Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
Switch C4 to a solid Axel?
Old Sep 17, 2002 | 08:05 PM
Light84vette's Avatar
Light84vette
Default Switch C4 to a solid Axel?
Does anyone have any pics of a C4 Corvette with a Solid straight axel installed in it with Drag tires maybe 29 or 31inches? I want to convert My 1984 Corvette to a drag vette using drag slicks and a straight axel and everything else. Could you guy's help me out :confused: :confused:
Old Sep 17, 2002 | 08:17 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: Switch C4 to a solid Axel? (Light84vette)
Welcome to the forum.
Wheelsup has a great photo of his solid axel C4.
I sure he will post it for your.
I'm looking at this mod also.
[Modified by mackeyred96, 7:19 PM 9/17/2002]
Old Sep 17, 2002 | 09:08 PM
boweryboy's Avatar
boweryboy
Cruise-In II Veteran
I second John's :cool: on Wheelsup rear end! It is very very nice! Ultra sweet!
One of the Vette Doctor's customer just had it done on a ZR1 and it is supposed to be very nice also. I do not believe they did the work but I am sure if you called them they would get you in touch with the shop that did it.
Old Sep 17, 2002 | 09:23 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: Switch C4 to a solid Axel? (boweryboy)
Yes Wheelsup has a Ford 9" I believe.
Old Sep 17, 2002 | 09:26 PM
wheelsup's Avatar
wheelsup
John and Bill, thanks for the kudos on the 4-link suspension. More and more guys are starting to look at this option. The car goes straight as an arrow. :yesnod:
This pic was taken soon after installed,but has since been painted.
It has a best 60' of 1.47 with a 350 small block. This may be my last season with this engine combo. This tires are 28",but plan on running a bigger tire.
Phil C
[Modified by wheelsup, 7:30 PM 9/17/2002]
Old Sep 17, 2002 | 10:20 PM
Light84vette
Default Re: Switch C4 to a solid Axel? (wheelsup)
Thanks for all the info Wheelsup. Do you have any pics of the exterior of the car, the way the tire fits in the wheel well. Also could you tell me what kind of axel you got in thier and where is a good place to buy one. Plus where all the pieces hand fabricated or was this some sort of kit like the Links? :cool: :chevy :cool:
Old Sep 18, 2002 | 09:47 AM
wheelsup's Avatar
wheelsup
I will try to get another pic of wheels/tires. The rear is mostly fabricated all but the Ford housing,axles,center section axles flanges,coilovers and brakes. There is no kit available to my knowledge.
Phil C
Old Sep 18, 2002 | 01:38 PM
NJVetteGuy's Avatar
NJVetteGuy
You might also want to talk to Julio at Cartek...he did the solid axle swap in his C4 that runs deep in the 10s :cheers:
Old Sep 18, 2002 | 01:58 PM
mackeyred96
Default Re: Switch C4 to a solid Axel? (NJVetteGuy)
Julio's is a Dana 60 that bolts into the stock IRS mounts.
Old Sep 19, 2002 | 10:55 PM
Light84vette
Heu wheelslup, What parts did you have to remove in order to make the axel fit and function. Also did you have to take out the two compartments that hold the tire jack and the extra which are located behind the seats?
Old Sep 20, 2002 | 02:35 PM
wheelsup's Avatar
wheelsup
The rear compartments must go as well as tge ABS. The ABS is a joke anyway,so I did not miss it. I actually have better brakes w/o it.
Phil
Old Sep 21, 2002 | 12:21 AM
Light84vette
How do you take out the rear compartments? Plus when you take them out what did you use to cover up the hole. Also where does you exhaust come out from? :flag
Old Sep 21, 2002 | 09:12 AM
wheelsup's Avatar
wheelsup
The rear compartments were cut out. This is a major project. The hole is covered with aluminum.New exhaust will need to be fabricated as well.
Phil
Old Sep 21, 2002 | 07:54 PM
Light84vette
Do your Drag Links for the axels fit in the stock location? If not where did you put them? Plus not to be to rude could you please post some pics on how the tire looks like in the wheel well? From outside :flag
Old Sep 21, 2002 | 08:37 PM
wheelsup's Avatar
wheelsup
The 4-link bars are not on the frame rail. They are now on their own cross member. Unfortunately, I'am out of town for a few weeks (pics).
Phil
Old Sep 21, 2002 | 09:42 PM
Light84vette
Thanks Phill you really help me gain some knowledge on putting a sold axel on my Corvette. I still have one other question, since you do not have an IRS set up and now have an axel that moves up and down, How do you support the tranny since the beam is supported by the Diff which is not there. Or did you just make a custom beam that runs from the tranny to a bracket connected to the chasiss? :confused:
Old Sep 23, 2002 | 11:05 PM
Light84vette
Hey wheelsup how hard was it to fit and place in all the parts and take the unneeded ones out? How long did it take? :cheers:
To Switch C4 to a solid Axel?
Old Sep 24, 2002 | 09:14 AM
wheelsup's Avatar
wheelsup
This was ~4-5 week project. I removed the IRS and the fabricator did the rest.
Phil
Old Oct 22, 2002 | 08:07 PM
Light84vette
Where did you get the axel from and what model is it. Would it be difficult to weld in and fab the new parts and make it work. Also how do you support your tranny?
Old Oct 23, 2002 | 11:24 PM
Light84vette
come on I know you people saw this topic. reply the buttons right there to the right of the screen :crazy:
