and 106FF (nano) and a gray and a white pad (plus non-abrasive wax pads).
Because the hood is new, its in good shape and doesn't need polishing. I'm looking for suggestions as to what I should do. I'm an amateur but have done a few cars. I'm hoping I've already got what it takes to fix this....
Thanks in advance!
Old Sep 22, 2008 | 04:07 PM
steve8's Avatar
steve8
You can always try what you have, but I can't imagine it will work.
I would say orange pad and SIP would be what you will need, then on to your other products.
Old Sep 22, 2008 | 04:38 PM
Killrwheels@Autogeek's Avatar
0Killrwheels@Autogeek
Former Vendor
you could try Nano with the slightly more abrasive white pad to see if it will help remove the marks. Might need to step up to more abrasive polish also like SIP or the new 203 version.
Old Sep 22, 2008 | 08:52 PM
yellowvert's Avatar
yellowvert
Do I then follow it with Micro on Gray to remove Nano swirls and gloss it back?
Old Sep 22, 2008 | 10:10 PM
steve8's Avatar
steve8
The pads and polish you have are already incredibly mild. I can't imagine accomplishing what you want, nor inducing the swirls you are worried about.
Old Sep 23, 2008 | 06:16 PM
Former Vendor
nano actually is rated as a final polish due to its gloss rating. It doesnt usually need a FP following. SIP will in most cases finish down quite well, but we suggest using Nano and the FP to truly gem the surface.
With PC suggestion is SIP/Orange Pad, SIP/White Pad, Nano/Grey pad
To Help needed
