Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
Wrong angle or wrong pressures ?
Old Sep 1, 2002 | 06:17 PM
te51cle's Avatar
te51cle
Default Wrong angle or wrong pressures ?
For my second visit to a drag strip today I lowered my rear tyre pressures to 20 psi. The track was a low grip one and I'm a bit clumsy so I got loads of wheelspin. After the 4th run I noticed that the outside 3" of both rear tyres was a little worn/scrubbed but the rest of the tyre was fine. If the pressure is too low the classic wear pattern is for both outside and inside edges to wear so I wonder if the problem is elsewhere.
It makes me think that the camber angle should be changed, anyone have any recommendations ? Would increasing the pressure to 25 psi help even things out ? I'll replace the runflats with grippier tyres once I've learnt to drive a little better !
One thing that did annoy me though was the tyre pressure monitors that gave little chiming warnings for each wheel. Is there any way to stop this ?
Old Sep 1, 2002 | 10:19 PM
KyleBst264's Avatar
KyleBst264
Default Re: Wrong angle or wrong pressures ? (te51cle)
You may want to increase your tire pressures a little bit more, and see what effect that has before worrying about the rear camber.
