Can I fit two 315/30/18 tires in the back hatch of a C5 coupe?
Does anyone know if I can fit two wheels and tires (315/30/18) in the back hatch of a C5 coupe and still close the hatch? Someone must have tried this before.
It might work if you slide the passenger seat all the way forward and then also fold the passenger seat forward with the 2nd tire leaning right up against it but I still don't think so.
I DID read the first post, I can't fit my tires in my trunk!!!! lol I've been having to put one on the seat and one in the back of the hatch but now I need to add 2 more tires to the mix.
I have NT01 315/30/18 on the back of my C5 Z06 and they fit fine under the fender, but bulge a little on the stock z06 rim. I think 305 would be perfect, but they don't make the NT01 in that size.
Ok, now you can post this LOL.
A friend of mine had a little bracket he liked to use to let air flow through the back hatch (instead of letting it act like a parachute) when he drove his 94 with the top off. It mounted to the "loop" on the hatch and engaged the hook on the trunk latch to leave about a 2 inch gap between the glass and the body for air flow. I bet with that bracket, the wider tires would have fit. Maybe they make one for your car too?
Not sure but I think Sheila did it also....
