Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
Switch C4 to a solid Axel?
Old Oct 23, 2002 | 11:34 PM
RPM Frank's Avatar
RPM Frank
Default Re: Switch C4 to a solid Axel? (Light84vette)
This may help you ............
http://forums.corvetteforum.com/zerothread?id=409513
Old Oct 23, 2002 | 11:51 PM
Light84vette's Avatar
Light84vette
Default Re: Switch C4 to a solid Axel? (RPM Frank)
Yeah but how long would that take? Plus its going to probably be very $$$$ and is it going to have a strong axel or a joke broke thing weaker than the dana 36. Also is their going to be any for purchase in large quantities b/c a lot of corvette owners are going to be going after this. :yesnod:
Old Oct 24, 2002 | 12:11 AM
RPM Frank's Avatar
RPM Frank
A - Full production by January.
B - It's not gunna be free.
C - If you break it, I'll fly out there with a refund and put your old setup back in, the base unit has been proven to 8.50's with a spool and no it's not a 9"
D - Pre-orders after final testing and G/P's are welcome.
Your gunna love this thing ........... :chevy
Old Oct 24, 2002 | 02:21 AM
Light84vette
dam 8.50's on a base unit. Thats beyond great for me. I just did'nt what no junky tiny axel for it. How many are you planning on selling or producing? If its less than or 3 grand I'll take it. And this is totally bolt it? If it is then do the links bolt into the stock location?
Old Oct 24, 2002 | 02:23 AM
Light84vette
Also how is this kit going to support the tranny if the stock diff is not present?
Old Oct 24, 2002 | 08:18 AM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
I would like to go with a solid axle on my C3.. Howevever - the cost is pretty high...
Old Oct 26, 2002 | 01:56 PM
RPM Frank's Avatar
RPM Frank
Default Re: Switch C4 to a solid Axel? (GrandSportC3)
Yes, it's a total bolt in.......... Sorry but until the final design/assembly has been approved, we cant in all honestly give you the final number.
Part of the issue regarding final pricing will be on our own purchasing power after production begins, but as the laws of supply and demand go, the more we buy the better our pricing to the consumer in the final product. From what I've been seeing with in everyones enthusiam regarding this assembly, I think you'll be happy with the final sale price.
Plus you'll only be doing it once ......... Thats will save you in the long run.
Old Oct 26, 2002 | 01:58 PM
RPM Frank's Avatar
RPM Frank
Hi everyone, to answer some of the questions you have posted.....
This will be a complete "bolt in system", the hardest part will be finding a place to store your original IRS. Here's a short list of things to come out of it.
Hal fully adjustable Shocks.
Coil springs.
True fully adjustable 4 link.
Adjustable panard bar.
Utilises your original brakes with all ABS and E-brake functions.
Eaton Posi with choice of spring pressure or full spool.
Choice of gears up 5.89 ratio.
Hi Perf axles with stock or longer studs.
Original track width maintained and available for both wheel offsets.
Transmission X-member, available for TH350/Glide/400/700R4/4L60E/2004R
Aluminum driveshaft respective to trans choice.
C-Clip eliminator kit.
Strengthend cover.
Pinion angle locating plate, so not to remove the driveshaft to set angles.
As Mackey outlined previously in this post, pricing will be competative but will not be announced untill the final product has been completed for mass production. Expect this to happen in December and full production by January.
:chevy
Old Oct 26, 2002 | 11:01 PM
Light84vette
What king of tire can we stuff into it like what would be the largest size of Tire we could put into the corvette. Also would the distance between the chasiss and the axel be increased so you could put a bigger tire in it? Also how wide of a tire? Please specs in inches no crazy 30rz10 number.
Old Oct 27, 2002 | 12:41 AM
RPM Frank's Avatar
RPM Frank
Tire sizes and wheel offesets will remain unchanged, whatever works on your car now will work the same later, in today's market of numerous HP wheels, you can get whatever you like and or what suit's your needs.
The purpose of retaining the original geometry was with the street and strip car owner in mind, this way we can produce an item that will not force the customer into a myriad of additional expenses for custom items. If the sole purpose of the vehicle will be for track use only, then we can construct a unit to the specs required to suit the individuals needs.
Old Oct 27, 2002 | 04:09 AM
Light84vette
Is it possible to have say 25 or 26 inch street tires on the street and then when your at the track swap them for 28 or 29inch drag radials and drop the axel to sit farther away from the chasiss to allow that tall of a tire to fit into it? Maybe change the springs or shocks? Or some how adjust the links? Also what about the width of the tire, how fat can the meats be out back so they dont rub the inner fender and all the other parts?
Old Oct 29, 2002 | 04:04 PM
tpi 421 vette's Avatar
tpi 421 vette
RPM Frank, are you going to have a crossmember available for a ZF6 speed?
Old Oct 29, 2002 | 08:07 PM
  #33
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
I run 315x35x17 (26") BFG drag radials on 11" wheels on the street and my race set up is either 325x50x15 or 28x13.5x15 ET streets (both are 28") for the track. all 3 can be run with no alterations to chassis or ride heights. The same will be true for the solid axle.
However a 29" or 30" tire may require some outter wheel opening modifications.
Old Oct 29, 2002 | 08:26 PM
  #34
RPM Frank's Avatar
RPM Frank
Default Re: Switch C4 to a solid Axel? (mackeyred96)
Quote
(RPM Frank, are you going to have a crossmember available for a ZF6 speed?
Sorry, I completely forgot to mention the standards ...... The answer is yes, we will have a full line of crossmembers for stock, swap and aftermarket standard transmissions. Actually, we will also be offering complete swap kits for nearly any unit you may be interested in also. All trans kits will come complete and fully inclusive of hardware for a complete installation wthout the need of chasing parts, IE: Soup to Nuts ..... They will come in two flavors ....
Kit "A" Trans, crossmember, clutch of your choice, Pedal assemblies/cable or hydraulic master and slaves, Driveshaft, all hardware.
Kit "B" Crossmember, Pedal assemblies/cable or hydraulic master and slaves, Driveshaft, all hardware.
Each kit will be fully comprehensive to suit your needs and complete to the last nut and bolt using "Rockwell Standard" quality fasteners.
Old Oct 29, 2002 | 08:47 PM
  #35
Light84vette
What's the name of the company that will sell the solid Axel swap kits?
Old Oct 31, 2002 | 07:29 PM
  #36
RPM Frank's Avatar
RPM Frank
RPMdragracing
http://www.rpmdragracing.com
Old Oct 31, 2002 | 09:08 PM
  #37
mackeyred96
:cool:
To Switch C4 to a solid Axel?
Old Oct 31, 2002 | 10:17 PM
  #38
Light84vette
Thats just a one page website. Since this is such a good deal I just have to ask you are you really doing this or is this just one big lie for a direct bolt-in-kit to a solid axel?(no offense) Because its just that you and Mackey are the ones suppling the info on the Direct bolt in Kit and I think you only mentioned the company name untill I asked you to. Please dont come back and bring a Heated thread, I'm just asking not offending. And what engine and how much power did it take to get that Corvette to run 8.5's in the quarter on the base kit? It all seems a bit odd. :rolleyes: :confused:
Old Oct 31, 2002 | 10:40 PM
  #39
mackeyred96
( Please dont come back and bring a Heated thread, I'm just asking not offending.)
:confused:
YOU'VE GOT A FUNNY WAY OF ASKING A QUESTION WITHOUT EXPECTING A HEATED THREAD IN RETURN.
THE WAY I READ IT YOUR CALLING BOTH FRANK AND ME A LIER.
OR DID I MISREAD SOMETHING???????
1ST, THE PROTOTYPE IS GOING IN MY CAR.
WHO BETTER TO TEST IT?????
2ND, NOWHERE DOES IT SAY THAT IT WAS A CORVETTE THAT RAN 8.5 ONLY THAT THE AXLE SETUP HAS GONE THAT FAST TO ANSWER ANY QUESTION ABOUT IT'S DURABILITY AND STRENGTH.
3RD, I ASKED FRANK NOT TO MENTION HIS BUSINESS NAME ON THE FORUM UNTILL HE WORKSOUT THE DETAILS TO BECOME A SUPPORTING SPONSOR HERE ON THE FORUM.
I OWE THAT TO TROY AND THE OTHER SPONSORS HERE ON THE FORUM. IT'S JUST GOOD BUSINESS, IN DON'T WANT TO ANYTHING THAT WOULD BE CONSIDER OUT OF PLACE.
THANKS FOR YOUR KIND THOUGHT AND FOR YOUR INTEREST, I HOPE NOW YOU UNDRESTAND WHY WE DID WHAT WE DID.
I ONLY WISH YOU HAD ASKED ME FOR THIS INFO BY E-MAIL OR IM AND WOULD HAVE THIS OFF THE FORUM WHERE IT DOESN'T BELONGS.
THANKS AGAIN,
JOHN
[Modified by mackeyred96, 9:42 PM 10/31/2002]
Old Oct 31, 2002 | 11:39 PM
  #40
Light84vette
RPM Frank said this quote. Maybe I understood it wrong but I thought it said that on letter C the base unit has been proven to run 8.5's. Sorry for all that I did not know that you asked him to not talk about the company name. Anyway when it is a direct bolt in kit how wide of a tire can be put into it? Also If the crossmember for the tranny runs from under both the tunnels that are side by side next to the tranny, would their be any ground clearence problems like hitting a speed bump?
